  3. LCD Clock and Text sensor node with new V_TEXT
39 Posts 11 Posters 34.4k Views 21 Watching
  • AWIA
    AWIA
    AWI
    On special request of @pepov attached a piece of LUA script for Domoticz. This demonstrates how to fill V_TEXT devices from other values so that thes can be displayed on the Text sensor node.
    This special example demonstrates how to fill V_TEXT with weather data from a virtual device connected to Weather Underground. Please search the Domoticz wiki for more information on this special service.
    -- script to read the virtual Weatherstation (Weather Underground) service and send it to "V_TEXT" MySensors devices
    -- Weather Underground values are in 'WUWeer' and 'WUWind'
    commandArray = {} ;
    --Weatherstation data:
    sWeatherTemp, sWeatherHumidity, sWeatherUV, sWeatherPressure, sWeatherUV2 = otherdevices_svalues['WUWeer']:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)") ;
    sWeatherTemp = tonumber(sWeatherTemp);
    sWeatherHumidity = tonumber(sWeatherHumidity);
    sWeatherUV = tonumber(sWeatherUV);
    sWeatherPressure = tonumber(sWeatherPressure);
    sWeatherUV2 = tonumber(sWeatherUV2);
    -- print to log
    print("Weather station: Temperature is " .. sWeatherTemp .. " ");
    print("Weather station: Humidity is " .. sWeatherHumidity .. " ");
    print("Weather station: UV is " .. sWeatherUV .. " ");
    print("Weather station: Pressure is " .. sWeatherPressure .. " ");
    print("Weather station: UV2 is " .. sWeatherUV2 .. " ");
    --Windmeter data:
    sWindDirectionDegrees, sWindDirection, sWindSpeed, sWindGust, sWindTemperature, sWindFeel = otherdevices_svalues['WUWind']:match("([^;]+);([^;]+);([^;]+);([^;]+);([^;]+);([^;]+)") ;
    sWindDirectionDegrees = tonumber(sWindDirectionDegrees);
    sWindDirection = (sWindDirection);
    sWindSpeed = tonumber(sWindSpeed);
    sWindGust = tonumber(sWindGust);
    sWindTemperature = tonumber(sWindTemperature);
    sWindFeel = tonumber(sWindFeel);
    print("Windmeter: Winddirection (in degrees) is: " .. sWindDirectionDegrees .. " ");
    print("Windmeter: Winddirection is: " .. sWindDirection .. " ");
    print("Windmeter: Windspeed is: " .. sWindSpeed .. " ");
    print("Windmeter: Windgust is: " .. sWindGust .. " ");
    print("Windmeter: Windtemperature is: " .. sWindTemperature .. " ");
    print("Windmeter: Windfeel is: " .. sWindFeel .. " ");
    -- device numbers 725/ 873 and 872 are V_TEXT
    commandArray[1] = {['UpdateDevice'] = string.format ("725|0|out %4.1f\01 %2d\07 %4d\02\03  ", sWeatherTemp, sWeatherHumidity, sWeatherPressure)}
    commandArray[2] = {['UpdateDevice'] = string.format ("873|0|%2.1f:%3d:%4.1f", sWeatherTemp, sWeatherHumidity, sWeatherPressure)}
    commandArray[3] = {['UpdateDevice'] = string.format ("872|0|%3d:%4.1f:%4.1f:%4.1f:%4.1f", sWindDirectionDegrees, sWindSpeed/10 , sWindGust/10, sWindTemperature, sWindFeel)}
    return commandArray
    pepovP 1 Reply Last reply
    • AWIA AWI
      commandArray = {} ;
      -- print to log
      --Windmeter data:
      return commandArray
      pepovP
      pepovP
      pepov
      Wow Thanks AWI!!!!
      • NiklasON
        NiklasON
        NiklasO
        Does this work with MySensors 2.0? If someone has this running on 2.0, please share the code. :)
        Q 1 Reply Last reply
        • Marc-Olivier ChaubetM
          i try to send message but nothing change on LcdDisplay.
          I d'ont undestant what is wrong.
          Can you help me pls.
          send: 49-49-20-0 s=8,c=2,t=47,pt=0,l=0,sg=0,st=ok:
          send: 49-49-20-0 s=9,c=2,t=47,pt=0,l=0,sg=0,st=ok:
          read: 0-20-49 s=9,c=1,t=16,pt=0,l=4,sg=0:test
          send: 49-49-20-0 s=9,c=1,t=16,pt=0,l=4,sg=0,st=ok:test
          AWIA 1 Reply Last reply
          • NiklasON NiklasO
            Q
            Q
            Qu3Uk
            @NiklasO I have something similar running on MYS 2.0 and can paste the code. I'm using a 4x1 display and using V_VAR-1-4 to send each line over.
