  3. Domoticz
  4. SenseBender stops reporting data to Domoticz
5 Posts 3 Posters 2.3k Views 1 Watching
  • G Offline
    G Offline
    gravis12
    i have some problems when using domoticz together with an Ethernet gateway and the sensebender micro board. when reprogramming the node it works for some hours. Then suddenly it stops and no more data are reported. In downloaded the MYSController to check the traffic. In this tool I can see that data are sent all the time but still no data are detected by the Domotic server. I am very confused by this behaviour. Any hints on how to overcome this problem?
    /Thomas
    A 1 Reply Last reply
    • G gravis12
      /Thomas
      A Offline
      A Offline
      AWI
      @gravis12 Can you elaborate a little on the kind of data you are expecting in Domoticz? and (or) a serial log of the sensor?
      • G Offline
        G Offline
        gravis12
        I am expecting to see the updated temperature and the updated humidity values. Attached is a picture with the log from the myscontroller beside the log from Domoticz at the same time. As shown the values are received by the Mys controller but no updated data are seen in the log files in Domoticz. Confusing...
        • hekH Offline
          hekH Offline
          Is it normal that is says "RFXcom" in the log for MySensors stuff?
            A Offline
            A Offline
            AWI
            wrote on last edited by AWI
            @hek Nope, it should be MySensors... look at the hardware settings...
            upload-54b0a40e-72c3-4445-accb-3d5b5395c599
