  3. How Can I Add the NRF24L01 ratio to the 2-wire Temp Probe Sketch
5 Posts 2 Posters 2.5k Views 1 Watching
  • N
    N
    Newzwaver
    How do I add the radio sketch to this simple sketch?
    // SPI Pins
    #define CE_PIN 9
    #define CS_PIN 10
    // Wait times
    #define LONG_WAIT 500
    #define SHORT_WAIT 50
    #define SKETCH_NAME "2 Wire Temp Probe"
    #define SKETCH_VERSION "v0.1"// which analog pin to connect
    #define ID_S_TEMP 007
    #define THERMISTORPIN A0
    // resistance at 25 degrees C
    #define THERMISTORNOMINAL 10000
    // temp. for nominal resistance (almost always 25 C)
    #define TEMPERATURENOMINAL 25
    // how many samples to take and average, more takes longer
    // but is more 'smooth'
    #define NUMSAMPLES 5
    // The beta coefficient of the thermistor (usually 3000-4000)
    #define BCOEFFICIENT 3950
    // the value of the 'other' resistor
    #define SERIESRESISTOR 10000
    // Global Vars
    unsigned long SLEEP_TIME = 12000; // Sleep time between reads (in milliseconds)
    boolean metric = true;
    long randNumber;
    // Instanciate MySersors Gateway
    #ifdef ID_S_TEMP
    MyMessage msg_S_TEMP(ID_S_TEMP,V_TEMP);
    #ifdef ID_S_DISTANCE
    MyMessage msg_S_DISTANCE(ID_S_DISTANCE,V_DISTANCE);
    int samples[NUMSAMPLES];
    void setup(void) {
    Serial.begin(9600);
    analogReference(EXTERNAL);
    void loop(void) {
    uint8_t i;
    float average;
    // take N samples in a row, with a slight delay
    for (i=0; i< NUMSAMPLES; i++) {
    samples[i] = analogRead(THERMISTORPIN);
    delay(10);
    // average all the samples out
    average = 0;
    average += samples[i];
    average /= NUMSAMPLES;
    Serial.print("Average analog reading ");
    Serial.println(average);
    // convert the value to resistance
    average = 1023 / average - 1;
    average = SERIESRESISTOR / average;
    Serial.print("Thermistor resistance ");
    float steinhart;
    steinhart = average / THERMISTORNOMINAL; // (R/Ro)
    steinhart = log(steinhart); // ln(R/Ro)
    steinhart /= BCOEFFICIENT; // 1/B * ln(R/Ro)
    steinhart += 1.0 / (TEMPERATURENOMINAL + 273.15); // + (1/To)
    steinhart = 1.0 / steinhart; // Invert
    steinhart -= 258.95; // convert to C
    Serial.print("Temperature ");
    Serial.print(steinhart);
    Serial.println(" *C");
    delay(1000);
    • F
      F
      fleinze
      To initialize the radio and the sensor (in setup):
      gw.begin();
      gw.sendSketchInfo("2-Wire Temperature Sensor", "1.0");
      gw.present(ID_S_TEMP, S_TEMP);//child ID 0
      to send the temperature (in loop):
      gw.send(msg.setSensor(ID_S_TEMP).set(temperature, 1));
      to save energy use gw.sleep(sleeptime) instead of delay(sleeptime).
      How do you wire the sensors? What do you wire on the external reference pin?
      • N
        N
        Newzwaver
        Hi Fleinze, thanks for the help. I am using A0 for the pin and I decided to rebuild the Dallas temp sketch, I can compile it and the radio looks like it is communicating, I just can get it to register as a sensor in vera. Any ideas?
        NEW Sketch
        #include <OneWire.h>
        #define ONE_WIRE_BUS A0 // Pin where sensor is connected
        #define ID_S_TEMP 97
        int numSensors=A0;
        MyMessage msg(A0,V_TEMP);
        void setup(void) {
        Serial.begin(115200);
        sensors.begin();
        gw.begin();
        gw.sendSketchInfo("Temperature Sensor", "1.1");
        for (int i=A0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) {
        gw.present(i, S_TEMP);
        void loop(void) {
        gw.process();
        // Fetch temperatures from sensor
        gw.sleep(conversionTime);
        uint8_t i;
        float average;
        delay(10);
        average = 0;
        float temperature;
        temperature = average / THERMISTORNOMINAL; // (R/Ro)
        temperature = log(temperature); // ln(R/Ro)
        temperature /= BCOEFFICIENT; // 1/B * ln(R/Ro)
        temperature += 1.0 / (TEMPERATURENOMINAL + 273.15); // + (1/To)
        temperature = 1.0 / temperature; // Invert
        temperature -= 258.95; // convert to C
        Serial.print(temperature);
        // delay(1000);
        gw.sleep(SLEEP_TIME);
        send: 254-254-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
        send: 254-254-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
        read: 0-0-254 s=255,c=3,t=6,pt=0,l=1,sg=0:M
        read: 0-0-254 s=255,c=3,t=1,pt=0,l=10,sg=0:1442404204
        sensor started, id=254, parent=0, distance=1
        send: 254-254-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,st=ok:Temperature Sensor
        send: 254-254-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
        Average analog reading 706.00
        Thermistor resistance 22271.30
        Temperature 22.21 *C
        send: 254-254-0-0 s=5,c=1,t=0,pt=7,l=5,sg=0,st=ok:22.2
        Average analog reading 707.00
        Thermistor resistance 22373.42
        Temperature 22.12 *C
        send: 254-254-0-0 s=5,c=1,t=0,pt=7,l=5,sg=0,st=ok:22.1
        Average analog reading 707.20
        Thermistor resistance 22393.92
        Temperature 22.10 *C
        Average analog reading 708.00
        Thermistor resistance 22476.19
        Temperature 22.02 *C
        send: 254-254-0-0 s=5,c=1,t=0,pt=7,l=5,sg=0,st=ok:22.0
        Average analog reading 709.00
        Thermistor resistance 22579.62
        Temperature 21.93 *C
        So the value that sends is rounded 21.93C = 22 and it looks like it sent that. I just cant figure out how the vera will pick it up.
        Any ideas?
        • F
          F
          fleinze
          Hi @Newzwaver!
          please consider using using the code-feature of the forum, because it makes the code much more readable.
          You still had a lot of code from the dallastemp-example in your code which is not needed in you case. I tried to clean it up for you, but I did
          const unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
          MyMessage msg(0,V_TEMP);
          void setup(void) {
            pinMode(THERMISTORPIN, INPUT);
            gw.begin();
            gw.present(0, S_TEMP);
          void loop(void) {
            gw.process();
            float average;
            for (uint8_t i=0; i< NUMSAMPLES; i++) {
              delay(10);
            average = 0;
            float temperature;
            gw.send(msg.setSensor(0).set(temperature,1));
            // delay(1000);
          The original sketch is programmed to present a number of sensors, hence the for loop before gw.present(). You need just one sensor so you can present it at any child-ID (i.e. child-ID 0). The way the for loop was written, gw.present() was never executed. Also when sending the data you sent it as child-ID i. i was set in the last for-loop to 5.
          Try this, it should work.
          • N
            N
            Newzwaver
            Thank you very much worked great, I have the probe in my deep freeze ... If something goes wrong I get a notification. No more spoiled food. Thank you very much, it was very well appreciated..
