  3. My Slim 2AA Battery Node
498 Posts 71 Posters 599.8k Views 69 Watching
  • ahmedadelhosniA
    ahmedadelhosniA
    ahmedadelhosni
    wrote on last edited by ahmedadelhosni
    #47
    Aha..now I understood the reason. Thanks
    • M martkrui
      m26872, I just wanted to say thank you for your work on this project and for sharing it with everybody. :+1:
      I've just ordered the ATMEGAs to build 5 nodes.
      How confident are you about the V1.4 PCB ? If you don't see any issue with them at this point I think I'll take the whopping $14 risk :yum:
      m26872M
      m26872M
      m26872
      wrote on last edited by m26872
      #48
      @martkrui I'm not confident until I've tested one, but usually errors can be fixed with some ugly mods if necessary. ;-)
      BTW I added to the info that any/every DirtyPCB money from this share will be donated to MySensors.org.
      • B
        B
        betonishard
        Like the board and ordered it. Can you also post exactly the capacitor types? Keep up the good work.
        m26872M 1 Reply Last reply
          martkrui
          wrote on last edited by martkrui
          #50
          I also ordered the PCBs (at my own risk) and some of "TMK-T20 20mm 17mm"
          I'll try to CNC or 3Dprint some endcaps or something.
          • B betonishard
            m26872M
            m26872M
            m26872
            @betonishard There aren't any exact values or types, but good start would be
            Near the radio supply: One radial electrolytic >=4.7uF >=10V capacitor together with one ceramic (range 1pF - 1uF. I use different.).
            The rest (C1, C2, C3): 0.1uF ceramic, where the value probably matters most for C2 (the Reset capacitor)
            B 1 Reply Last reply
            • m26872M m26872
              B
              B
              betonishard
              @m26872
              Thanks... Maybe it is answered, but I didn't quite catch it. 3v will be fed to the radio, but isn't the 3.3 important instead of 3v? I don't see any stepup. Is your range acceptible?
              Thanks...
              • mfalkviddM
                The radio can handle as low as 1.9V (source)
                • GertSandersG
                  GertSandersG
                  GertSanders
                  I have had a node sending messages as low as 1.65V :-)
                  • B
                    B
                    betonishard
                    @mfalkvidd @GertSanders Thanks for your answers!! How about the range, I know it is depending on the quality of Chinese products, however can you give an estimate regarding your setups?
                    • mfalkviddM
                      Short answer: Expect about the same range as a regular wifi card.
                      Long answer: Look at these informative and quite entertaining videos:
                      Ultimate nRF24L01 range comparison
                      nRF24L01 range test (arduino)
                      nRF24L01 range test part 2 (arduino)
                      • A
                        ar91
                        I was about to order the 1.4v of your board before that i wanted to ask you a basic question, do i need to use any step up regulator to connect any 5v sensors? Have you connected any 5v sensors, if yes could you please post some pictures?
                        Thanks again for the great work.
                        • GertSandersG
                          GertSandersG
                          GertSanders
                          You will indeed need to use a step-up regulator to use 5V sensors, as his board is 2AA battery based (gives maximum 3.2V on fresh batteries). For quite some sensors, you will find 3V3 versions, which can work at even lower voltages. look for sensors which work down to 1.8V-1.9V
                          Using 5V sensors in a battery based node is not efficient.
                          A 1 Reply Last reply
                          • GertSandersG GertSanders
                            ar91
                            @GertSanders Thank you so much. Is there a recommended list of low voltage sensors? The Mysensor store only has 5v sensors i believe. I will other search other forum post as well. If anyone know from top of their head please list it.
                            Temperature sensor - ?
                            Humidity sensor - ?
                            Luminosity sensor - ?
                            PIR - ?
                            Infrared sensor -?
                            Soil Moisture sesnor -?
                            • Cliff KarlssonC
                              Cliff KarlssonC
                              Cliff Karlsson
                              I also was about to order the 1.4 board. But are there any list of components that I need to complete the board?
                                m26872M
                                m26872M
                                m26872
                                @Cliff-Karlsson Sorry for late reply. I've not yet a BOM. I'll try o fix it later.
                                • m26872M
                                  m26872M
                                  m26872
                                  #62
                                  NEWS:
                                  • A "final" version 2.0 redesigned i KiCad (very similar layout), panelized, ordered and tested OK.
                                  • A faulty via was introduced during panelization of v1.2, so the panelized v1.2 (blue board) needs a small fix to work.
                                  More info ASAP.
                                  Edit 4/11: There seems to be no issues with v1.4 (red board) as I thought first. Luckily since it's now been shared a few times.
                                  AWIA 1 Reply Last reply
                                  • m26872M m26872
                                    NEWS:
                                    More info ASAP.
                                    AWIA
                                    AWIA
                                    AWI
                                    @m26872 I received the boards yesterday. Can you direct me to the fix needed.?
                                    • AWIA AWI
                                      m26872M
                                      m26872M
                                      m26872
                                      @AWI It should be easy the see the via with a missing hole. A connecting wire between Arduino D13 and nRF SCK is needed.
                                      • m26872M m26872
                                        AWIA
                                        AWIA
                                        AWI
                                        @m26872 Tnhx, however my samples seems to be correct...
                                        upload-703db10b-132e-423d-bb85-1903bc043352
                                        • AWIA AWI
                                          m26872M
                                          m26872M
                                          m26872
                                          #66
                                          @AWI Mine too. I didn't see the red v1.4 until I got it today. Looks promising, but I've not tested it yet. Interesting to see that they've done a different panelizing.
