  3. My Slim 2AA Battery Node
498 Posts 71 Posters 604.5k Views 69 Watching
  • A
    A
    ar91
    Very nice design. Any video on installation of bootloader with various settings described in the original post?.
    m26872M 1 Reply Last reply
    • A ar91
      m26872M
      m26872M
      m26872
      #42
      @ar91 Thx. Sorry no. I don't know of any and I'm too shy to do it myself.
      • ahmedadelhosniA
        ahmedadelhosniA
        ahmedadelhosni
        Great idea using this housing.
        Why didn't you use CR batteries to decrease size ?
        http://www.digikey.com/product-detail/en/CR1220/P033-ND/269740
          2AA batteries have approximately 2000mAh capacity. CR1220 has 35mAh. So for the same capacity, more than 50 CR1220 would be needed. That wouldn't save space :)
          But CR1220 has lower self-discharge so they can be a good alternative for things that are really low-power, or don't need long battery life.
          • ahmedadelhosniA ahmedadelhosni
            m26872M
            m26872M
            m26872
            #45
            @ahmedadelhosni I've read a few reports from people with radio module issues after some time on CR "coin cell" batteries. The expected battery life time then doesn't match the result. I think you can find references by searching.
              martkrui
              m26872, I just wanted to say thank you for your work on this project and for sharing it with everybody. :+1:
              I've just ordered the ATMEGAs to build 5 nodes.
              How confident are you about the V1.4 PCB ? If you don't see any issue with them at this point I think I'll take the whopping $14 risk :yum:
              • ahmedadelhosniA
                ahmedadelhosniA
                ahmedadelhosni
                wrote on last edited by ahmedadelhosni
                #47
                Aha..now I understood the reason. Thanks
                • M martkrui
                  m26872M
                  m26872M
                  m26872
                  #48
                  @martkrui I'm not confident until I've tested one, but usually errors can be fixed with some ugly mods if necessary. ;-)
                  BTW I added to the info that any/every DirtyPCB money from this share will be donated to MySensors.org.
                  • B
                    B
                    betonishard
                    Like the board and ordered it. Can you also post exactly the capacitor types? Keep up the good work.
                      martkrui
                      wrote on last edited by martkrui
                      #50
                      I also ordered the PCBs (at my own risk) and some of "TMK-T20 20mm 17mm"
                      I'll try to CNC or 3Dprint some endcaps or something.
                      • B betonishard
                        m26872M
                        m26872M
                        m26872
                        @betonishard There aren't any exact values or types, but good start would be
                        Near the radio supply: One radial electrolytic >=4.7uF >=10V capacitor together with one ceramic (range 1pF - 1uF. I use different.).
                        The rest (C1, C2, C3): 0.1uF ceramic, where the value probably matters most for C2 (the Reset capacitor)
                        B 1 Reply Last reply
                        • m26872M m26872
                          B
                          B
                          betonishard
                          @m26872
                          Thanks... Maybe it is answered, but I didn't quite catch it. 3v will be fed to the radio, but isn't the 3.3 important instead of 3v? I don't see any stepup. Is your range acceptible?
                          Thanks...
                            The radio can handle as low as 1.9V (source)
                            • GertSandersG
                              GertSandersG
                              GertSanders
                              I have had a node sending messages as low as 1.65V :-)
                              • B
                                B
                                betonishard
                                @mfalkvidd @GertSanders Thanks for your answers!! How about the range, I know it is depending on the quality of Chinese products, however can you give an estimate regarding your setups?
                                  Short answer: Expect about the same range as a regular wifi card.
                                  Long answer: Look at these informative and quite entertaining videos:
                                  Ultimate nRF24L01 range comparison
                                  nRF24L01 range test (arduino)
                                  nRF24L01 range test part 2 (arduino)
                                  • A
                                    A
                                    ar91
                                    I was about to order the 1.4v of your board before that i wanted to ask you a basic question, do i need to use any step up regulator to connect any 5v sensors? Have you connected any 5v sensors, if yes could you please post some pictures?
                                    Thanks again for the great work.
                                    • GertSandersG
                                      GertSandersG
                                      GertSanders
                                      You will indeed need to use a step-up regulator to use 5V sensors, as his board is 2AA battery based (gives maximum 3.2V on fresh batteries). For quite some sensors, you will find 3V3 versions, which can work at even lower voltages. look for sensors which work down to 1.8V-1.9V
                                      Using 5V sensors in a battery based node is not efficient.
                                      A 1 Reply Last reply
                                      • GertSandersG GertSanders
                                        A
                                        A
                                        ar91
                                        @GertSanders Thank you so much. Is there a recommended list of low voltage sensors? The Mysensor store only has 5v sensors i believe. I will other search other forum post as well. If anyone know from top of their head please list it.
                                        Temperature sensor - ?
                                        Humidity sensor - ?
                                        Luminosity sensor - ?
                                        PIR - ?
                                        Infrared sensor -?
                                        Soil Moisture sesnor -?
                                        • Cliff KarlssonC
                                          Cliff KarlssonC
                                          Cliff Karlsson
                                          I also was about to order the 1.4 board. But are there any list of components that I need to complete the board?
