  3. My Slim 2AA Battery Node
498 Posts 71 Posters 599.8k Views 69 Watching
    @m26872
    200pcs!! What the heck are you up to?
    m26872M 1 Reply Last reply
    • m26872M m26872
      @AWI Great idea with the strips! And thanks for verifying (v1.2?).
      AWIA
      AWIA
      AWI
      @m26872 I think I used version 1.1? Did you change any of the wiring in the newer versions?
        @m26872
        m26872M
        m26872M
        m26872
        @hek
        hehe, I had a hunch it'd be spectacular. Let's just say that I aim to have a few single sensor/purpose sleeping nodes, but probably not 200. At least not in a while.
        • AWIA AWI
          m26872M
          m26872M
          m26872
          @AWI Ops sorry, I meant v1.0. I see the larger pads in your pics. The routing is a little different to 1.2 and 1.4. Mostly related components under the uC.
          • A
            ar91
            Very nice design. Any video on installation of bootloader with various settings described in the original post?.
            • A ar91
              m26872M
              m26872M
              m26872
              wrote on last edited by m26872
              #42
              @ar91 Thx. Sorry no. I don't know of any and I'm too shy to do it myself.
              • ahmedadelhosniA
                ahmedadelhosniA
                ahmedadelhosni
                Great idea using this housing.
                Why didn't you use CR batteries to decrease size ?
                http://www.digikey.com/product-detail/en/CR1220/P033-ND/269740
                • mfalkviddM
                  2AA batteries have approximately 2000mAh capacity. CR1220 has 35mAh. So for the same capacity, more than 50 CR1220 would be needed. That wouldn't save space :)
                  But CR1220 has lower self-discharge so they can be a good alternative for things that are really low-power, or don't need long battery life.
                    m26872M
                    m26872M
                    m26872
                    #45
                    @ahmedadelhosni I've read a few reports from people with radio module issues after some time on CR "coin cell" batteries. The expected battery life time then doesn't match the result. I think you can find references by searching.
                      martkrui
                      m26872, I just wanted to say thank you for your work on this project and for sharing it with everybody. :+1:
                      I've just ordered the ATMEGAs to build 5 nodes.
                      How confident are you about the V1.4 PCB ? If you don't see any issue with them at this point I think I'll take the whopping $14 risk :yum:
                      • ahmedadelhosniA
                        ahmedadelhosniA
                        ahmedadelhosni
                        wrote on last edited by ahmedadelhosni
                        #47
                        Aha..now I understood the reason. Thanks
                        • M martkrui
                          m26872M
                          m26872M
                          m26872
                          #48
                          @martkrui I'm not confident until I've tested one, but usually errors can be fixed with some ugly mods if necessary. ;-)
                          BTW I added to the info that any/every DirtyPCB money from this share will be donated to MySensors.org.
                          • B
                            B
                            betonishard
                            Like the board and ordered it. Can you also post exactly the capacitor types? Keep up the good work.
                              martkrui
                              wrote on last edited by martkrui
                              #50
                              I also ordered the PCBs (at my own risk) and some of "TMK-T20 20mm 17mm"
                              I'll try to CNC or 3Dprint some endcaps or something.
                              • B betonishard
                                m26872M
                                m26872M
                                m26872
                                @betonishard There aren't any exact values or types, but good start would be
                                Near the radio supply: One radial electrolytic >=4.7uF >=10V capacitor together with one ceramic (range 1pF - 1uF. I use different.).
                                The rest (C1, C2, C3): 0.1uF ceramic, where the value probably matters most for C2 (the Reset capacitor)
                                B 1 Reply Last reply
                                • m26872M m26872
                                  B
                                  B
                                  betonishard
                                  @m26872
                                  Thanks... Maybe it is answered, but I didn't quite catch it. 3v will be fed to the radio, but isn't the 3.3 important instead of 3v? I don't see any stepup. Is your range acceptible?
                                  Thanks...
                                  • mfalkviddM
                                    The radio can handle as low as 1.9V (source)
                                    • GertSandersG
                                      GertSandersG
                                      GertSanders
                                      I have had a node sending messages as low as 1.65V :-)
                                      • B
                                        B
                                        betonishard
                                        @mfalkvidd @GertSanders Thanks for your answers!! How about the range, I know it is depending on the quality of Chinese products, however can you give an estimate regarding your setups?
                                        • mfalkviddM
                                          Short answer: Expect about the same range as a regular wifi card.
                                          Long answer: Look at these informative and quite entertaining videos:
                                          Ultimate nRF24L01 range comparison
                                          nRF24L01 range test (arduino)
                                          nRF24L01 range test part 2 (arduino)