            If that's useful to you I can post it.
            NiklasON 1 Reply Last reply
            • Q Qu3Uk
              NiklasON
              NiklasON
              NiklasO
              wrote on last edited by NiklasO
              #26
              Yes please. I ported to 2.0 late yesterday and it works ok. I have 4 lines, 20 chars.
              • Marc-Olivier ChaubetM Marc-Olivier Chaubet
                AWIA
                AWIA
                AWI
                wrote on last edited by AWI
                #27
                @Marc-Olivier-Chaubet Can you post a little more information (the sketch)?
                The text seems to be arriving at the node. So first check if the information comes in on serial (Serial.print(....)).
                And next: is your display working? just print something it in the local sketch.
                • NiklasON NiklasO
                  Q
                  Q
                  Qu3Uk
                  @NiklasO
                  Here is it.
                  //#define MY_DEBUG
                  //#define MY_NODE_ID 200
                  #define MY_SENSOR_ID 1
                  #define MY_REPEATER_FEATURE
                  // LCD includes
                  #include <Wire.h>
                  // MYS includes
                  #define LCD_ON 1  // GPIO value to write to turn on attached relay
                  #define LCD_OFF 0 // GPIO value to write to turn off attached relay
                  LiquidCrystal_I2C lcd(0x3f, 20, 4); //0x3f is the LCD address.
                  String LINE_BLANK = "                    ";
                  void before() {
                    // Set off  LCD module
                    lcd.begin ();
                    lcd.backlight();
                    lcd.setCursor(0, 0); //
                    lcd.print("Ready!"); // We expect the controller to remove this from display.
                    sendSketchInfo("LCD Display", "1.0");
                    present(MY_SENSOR_ID, S_INFO);
                    // extra processing if required.
                      // Use V_STATUS to turn on/off the LCD display
                      // if supported by LCD.
                    // temp string, probably don't need this.
                    if (message.type == V_VAR1) {
                      writeScreen(0, message.data);
                    if (message.type == V_VAR2) {
                      writeScreen(1, message.data);
                    if (message.type == V_VAR3) {
                      writeScreen(2, message.data);
                    if (message.type == V_VAR4) {
                      writeScreen(3, message.data);
                  void writeScreen(int line, String text)
                    // Trim whitespace from incoming text.
                    text.trim();
                    // Remove anything over 20 char in text.
                    if(text.length() > 19)
                        text.remove(20);
                    // Clear the line
                    lcd.setCursor(0, line);
                    lcd.print(LINE_BLANK);
                    // Set Line
                    lcd.print(text);
                  user1306U 1 Reply Last reply
                    wrote on last edited by Marc-Olivier Chaubet
                    #29
                    Hi AWI,
                    Yes my display is working, i can see the date and "Line 1 - First....."
                    I think what i send is not correct....0_o
                    This is from the serial monitor
                    Should it be something like this
                    read: 0-20-49 s=9,c=1,t=16,pt=0,l=4,sg=0:Line1=test
                    this is the sketch.
                     PROJECT: MySensors / LCD display for text from controller
                     PROGRAMMER: AWI
                     DATE: september 8, 2015/ last update: september 8, 2015
                     FILE: AWI_LCD_49.ino
                     LICENSE: Public domain
                     Hardware: tbd ..MYS Ceech - ATmega328p board w/ NRF24l01
                        and MySensors 1.5 ()
                    Special:
                        MySensors - Development (as of sept 2015)
                    SUMMARY:
                        display time & 2 lines of text from Controller Text sensors
                    #include <MyMessage.h>
                    #include <MySensor.h>                       // Mysensor network
                    #include <Time.h>                           //http://playground.arduino.cc/Code/Time
                    #include <Wire.h>
                    // uncomment if you are using the DEVELOPMENT version with V_TEXT & V_INFO defined (better to use development MyMessage.h)
                    const byte V_TEXT = 47 ;                  // values taken from development edition MyMessage.h
                    const byte S_INFO = 36 ;
                    const byte nodeId = 49 ;                    // MySensors fixed node id
                    const byte LCD1_CHILD = 8 ;                 // LCD line 1
                    const byte LCD2_CHILD = 9 ;                 // LCD line 2
                    char lastLCD1[21] = "Line1 - first   ";     // define & init before first receive
                    char lastLCD2[21] = "Line2 - second  ";
                    boolean timeReceived = false ;
                    // timers for loop delays
                    unsigned long lastUpdate=0, lastRequest=0, lastDisplay=0;
                    int display_no = 0 ;                        // current display
                    // *** Definition and initialisation
                    // define the MySensor network
                    MyTransportNRF24 transport(9,10);           // Sensoduino (8,7) Ceech board, 3.3v (7,8)  (pin default 9,10)
                    MySensor gw(transport);
                    // Initialize messages for sensor network
                    MyMessage textMsg(0, V_TEXT);
                    //                    addr, en,rw,rs,d4,d5,d6,d7,bl,blpol
                    LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);  // Set the LCD I2C address
