  3. RS485/RS232/Serial transport class for mysensors.org
rs485 serialrs485
143 Posts 27 Posters 138.9k Views 27 Watching
  • elmarculinoE
    elmarculinoE
    elmarculino
    @LeoDesigner I still could not make it work in 1.5.2 with your library, but I will keep trying. Thanks!
    @hek I finally could make a gateway / sensor (Humidity) connection via RS485 using the development branch. Is any Controller compatible with the development branch? Thanks!
    0;255;3;0;9;Starting gateway (RSNGA-, 2.0.0-beta)
    0;255;3;0;9;Radio init successful.
    0;255;3;0;9;Init complete, id=0, parent=0, distance=0
    0;255;3;0;9;read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:44.0
    1;0;1;0;1;44.0
    0;255;3;0;9;read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:43.0
    1;0;1;0;1;43.0
    1;0;1;0;1;44.0
    0;255;3;0;9;read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:27.0
    1;1;1;0;0;27.0
      Great to hear. Did you need to make any adjustments?
      Yes, the serial protocol is backward compatible. So any controller should work as good.
      • elmarculinoE
        elmarculinoE
        elmarculino
        @hek None. Works out of the box. But I could not make it work with Home Assistant.
        Pin 9 >>> DI
        Pin 8 >>> RO
        Pin 2 >>> DE and RE
        INFO:mysensors.mysensors:/dev/ttyUSB0 is open...
        INFO:mysensors.mysensors:Connected to /dev/ttyUSB0
        INFO:mysensors.mysensors:n:0 c:255 t:3 s:9 p:read: 1-1-0 s=0,c=1,
        WARNING:mysensors.mysensors:Error decoding message from gateway, probably received bad byte.
        WARNING:mysensors.mysensors:Error decoding message from gateway, probably received bad byte.```
        • elmarculinoE
          elmarculinoE
          elmarculino
          @LeoDesigner My 1.5.2 RS485 Humidity sensor send the same messages as the example Humidity sketch, but shows a lot of 'X' and '?' characters at 115200 in Serial Console.
          The console with the example Humidity sketch is clean:
          sensor started, id=1, parent=0, distance=1
          send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=8,sg=0,st=ok:Humidity
          send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
          send: 1-1-0-0 s=0,c=0,t=7,pt=0,l=0,sg=0,st=ok:
          send: 1-1-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=ok:
          send: 1-1-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:26.0
          T: 26.00
          send: 1-1-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,st=ok:44.0
          H: 44.00
          Do you know what can be causing it? Am I doing anything wrong, again?
          #include <DHT.h>
          #include <MyHwATMega328.h>
          #include <SerialTransport.h>
          #define CHILD_ID_HUM 0
          #define CHILD_ID_TEMP 1
          MyTransportSerial transport(Serial,5,2);
          MyHwATMega328 hw;
          MySensor gw(transport, hw);
          DHT dht;
          float lastTemp;
          float lastHum;
          boolean metric = true;
            gw.begin();
            gw.sendSketchInfo("Humidity", "1.0");
            if (isnan(temperature)) {
              lastTemp = temperature;
              if (!metric) {
              Serial.print("T: ");
              Serial.println(temperature);
            if (isnan(humidity)) {
                lastHum = humidity;
                Serial.print("H: ");
                Serial.println(humidity);
            gw.sleep(SLEEP_TIME); //sleep a bit
          L 1 Reply Last reply
          • elmarculinoE elmarculino
            T: 26.00
            H: 44.00
            #include <DHT.h>
            MyHwATMega328 hw;
            DHT dht;
            float lastTemp;
            float lastHum;
              gw.begin();
                if (!metric) {
                  lastHum = humidity;
            L
            L
            LeoDesigner
            wrote on last edited by LeoDesigner
            #85
            @elmarculino
            My library is using a standard hardware serial port of arduino - you have to disable debug option in MySensors config and use the serial port only for RS485. The 'garbage' you are receiving are actual binary communication packets intended only for RS485 bus. You have to disconnect your serial to usb adapter in case if you are using Arduino Pro. Please take a closer look to the video and schematic coming with the library. You can use and 'sniff' your serial console - but you must to disable any additional serial debug prints to the console in production mode. Remember - your serial console is a RS485 bus with this library.
            • radekzmR radekzm
              @Michal
              I'll help when I get back from work.
