  3. My own board (50mm x 30mm)
133 Posts 22 Posters 119.5k Views 21 Watching
  • GertSandersG
    GertSandersG
    GertSanders
    Just realised this. Indeed, I will start a new topic.
    • GertSandersG
      GertSandersG
      GertSanders
      wrote on last edited by GertSanders
      #42
      Second variant with the same board. This one actually sends it's messages better (no more st:fail's):
      And it's nice and compact. Now I need to find a nice ventilated little box to protect them from dust.
      This board is now tested and shared on OSHPark: https://oshpark.com/shared_projects/unP8BmuI
      Component values are mentioned in the brd file. I will add a BOM in Excel format later.
        maciejka
        Really great job!!!
          MikeF
          This might work - it's well ventilated; width & depth OK, but don't know about height.
          http://www.ebay.co.uk/itm/291147751395?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
          • GertSandersG
            GertSandersG
            GertSanders
            My dirty dirty boards have arrived today :-)
            I actually received 12 boards, so I can make 24 sensors, great succes :+1: !!!
            ahmedadelhosniA 1 Reply Last reply
            • DidiD
              DidiD
              Didi
              @GertSanders
              Please post the BOM.
              if (knowledge == 0) { use BRAIN; use GOOGLE;use SEARCH; } else {make POST;}
              • GertSandersG
                GertSandersG
                GertSanders
                @Didi Here is the BOM and EAGLE files.
                selfcontained low power node v1.csv
                selfcontained low power node v1.brd
                selfcontained low power node v1.sch
                DidiD 1 Reply Last reply
                • GertSandersG
                  GertSandersG
                  GertSanders
                  #48
                  Preview of my latest board, waiting for prototypes to test this ....
                  This is a 50x50mm board with multiple powering options (AA or AAA batteries, direct 3.3 or 5V DC, 4.5-20V DC in, 220V AC) and can fit a GSM module at the same time as the NRF24 radio. Allows 2 variants of I2C connection (SDA and SCL on IO header can be swapped via soldering pads). Room for signing chip and some I2C based EEPROM or FRAM memory. Several connectors for digital pins with power.
                  Fits into this box:
                  http://www.aliexpress.com/item/Free-shipping-2-pcs-lot-60-58-28mm-plastic-housing-DIY-project-box-ABS-junction-box/2039860908.html
                  • GertSandersG GertSanders
                    DidiD
                    DidiD
                    Didi
                    Thank you
                    • P
                      P
                      pjeterinfo
                      @GertSanders Hi Gert, on the small board, did you soldered C2 and C3 on the bottom or on top just under/in the IC socket?
                      • GertSandersG
                        GertSandersG
                        GertSanders
                        @pjeterinfo On one of the sensors I soldered it on the bottom between the two connectors on the bottom.
                        For the sensors where I add the batteryholder on the bottom, I do indeed solder these capacitors on topside between the legs of the chip. Later this evening I will make a photo of such a setup.
                        • GertSandersG
                          GertSandersG
                          GertSanders
                          #52
                          This is the small board on an AA batteryholder.
                          • Carl HC
                            Carl HC
                            Carl H
                            very good job, i'm very interested to try your board. Did you try to order from
                            dirtypcbs.com vs oshpark for the price?
                            • GertSandersG
                              GertSandersG
                              GertSanders
                              #54
                              I ordered from both. From OSHPark because they have a 10-12 days turnaroundtime for me (to Belgium) so I could test faster and Dirtypcb because of price (quality is as good, only ENIG is missing). The boards are shared on both manufacturers websites.
                              More details here:
                              http://forum.mysensors.org/topic/595/pcb-boards-for-mysensors/30
                              • GertSandersG
                                GertSandersG
                                GertSanders
                                My AC capable boards have arrived in the mail today, some of these will become repeaters, some will be GSM nodes, I know what to do the coming days :-)
                                • G
                                  G
                                  gloob
                                  wrote on last edited by gloob
                                  #56
                                  I did also order your red board now and will try it. Do you have a wiring diagram that I can open with adobe reader or something else.
                                  • GertSandersG
                                    GertSandersG
                                    GertSanders
                                    #57
                                    @gloob Here is the diagram: GSRedboard schematic.pdf
                                    This is the same schematic as "selfcontained low power node v1.sch"
                                    Since a Redboard already exists (Sparkfun makes them), I added the GS prefix, but I like the name suggestion :-)
                                      ahmedadelhosniA
                                      ahmedadelhosniA
                                      ahmedadelhosni
                                      @GertSanders I don't understand the shipping price on dirtypcb. They say "10 each 5x5cm PCBs $14" so that mean that 10 pcbs boards, each are 5x5 cms will cost 14$, right ?
                                      but when I choose buy, I get confused. In the quantity selection there is protpack +-10 which is 14$, and another option to set the quantity to 10, 20 or 30, it increases the price to 28$
                                      Can you please clarify this ? Thanks
                                      • mountainmanM
                                        mountainmanM
                                        mountainman
                                        http://dirtypcbs.com/about.php
                                        If you need a specific quantity of boards the use a more expensive board house. The proto pack will be 10 +/- 1 boards.
                                        • mountainmanM mountainman
                                          ahmedadelhosniA
                                          ahmedadelhosniA
                                          ahmedadelhosni
                                          @mountainman Thanks. Strange offer to have expect 9 or 12 boards :D