                    // OPTIONAL: Custom characters for display - Units)
                    byte heart[8] = { B00000, B01010, B11111, B11111, B01110, B00100, B00000, B00000};
                    void setup(void){
                        //Serial in Sensor network = 115200
                        gw.begin(incomingMessage, nodeId);                  // this node is 49 fixed
                        //Send the sensor node sketch version information to the gateway
                        gw.sendSketchInfo("AWI_LCD text 49", "1.1");
                        gw.present(LCD1_CHILD, S_INFO, "LCD_line1");        // new S_type 20150905 (not know by domoticz)
                        gw.present(LCD2_CHILD, S_INFO, "LCD_line2");
                        gw.send(textMsg.setSensor(LCD1_CHILD).set("-"));    // initialize the V_TEXT at controller for sensor to none (trick for Domoticz)
                        gw.send(textMsg.setSensor(LCD2_CHILD).set("-"));
                        // Initializations
                        gw.requestTime(receiveTime);                        // get the time from controller (handled by receiveTime)
                        // ** LCD display **
                        Wire.begin();                                       // I2C
                        lcd.begin(16, 2);                                   // LCD 2 lines * 16 char.
                        lcd.setBacklight(HIGH);
                        lcd.createChar(1, heart);
                        // lcd.write(byte(0)); // write units
                    void loop(void){
                        // timer for loop delays
                        unsigned long now = millis();
                        gw.process() ;
                        // If no time has been received yet, request it every 10 second from controller
                        // When time has been received, request update every hour
                        if ((!timeReceived && (now-lastRequest > 10*1000)) ||
                            (now-lastRequest > 3600000UL)){                 // request update every hour to keep in sync
                           // Request time from controller.
                           Serial.println("requesting time");
                           timeReceived = false;
                           lastRequest = now;
                        // Change display and update sensors every 5 seconds (default = 5000)
                        if (now-lastDisplay > 5000){
                            lastDisplay = now;
                            gw.request(LCD1_CHILD, V_TEXT, 0);                  // request new values from controller
                            gw.request(LCD2_CHILD, V_TEXT, 0);                ;// request new values from controller
                            // change display
                            display_no++;
                                if (display_no >= 2){ // wrap for number of different displays for second line
                                display_no = 0;
                        // Update display every second
                        if (now-lastUpdate > 1000) {
                            LCD_local_display();
                            lastUpdate = now;
                    // This is called when a new time value was received
                    void receiveTime(unsigned long controllerTime) {
                        Serial.print("Time value received: ");
                        Serial.println(controllerTime);
                        setTime(controllerTime);                            // time from controller
                        timeReceived = true;
                    // This is called when a message is received
                        if (message.type==V_TEXT) {                         // Text messages only
                         // Write some debug info
                         Serial.print("Message: "); Serial.print(message.sensor); Serial.print(", Message: "); Serial.println(message.getString());
                        if (message.sensor == LCD1_CHILD ) {
                            snprintf(lastLCD1, sizeof(lastLCD1), "%16s", message.getString());  // load text into LCD string
                        else if (message.sensor == LCD2_CHILD){
                            snprintf(lastLCD2, sizeof(lastLCD2), "%16s", message.getString());
                    void LCD_local_display(void){
                    // take car of LCD display information
                        char buf[17]; // temp buffer for max 16 char display
                        // start with location & time on first line
                        snprintf(buf, sizeof buf, "%02d:%02d:%02d %02d-%02d", hour(), minute(), second(), day(), month());
                        lcd.print(buf);
                        lcd.setCursor(0, 1);
                        if (display_no == 0){
                          lcd.print(lastLCD1);                          // second line is text value from controller
                        } else {                                        // display == 2
                          lcd.print(lastLCD2);
                    Thxs
                      Hi AWI,
                      this is the sketch.
                       PROGRAMMER: AWI
                      Special:
                      SUMMARY:
                      #include <Wire.h>
                      void setup(void){
                          // Initializations
                      void loop(void){
                          gw.process() ;
                             lastRequest = now;
                              lastDisplay = now;
                              // change display
                              display_no++;
                                  display_no = 0;
                              lastUpdate = now;
                          lcd.print(buf);
                      Thxs
                      AWIA
                      AWIA
                      AWI
                      #30
                      @Marc-Olivier-Chaubet You should be receiving the TEXT value coming from the controller. Is node showing other information on serial?