              MichalM
              MichalM
              Michal
              @radekzm
              OK, what I did:
              on one Arduino nano I have this sketch
              https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/GatewaySerialRS485/GatewaySerialRS485.ino
              on second arduino nano I have conbined two sketches:
              https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/DistanceSensor/DistanceSensor.ino
              and
              https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/MotionSensorRS485/MotionSensorRS485.ino
              and the results is:
               * Version 1.0 - Henrik Ekblad
               * This is an example of sensors using RS485 as transport layer
               * Motion Sensor example using HC-SR501
               * http://www.mysensors.org/build/motion
               * The transport uses AltSoftSerial to handle two serial links
               * on one Arduino. Use the following pins for RS485 link
               *  Board          Transmit  Receive   PWM Unusable
               * Teensy 3.0 & 3.1  21        20         22
               * Teensy 2.0         9        10       (none)
               * Teensy++ 2.0      25         4       26, 27
               * Arduino Uno        9         8         10
               * Arduino Leonardo   5        13       (none)
               * Arduino Mega      46        48       44, 45
               * Wiring-S           5         6          4
               * Sanguino          13        14         12 *
              // Enable RS485 transport layer
              #define MY_RS485
              // Define this to enables DE-pin management on defined pin
              #define MY_RS485_DE_PIN 2
              // Set RS485 baud rate to use
              #define MY_RS485_BAUD_RATE 9600
              #include <NewPing.h>
              #define CHILD_ID 1
              #define TRIGGER_PIN  5  // Arduino pin tied to trigger pin on the ultrasonic sensor.
              #define ECHO_PIN     6  // Arduino pin tied to echo pin on the ultrasonic sensor.
              #define MAX_DISTANCE 300 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
              unsigned long SLEEP_TIME = 5000; // Sleep time between reads (in milliseconds)
              NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
              MyMessage msg(CHILD_ID, V_DISTANCE);
              int lastDist;
                metric = getConfig().isMetric;
              void presentation() {
                sendSketchInfo("Distance Sensor", "1.0");
                present(CHILD_ID, S_DISTANCE);
                int dist = metric?sonar.ping_cm():sonar.ping_in();
                Serial.print("Ping: ");
                Serial.print(dist); // Convert ping time to distance in cm and print result (0 = outside set distance range)
                Serial.println(metric?" cm":" in");
                if (dist != lastDist) {
                    send(msg.set(dist));
                    lastDist = dist;
                sleep(SLEEP_TIME);
              On serial port (/dev/ttyUSB0) Controller (first nano) I see:
              on serial port(/dev/ttyUSB1) in node is see:
              Ping: 33 cm
              Ping: 34 cm
              Ping: 34 cm
              Ping: 33 cm
              Ping: 33 cm
              Ping: 33 cm
              Ping: 5 cm
              Ping: 91 cm
              Ping: 88 cm
              Ping: 89 cm
              But I expect to see some message on controller. What can I check? Do you see and mistakes ?
                Mariusz
                wrote on last edited by Mariusz
                #87
                I am new in mysensors and arduino however I already use domoticz with mysensors and rflink.
                Everything is working fine however now I plan to renovate my house and I would like to put wire connection using max485 and arduino. Problem is that it is now working :( I have tried 1.5.4 version and also development branch. It seems that signal is not getting to gateway. I nothing see on arduino gateway except of initalization gateway. I have started to use two nano but I also tried combination nano and mega without success. I would be very appreciate if someone who done it could more describe how to make that it works.
                I tried https://arduino-info.wikispaces.com/SoftwareSerialRS485Example and it works fine.
                I use for nano combination pins 2 (de/re), 8 (ro),9(di)
                radekzmR 1 Reply Last reply
                • M Mariusz
                  radekzmR
                  radekzmR
                  radekzm
                  @Mariusz jak jesteś Polakiem ? Jeżeli tak to mogę Ci pomóc po polsku będzie łatwiej :)
                  m26872M 1 Reply Last reply
                  • radekzmR radekzm
                    m26872M
                    m26872M
                    m26872
                    @radekzm Please use private chat/PM if you don't intend everyone to read it.
                    • radekzmR
                      radekzmR
                      radekzm
                      wrote on last edited by radekzm
                      #90
                      @m26872
                      I'm sorry and promises to improve :)
                      @Mariusz
                      In my case the solution was in MyConfig.h file (in my case C:\Program Files (x86)\Arduino\libraries\MySensors):
                      1. Disable function MY_DISABLED_SERIAL
                        commenting lines 49
                        // #define MY_DISABLED_SERIAL
                      2. Disable function MY_DEBUG
                        commenting lines 36
                        //#define MY_DEBUG
                      3. Correct connection is on my pictures enclosed in the above comment
                      Board | Transmit | Receive | PWM Unusable
                      Arduino Uno | 9 | 8 | 10 <----- Form https://www.pjrc.com/teensy/td_libs_AltSoftSerial.html .... (& other ATMEGA328)
                      Arduino Leonardo | 5 | 13 | (none)
                      Arduino Mega | 46 | 48 | 44, 45
                      DE and RE -> Pin 2
                      RO -> Pin 8
                      DI -> Pin 9
                      1. To check the hardware and connections run the "Example Program" from https://www.pjrc.com/teensy/td_libs_AltSoftSerial.html
                      2. Use development branch
                      • L LeoDesigner
                        Hi everyone !
