  3. a little programming help please.
13 Posts 3 Posters 4.6k Views 1 Watching
  • M Offline
    M Offline
    mvader
    I can write some pretty good *nix shell scripts and windows scripts. but don't know any C programming.
    I'm trying to write a for loop but can't seem to get it to work, the issue is the variables i want to use.
    something like this
    var1 = 123
    var2 = 456
    var3 = 789
    setup
    loop
    for X blah blah
    myaction(varX)
    where varX is = to the var 1 2 or 3 above.
    is something like that possible with arduino code or am i barking up the wrong tree?
    thanks
    • S Offline
      soward
      Sounds like you might want to use an array. Something like :
       int myVars[] = { 123,456,789 };
       for (int i = 0; i < (sizeof(myVars)/sizeof(int)) ; i++) {
           Serial.println(myVars[i]);
      should work, though depending on exactly what you want to accomplish, and what controller you are using, etc. there might be some better approach.
      • M Offline
        M Offline
        mvader
        thanks for looking at this for me.
        I gave your suggestion a try, i'm still having issues
        char* outlet[]={"0","1111111","2222222","3333333"};
        where S = to one of the elements in the array
        Serial.println(outlet[(S)]); <-- this works
        mySwitch.send(outlet[(S)], 24); <-- this errors
        error: invalid conversion from 'char*' to 'long unsigned int' [-fpermissive]
        why does it print, but not put that same value in the next command?
        I want it to work like this
        myswitch.send (VALUE of the element in the arra,24);
        how do i get that value in there?
        A S 2 Replies Last reply
        • M mvader
          A Offline
          A Offline
          AWI
          @mvader
          You are using a "setter" for a float value (or pointer) see API
          // Setters for payload
          MyMessage& set(void* payload, uint8_t length);
          MyMessage& set(const char* value);
          MyMessage& set(uint8_t value);
          MyMessage& set(float value, uint8_t decimals);
          MyMessage& set(unsigned long value);
          MyMessage& set(long value);
          MyMessage& set(unsigned int value);
          MyMessage& set(int value);
          • M Offline
            M Offline
            mvader
            so the value of S is a number it's the sensor ID # that my vera has assigned to my outlets
            when i click "ON" in vera, it will send (if say outlet 3) S will then equal 3
            i then want to send out the code that is assigned to outlet 3
            i was using an array to store them, but i would be fine defining outlet1= outlet2= etc
            either way when i get to the function as the bottom
            i want the code to show outlet(S) S being the outlet, but outlet(S) should = 1111641 and that is what code i want sent out
            i can't seem to figure out how to make that happen
            in a shell script i can just do outlet$S and then that = outlet3 (the value of)
            can you do that in arduino/C ?
            #include <RCSwitch.h>
            #define RF433_CHILD_ID 0
            #define NUMBER_OF_OUTLETS 4
            #define char* outlet[]={"0","1119683","1111641","1114582"};
            RCSwitch mySwitch = RCSwitch();
            mySwitch.enableTransmit(2);
            Serial.begin(115200);
            gw.sendSketchInfo("RF433C", "1.0");
            for(int i=0; i<NUMBER_OF_OUTLETS;i++)
            gw.present(i+1, S_LIGHT);
              gw.process();
              if (message.type==V_LIGHT) {
              int incomingLightState =  message.getBool();
              int S = message.sensor;
             if (incomingLightState==1)
            • M mvader
              soward
              Maybe you could post your entire sketch here?
              M 1 Reply Last reply
              • S soward
                M Offline
                M Offline
                mvader
                that is my entire sketch (above your post) lol
                i have not been able to get any further
                A 1 Reply Last reply
                • M mvader
                  A Offline
                  A Offline
                  AWI
                  @mvader
                  I don't know what you are trying to accomplish but RCSwtich.send expects either a character array (= implicit pointer) or an "unsigned long" Code with a length value. I does not have anything to do with MySensors. It is probably easier for you to browse through the RCSwitch examples before combining it with the MySensors API (which has similar characteristics..
                  Below the RCSwitch definitions.
                  void send(unsigned long Code, unsigned int length);
                  void send(char* Code);
                  • M Offline
                    M Offline
                    mvader
                    wrote on last edited by mvader
                    @AWI
                    i'm confused why you say it doesn't have anything to do with mysensors.
                    i have a working sketch that controls 433 outlets on my - mysensors network
                    the issue i have is i'm trying to shorten the sketch.
                    the way it is written now, it defines an on and off code for each outlet
                    if you have many outlets that's allot of "IF" statements.
                    in the shell script world i could easily shorten that by using a variable and for loop.
                    as admitted i'm a scripter and know little about c/arduino programming
                    here is a modified working sketch
                    /*  RF433Mhz Transmitter node:
                        This sketch allows On-Off-Keying (OOK) control of four 433Mhz relay outlets
                        which utilize the common PT2262 encoding chip for signal transmission. The sketch could
                        be easily expanded to include additional outlets.  The sensor node consists of a nano
                        connected to a NRF24L01 and a 433Mhz transmitter connected to pin 3, 5V and Gnd.  The
                        transmitter can run off of 3.3V as well.