                           Serial.print("Text Message: "); Serial.print(message.sensor); Serial.print(", Message: "); Serial.println(message.getString());
                      In incomingmessage routing add a print statement to show which messages are coming in (see above).
                        I've change this line with "!=" and it work. but i dont undestand why....?
                            if (message.type!=V_TEXT) {                         // Text messages only
                          AWIA
                          AWIA
                          AWI
                          @Marc-Olivier-Chaubet A closer look at what happens on you seria outputl:
                          0_1476200021647_upload-770a6b42-dfb9-43dc-b647-0957e02cc9b8
                          • on the first 2 lines there are 2 requests for values from your controller. The "t=47' indicates that the type is V_TEXT.
                          • on the the third line you receive a value with payload "test". however the 't=16' indicates that this is a V_TRIPPED value. (see Serial Protocol).
                          So there is something completely wrong. What is your controller and does it show the right types of sensors?
                          • Q Qu3Uk
                            @NiklasO
                            Here is it.
                            //#define MY_DEBUG
                            // LCD includes
                            #include <Wire.h>
                            // MYS includes
                            void before() {
                              lcd.begin ();
                              lcd.backlight();
                              text.trim();
                                  text.remove(20);
                              // Clear the line
                              // Set Line
                              lcd.print(text);
                            user1306U
                            user1306U
                            user1306
                            @Qu3Uk
                            thank you very much for sharing your code.
                            sorry this might be simple but i'm not sure how do you send text to the display? How do you update V_VAR1 in domoticz?
                            thanks
                            • NiklasON
                              NiklasON
                              NiklasO
                              #34
                              This is my test code. Not optimized, just testing. I have just started to play with arduino (got my first ever this month) so I can't say I know what I am doing. ;) Made som changes in the code below, not tested yet. It compiles, guess that's good. ;)
                              I have commented out stuff related to line1 because that is always showing the time and date, in code, from GW/controller. Enable if you want to control all 4 lines from Domoticz.
                              Update display by using the domoticz api:
                              json.htm?type=command&param=udevice&idx=XXXX&nvalue=0&svalue=Banana
                              Replace XXXX with the IDX for each of the 3 lines. You'll see it when adding the 3 text devices in Domoticz. Then use the Event-system in Domoticz to add Lua-script to update the display as example in this thread.
                              //Credits: https://forum.mysensors.org/topic/1957/lcd-clock-and-text-sensor-node-with-new-v_text
                              //Soft signing.
                              //#define MY_SIGNING_SOFT
                              //#define MY_SIGNING_REQUEST_SIGNATURES
                              //#define MY_SIGNING_SOFT_RANDOMSEED_PIN 7
                              #include <TimeLib.h>
                              #include <Wire.h>
                              //char lastLCD1[21] = "Line1"; //Line 1 always showing current time
                              char lastLCD2[21] = "Line2";
                              char lastLCD3[21] = "Line3";
                              char lastLCD4[21] = "Line4";
                              //20 whitespace characters used to clear your LCD line before printing to it.
                              //Change to fit your LCD. Don't forget to change number of chars in the writeScreen function if needed.
                              unsigned long lastUpdate = 0, lastRequest = 0, lastDisplay = 0;
                              //const byte LCD1_CHILD = 1;                          // Child ID for LCD line 1
                              const byte LCD2_CHILD = 2;                          // Child ID for LCD line 2
                              const byte LCD3_CHILD = 3;                          // Child ID for LCD line 3
                              const byte LCD4_CHILD = 4;                          // Child ID for LCD line 4
                              // Initialize display. Google the correct settings for your display.
                              // The follwoing setting should work for the recommended display in the MySensors "shop".
                              void before() {
                                Wire.begin();                                       // I2C.
                                lcd.begin(20, 4);                                   // LCD with 20 chars, 4 lines.
                                lcd.setBacklight(HIGH);                             // Make sure backlight is on.
                                writeScreen(0, "Waiting for GW...");                // Print initial text before contact with GW.
                              void setup(void)
                                Serial.begin(115200);                               // Start serial.
                                requestTime();                                      // Request time from controller.