                        I needed a wired solution for my several nodes.
                        Here is the serial rs485/rs232 wired network transport for mysensors.
                        https://github.com/leodesigner/mysensors-serial-transport
                        It is based on the Majenko ICSC serial library.
                        Can you please test it? It is a beta version - but it is working for me.
                        (However, I am still waiting for my rs485 boards to arrive)
                        You can find more technical information at
                        http://sourceforge.net/p/arduino-icsc/wiki/RS-485/
                        To use it, you have to:
                        1. Put SerialTransport.cpp and SerialTransport.h to folder/directory/path SerialTransport in your library.
                        2. Add #include <SerialTransport.h> to your .ino sketch
                        3. Replace transport class with:
                          MyTransportSerial transport(Serial,0,-1); // serial port, node, dePin (-1 disabled)
                        Please let me know about bugs and how it is working for you.
                        skatunS
                        skatunS
                        skatun
                        @LeoDesigner
                        Hi, I am trying to do almost the same, but I would like to use softwareSerial instead of altsoft. The reason why I would do this is that i can barely fit the arduino nano inside my case, and an additional rs485 module would not fit and that I have 8 nodes connected on the softwareserial . I have tested software serial on arduino and it seems to work fine up to 15meters, I also adjusted the baudrate to 9600 since my node does not send out/receive large amount of data. I read that you did some work on software serial and were wondering if you could take a look at this thread.
                        • CrankyCoderC
                          CrankyCoderC
                          CrankyCoder
                          Is there any how-to's on this transport class as far as the hardware goes? How does it work with multiple nodes? Is it like a ring pattern? or do all the nodes have to have a dedicated connection to the gateway.
                          Home Automation Tinkerer
                          www.CrankyCoder.net
                          Gateway: MQTTClientGateway
                          MySensors: 2.3
                          • tbowmoT
                            tbowmoT
                            tbowmo
                            Depends on your physical transport layer. I would say a multidrop link where everything is in parallel..
                            • H
                              H
                              hausinger
                              Is it possible, to built a esp8266 wifi gateway and communicate GW to node with rs485?
                              In altsoft esp8266 is not decleared, so i can't use it out of the box.
                              Btw: I tested my_rs485 with nano as GW and Pro Mini as node, and it worked great. Thank you :)
                                @hausinger I don't think so. I haven't heard of anyone trying. I guess you'd have to replace alt-soft-serial with something else.
                                • scalzS
                                  scalzS
                                  wrote on last edited by scalz
                                  #96
                                  @hausinger if you know about coding..
                                  • plain C lib for esp8266, it can be adapted to work with Arduino Esp: https://github.com/plieningerweb/esp8266-software-uart
                                  • or use stock arduino esp8266 software serial lib (https://github.com/plerup/espsoftwareserial), and inspire yourself from lib above, and code your CE pin management..
                                  • BartB
                                    BartB
                                    Bart
                                    Any reason why this lib is not using Serial1 or Serial2 on Arduino Mega 2560 instead of AltSoftSerial?
                                      @Bartek-Celary
                                      No, not really. Just that not many that uses 2560.
                                      • BartB
                                        BartB
                                        Bart
                                        wrote on last edited by Bart
                                        #99
                                        How about adding the following define to use the Serial1/2 on Mega. I have not tested yet but assuming the AltSoftSerial lib has the same interface/functionality it should work.
                                        #define MY_RS485_SERIAL Serial1
                                        diff --git a/core/MyTransportRS485.cpp b/core/MyTransportRS485.cpp
                                        index 814f721..ea35c9e 100644
                                        --- a/core/MyTransportRS485.cpp
                                        +++ b/core/MyTransportRS485.cpp
                                        @@ -92,7 +92,11 @@ unsigned char _recSender;
                                         unsigned char _recCS;
                                         unsigned char _recCalcCS;
                                        +#if defined(MY_RS485_SERIAL)
                                        +HardwareSerial& _dev = MY_RS485_SERIAL;
                                        +#else
                                         AltSoftSerial _dev;
                                        +#endif
                                         unsigned char _nodeId;
                                          Looks like a neat solution. If it verifies ok, please create a pull request agains the development branch.
