  2. Bug Reports
  3. Error Compiling
Error Compiling
6 Posts 4 Posters 4.3k Views 2 Watching
  • b0rmannB
    b0rmannB
    b0rmann
    all is broken in last version :)
    In file included from EnergyMeterPulseSensor.ino:38:0:
    /home/andrej/sketchbook/libraries/MySensors/MySensor.h:158:70: error: expected type-specifier before ‘MyHwDriver’
    MySensor(MyTransport &radio =*new MyTransportNRF24(), MyHw &hw=*new MyHwDriver()
    EnergyMeterPulseSensor.ino:47:10: error: call to ‘MySensor::MySensor(MyTransport&, MyHw&)’ uses the default argument for parameter 2, which is not yet defined
    In file included from DallasTemperatureSensor.ino:27:0:
    DallasTemperatureSensor.ino:39:10: error: call to ‘MySensor::MySensor(MyTransport&, MyHw&)’ uses the default argument for parameter 2, which is not yet defined
    • A
      A
      ampmendes
      I am trying to compile the SerialGateway.ino example and keep getting the same error
      I am using the arduino ide and downloaded the 1.5 version of the library. With the 1.4 version it compiles ok, but i want to create a serial gateway with RFM69 Radio
      I appreciate the help, i am new to this and i am discovering.
      SparkmanS 1 Reply Last reply
      • A ampmendes
        SparkmanS
        SparkmanS
        Sparkman
        @ampmendes Did you delete all 1.4 libraries before loading the 1.5 ones and then restarting the IDE? These types of errors are typically caused by having mutliple files with the same name.
        Cheers
        Al
        b0rmannB 1 Reply Last reply
        • SparkmanS Sparkman
          Cheers
          Al
          b0rmannB
          b0rmannB
          b0rmann
          @Sparkman i do not use IDE...
            Then remove old MySensors library (and sketch) from your codebender account before cloning sketch again from mysensors.org (with libraries).
            • A
              A
              ampmendes
              Thank for the reply, but i already found the problem, i was using an old IDE, i installed the last version and it fixed the problem
