  3. Energy monitor shield
4 Posts 3 Posters 2.8k Views 3 Watching
    maciejka
    Hi Everyone!
    It is possible to implement energy monitor shield for Arduino to mysensors?
    Maybe somebody already tried this or has some experience.
    I want to add this kind of sensor (CT for 3 lines) to domoticz.
    I found 2 kind of solution:
    http://www.seeedstudio.com/wiki/Energy_Monitor_Shield_V0.9b#Simple_demonstration_with_wireless_technology
    and
    http://wiki.openenergymonitor.org/index.php?title=EmonTx_Arduino_Shield#emonTx_Arduino_Shield
    Please write yours comments.
    • TheoLT
      TheoLT
      TheoL
      I'm not sure, but I think that it isn't possible without a lot of code refactoring. They use the same radio as MySensors, but it might be difficult to use one radio for both MySensors and the communication between the different E-mon nodes.
      It might be easier to build a couple of MySensors nodes for harvesting energy usage to your Domotica controller.
      But it's just my first impression I've never used those boards. Other people on this forum might know if it's possible or not.
        This shield should work just fine. Just make sure to set the correct CE/CS (which differs a bit from our "standard") when initialising the MySensors library.
          maciejka
          wrote on last edited by maciejka
          Thank You for your suggestion. I will try with Energy Monitor Shield from Seeedstudio and connect it to MySensors gateway.