                              void presentation()  {
                                sendSketchInfo("Domoticz LCD", "1.0");                    // Send the sketch version information to the gateway and Controller
                                //present(LCD1_CHILD, S_INFO, "LCD_line1");
                                //wait(500);
                                wait(500);
                                present(LCD3_CHILD, S_INFO, "LCD_line3");
                                wait(500);
                                present(LCD4_CHILD, S_INFO, "LCD_line4");
                                wait(500);
                                //send(textMsg.setSensor(LCD1_CHILD).set("-"));      // initialize the V_TEXT at controller for sensor to none (trick for Domoticz)
                                send(textMsg.setSensor(LCD3_CHILD).set("-"));
                                send(textMsg.setSensor(LCD4_CHILD).set("-"));
                              void loop()     {
                                if ((!timeReceived && (now - lastRequest > 10 * 1000)) ||
                                    (now - lastRequest > 3600000UL)) {              // request update from GW every hour to keep in sync
                                  Serial.println("Requesting time...");
                                  requestTime();
                                  lastRequest = now;
                                // Update sensors every 5 seconds
                                if (now - lastDisplay > 5000) {
                                  lastDisplay = now;
                                  //request(LCD1_CHILD, V_TEXT, 0);                  // request new values from controller
                                  request(LCD2_CHILD, V_TEXT, 0);                  // request new values from controller
                                  request(LCD3_CHILD, V_TEXT, 0);                  // request new values from controller
                                  request(LCD4_CHILD, V_TEXT, 0);                  // request new values from controller
                                // Update LCD time every second
                                if (now - lastUpdate > 1000) {
                                  LCD_time();
                                  lastUpdate = now;
                                if (message.type == V_TEXT) {                       // Text messages only
                                  Serial.print("Message: "); Serial.print(message.sensor); Serial.print(", Message: "); Serial.println(message.getString());     // Write some debug info
                                  //if (message.sensor == LCD1_CHILD) {
                                  //  writeScreen(0, message.data);
                              // Don't forget to change "if" to "else if" when controlling all 4 lines:
                                  if (message.sensor == LCD2_CHILD) {
                                  else if (message.sensor == LCD3_CHILD) {
                                  else if (message.sensor == LCD4_CHILD) {
                              void receiveTime(unsigned long ts) {
                                setTime(ts);
                              void LCD_time(void) {
                                if (timeReceived) {
                                  lcd.print(year());
                                  lcd.print("-");
                                  printDigits(month());
                                  lcd.print("-");
                                  printDigits(day());
                                  lcd.print("     ");
                                  printDigits(hour());
                                  lcd.print(":");
                                  printDigits(minute());
                                } else {
                                  writeScreen(0, "Waiting for time...");
                              void printDigits(int digits) {
                              //add leading 0 if digit = 0-9
                                if (digits < 10)
                                  lcd.print('0');
                                lcd.print(digits);
                                if (text.length() > 19)
                                  text.remove(20);
                                // Clear the line
                                // Set Line
                                lcd.print(text);
                              • user1306U user1306
                                @Qu3Uk
                                thanks
                                AWIA
                                AWIA
                                AWI
                                @user1306 V_VAR1 in Domoticz can not be updated or changed in Domotics (Blockly/ Lua/ Json, etc.). It's can only be used to store and retrieve values from MySensors. You should use V_TEXT as in the original example.
                                • user1306U
                                  user1306U
                                  user1306
                                  thanks guy for the help,
                                  what i'm trying to do, is send text to the display (16x2) using both lines (dont really need the time on top), and attach a 4 button keypad on it. then have these buttons sends commands (on.off) to Domoticz which will trigger Event and send that data/text back to the display.
                                  if i manage to figure it out i'll post my code.
                                  • AndurilA
                                    AndurilA
                                    Anduril
                                    Is there a limitation in text length? I plan to use a bigger display and want to maybe send strings with 30+ chars. Is it impossible (maybe then split this into two strings) or is it internally seperated in 2 messages (as nrf-payload is 32 byte - 7 byte MySensors-header)?
                                    • AndurilA Anduril
                                      AWIA
                                      AWIA
                                      AWI
                                      @Anduril The text length is limited to the maximum payload size. So I guess you need to do some tweaking ;)
                                      sellierS 1 Reply Last reply
                                      • AWIA AWI
                                        sellierS
                                        sellierS
                                        sellier
                                        Re: LCD Clock and Text sensor node with new V_TEXT
                                        Hello ,
                                        I have done the same exercise also with the LCD 4*20 and use the same program. It is great.
                                        It works but only I have the first line with the date.
                                        The lines 2,3,4 are empty.
                                        In Domoticz my V_TEXT are created and filled in.
                                        It seems that I can not read correctly the information LCD_line2, LCD_line3,LCD_line4
                                        we can see that on the line READ , the text is V_TEXT but nothing is received.
                                        Why ?