                        The sketch is based on the MySensors project (http://www.mysensors.org).
                        Submitted by Dwalt.
                    //  Include related libraries
                    //  Define Constants
                    #define NUMBER_OF_OUTLETS 4 // Each outlet will have 2 OOK codes
                    //#define SEND_DATA 2
                    #define CODE_1On 1119683
                    #define CODE_1Off 1119692
                    #define CODE_2On 6287580
                    #define CODE_2Off 6287572
                    #define CODE_3On 6287578
                    #define CODE_3Off 6287570
                    #define CODE_4On 6287577
                    #define CODE_4Off 6287569
                     Serial.begin(115200); // Not sure why this was included
                     //  The node is mains powered, so why not make it a repeater.
                     // Send the sketch version information to gateway
                     gw.sendSketchInfo("RF433", "1.1");
                     // Register outlets to gw (they will be created as child devices)
                     for(int i=0; i<NUMBER_OF_OUTLETS;i++) {
                      gw.process();
                      int incomingOutlet = message.sensor;
                      Serial.print("Outlet #: ");
                      Serial.println(message.sensor);
                      Serial.print("Command: ");
                     if (incomingOutlet==1) {
                     if (incomingLightState==1) {
                        // Turn on  socket 1
                        Serial.println("Turn on Socket 1");
                     mySwitch.send(CODE_1On, 24); // These codes are unique to each outlet
                     delay(50);
                     if (incomingLightState==0)  {
                        // Turn off socket 1
                     Serial.println("Turn off Socket 1");
                    mySwitch.send(CODE_1Off, 24);
                    delay(50);
                     if (incomingOutlet==2) {
                        // Turn on  socket 2
                        Serial.println("Turn on Socket 2");
                    mySwitch.send(CODE_2On, 24);
                     delay(50);
                        // Turn off socket 2
                     Serial.println("Turn off Socket 2");
                    mySwitch.send(CODE_2Off, 24);
                    delay(50);
                     if (incomingOutlet==3) {
                        // Turn on  socket 3
                        Serial.println("Turn on Socket 3");
                    mySwitch.send(CODE_3On, 24);
                     delay(50);
                        // Turn off socket 3
                     Serial.println("Turn off Socket 3");
                    mySwitch.send(CODE_3Off, 24);
                    delay(50);
                     if (incomingOutlet==4) {
                        // Turn on  socket 4
                        Serial.println("Turn on Socket 4");
                     mySwitch.send(CODE_4On, 24);
                     delay(50);
                        // Turn off socket 4
                     Serial.println("Turn off Socket 4");
                    mySwitch.send(CODE_4Off, 24);
                    delay(50);
                     delay(50);
                    • M mvader
                      @AWI
                          Submitted by Dwalt.
                      //  Define Constants
                        gw.process();
                          // Turn on  socket 1
                       delay(50);
                      delay(50);
                          // Turn on  socket 2
                       delay(50);
                      delay(50);
                          // Turn on  socket 3
                       delay(50);
                      delay(50);
                          // Turn on  socket 4
                       delay(50);
                      delay(50);
                       delay(50);
                      A Offline
                      A Offline
                      AWI
                      wrote on last edited by AWI
                      @mvader If you look at the similar statement in this sketch:
                      (better written as:)
                      const int CODE_1On = 1119683   // define integer with value
                      CODE_10n is an Integer "type"
                      In the other sketch you are using "outlet[(S)]" which is a char array (or pointer) type.
                      const char outlet[] = {"0","1119683","1111641","1114582"};   // define an array with character arrays
                      While the mySwitch.send( .. ) either wants a character array ("ABCDEF12121") or an integer with length (12234, 24)
                      C++ does not automatically convert types...
                      • M Offline
                        M Offline
                        mvader
                        I must still be missing something.
                        appreciate the correction on the declared part.
                        however, i still don't know how to make outlet(S) (where S is the outlet number)
                        work.
                        i constantly get a "outlet" is not defined.. etc
                        outlet is not specifically defined, but i'm not trying to send just "outlet"
                        i'm trying to send the value of outlet3
                        the variable S is supposed to represent the 3 (or whatever other outlet # is sent back by vera)
                        this allows me to use 1 piece of code, instead of saying
                        if outlet 1
                        if outlet 2
                        if outlet 3
                        etc
                        i can just say outlet(S)
                        but that' isn't working. why? not possible or not coded correctly?
                        • M mvader
                          work.
                          if outlet 1
                          if outlet 2
                          if outlet 3
                          etc
                          A Offline
                          A Offline
                          AWI
                          @mvader sorry for confusing you.. try this:
                          const unsigned long outlet[]= {0,1119683,1111641,1114582};
                          i.s.o.
                          • M Offline
                            M Offline
                            mvader
                            I think that may have done the trick.. i'll follow up in a bit
                            thanks!
