  3. My sensorboard MYS 1.0beta
121 Posts 44 Posters 114.0k Views 13 Watching
  • M Mrlynx
    I have thought about the spi channel but I cant really understand why the ethernet gateway sketch uses different CE/CS pins for the radio.
    Why cant the radio use pin 9/10 and the ethernet shield 5/6?
    Maybe @hek can shed som light on the matter?
    @Mrlynx
    It was based on an example I received from @a-lurker back in January.
    If it is possible for someone to rework the example using the normal configuration for the radio and ethernet (WizNet and ENJ) on the 5/6 please post an updated EthernetGateway (1.4) and pin configuration in a new forum thread.
    • D
      D
      djdworks
      the CE and CS pin shall be different for each SPI you have connected on SPI bus.
      The pins will act as follows
      CE (chip enable) = with this pin, LOW or HIGH depending on the manufacturer, the SPI bus is connected like a switch to the device, when the device is not "connected to the bus" the pins will be in "high impedance" state. Sometimes CE is already connected with CS and is not available on device pinout.
      CS (chip select) = this pin will enable the communication with the device.
      I hope to have clarified the matter.
      Some devices (like arduino TFT) have the possibility to have a dedicated SPI bus (MOSI MISO SCK CS RST) on any pin.
        Mrlynx
        I have now added a SPI-header (SCK/MOSI/MISO) and a smd footprint for a 24LCXXX flash memory.
        http://www.sa2avr.se
        • M Mrlynx
          marceltrapmanM
          marceltrapmanM
          marceltrapman
          Can you tell me how you wired things up?
          I am looking how to do this but I am not sure.
          Did you test it already?
          Fulltime Servoy Developer
          • marceltrapmanM marceltrapman
            Mrlynx
            @marceltrapman
            No I have not tested it yet.
            I have just followed this exampel http://www.hobbytronics.co.uk/arduino-external-eeprom
            • M Mrlynx
              @marceltrapman
              marceltrapmanM
              marceltrapmanM
              marceltrapman
              wrote on last edited by marceltrapman
              #26
              I now realise that you are using another chip than I am.
                Mrlynx
                Here is the final schematic on version 1.1 mys11.pdf.
                I now have all components and boards for 100 kits on order.
                RJ_MakeR 1 Reply Last reply
                • M Mrlynx
                  RJ_MakeR
                  RJ_MakeR
                  RJ_Make
                  I may have missed it, but are you planing on selling these, and if so how much will you be asking?
                  RJ_Make
                  • RJ_MakeR RJ_Make
                    Mrlynx
                    @ServiceXp Yes I am planning to try to sell these boards as a kit for 7$/kit.
                    It is going to be a diy kit with all components except 24LCxxx eeprom, radio and arduino pro mini.
                    • M Mrlynx
                      RJ_MakeR
                      RJ_MakeR
                      RJ_Make
                      @Mrlynx When do you think they will be available ?
                      RJ_Make
                        Mrlynx
                        @ServiceXp it depends on how soon I get all the components but maybe 4-5 weeks.
                        • DvbitD
                          DvbitD
                          Dvbit
                          Do you pan to is sue also a battery based version?
                          • DvbitD Dvbit
                            Mrlynx
                            @Dvbit this board can be batterypowered but it has no step up module.
                            I am not planning any special battery version at the moment.
                            • C4VetteC
                              C4VetteC
                              C4Vette
                              Can we pre-order? Maybe to help you pay for all this?
                              I would like two please.
                              • M Mrlynx
                                RJ_MakeR
                                RJ_MakeR
                                RJ_Make
                                @Mrlynx I thought it was battery operated, I saw the first pic and that it had battery connections and just assumed... Glad that was pointed out.
                                RJ_Make
                                • jendrushJ jendrush
                                  @Mrlynx said:
                                  nice work.
                                  Thank you. This is only temperature board, but best part of this board is cost.
                                  Piece of PCB ~30 cents,
                                  pins ~30 cents,
                                  power connector ~10 cents,
                                  capacitor+resistor ~ 10 cents,
                                  3.3V regulator ~ 10 cents
                                  :) less than 1$ for complete board, and about 7$ for all parts including radio, arduino mini, wall usb charger, and cables:) This is power of MySensors!
                                  Thank you @Hek, and rest of the team!
                                  Z
                                  Z
                                  Zeph
                                  pins ~30 cents,
                                  Which board are you quoting prices for, jendrush?
                                  jendrushJ 1 Reply Last reply
                                  • Z Zeph
                                    pins ~30 cents,
                                    jendrushJ
                                    jendrushJ
                                    jendrush
                                    Board that i designed, and etched myself:)
                                    • C4VetteC C4Vette
                                      Mrlynx
                                      @C4Vette I am not taking any preorders but they who has shown interest are going to be first in line when they are ready.
                                      More info will come later.
                                      H 1 Reply Last reply
                                      • D
                                        D
                                        Dennis van Velzen
                                        Nice board... Simple and straight forward to implement in our own projects!
                                        I also like to have approx. 5 boards... Please tell me how to order and how you like the payment...
                                        Can you also include the RF24's and Arduino boards? :+1:
                                        M jendrushJ 2 Replies Last reply
                                        • D Dennis van Velzen
                                          Mrlynx
                                          @Dennis-van-Velzen I am not planning to stock radios or arduinos as they are easy to source from internet.
