  3. GatewayESP8266MQTTClient in Development Branch
13 Posts 6 Posters 6.6k Views 2 Watching
    Mike Cayouette
    I am starting to do some testing with the GatewayESP8266MQTTClient in the Dev branch. How do we define our own nodeid's. In the past I would do it via begin() in void setup{}. Do we now put begin() in the presentation function?
    Mike
    • G
      G
      gmccarthy
      I'm trying the ENC28J60 branch and am also wondering the same thing. The setup and main functions are empty?
        @Mike-Cayouette
        #define MY_NODE_ID xxx
        But for the gateway this is not needed as they always get id=0
        @gmccarthy
        Unless you want to attach sensors to the gateway itself, you can leave presentation() and setup() empty.
          Mike Cayouette
          @hek Thank you. I should have mentioned I have the gateway working but I was wondering how to define the node id in the clients. In any case, I was coming back here to say I had figured it out.
          I have a temp sensor communicating with the gateway.
          Mike
          • V
            V
            vickey
            @hek Gateway and sensor node never get communicated even after configuring manual ID. Here is arduino debug
            Starting...
            find parent
            send: 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
            find parent
            find parent
            Here is the ESP8266 12E gateway debug
            0;0;3;0;9;Starting...
            scandone
            f 0, ....scandone
            state: 0 -> 2 (b0)
            .state: 2 -> 3 (0)
            state: 3 -> 5 (10)
            add 0
            aid 1
            cnt
            connected with Ahmed, channel 1
            ip:192.168.0.31,mask:255.255.255.0,gw:192.168.0.1
            .IP: 192.168.0.31
            0;0;3;0;9;Attempting MQTT connection...
            0;0;3;0;9;MQTT connected
            • FotoFieberF
              FotoFieberF
              FotoFieber
              There seems to be a bug in incomingMQTT:
              replace
              for (str = strtok_r(topic, "/", &p); str && i < 5;
              with
              for (str = strtok_r(topic, "/", &p); str && i <= 5;
              -> http://forum.mysensors.org/topic/1870/esp8266-wifi-gateway-port-for-mysensors/138
                Ok, created a PR on this.
                https://github.com/mysensors/Arduino/pull/229
                Will just let it run through Jenkins before merging.
                • FotoFieberF
                  FotoFieberF
                  FotoFieber
                  There may be other problems in the code. I switched to ethernet gateway and wrote my own controller in node-red (wip).
                    Mike Cayouette
                    @FotoFieber I switched to ethernet gateway and wrote my own controller in node-red
                    I am attempting the same . For some reason though I cannot get the mysensors ESP8266Gateway to receive data from node-red. I configured a TCP node in node-red with the gateways IP on port 5003. When I connect the serial monitor I can see the client connection established, but when I send data from node-red I get nothing. I am able to telenet to the gateway and in the serial monitor I see the messages I type so I know the gateway can receive, but it does not receive from node-red. How did you get node-red and the gateway to exchange messages?
                    Thank you,
                    Mike
                    FotoFieberF 1 Reply Last reply
                    • M Mike Cayouette
                      Thank you,
                      Mike
                      FotoFieberF
                      FotoFieberF
                      FotoFieber
                      @Mike-Cayouette
                      What kind of tcp node do you use?
                      I use a tcp request node and inject a blank on startup to get the connection opened.
                      • ahmedadelhosniA
                        ahmedadelhosniA
                        ahmedadelhosni
                        wrote on last edited by ahmedadelhosni
                        This reply is related to another topic http://forum.mysensors.org/topic/2378/how-can-i-set-the-payload-for-mqtt-v1-6 where I wasn't able to send my buffer from my mqtt gateway to another sensor node. After spending all day today debugging the issue, I was able to find two bugs and to send the buffer correctly.
                        This is the topic which I subscribe to
                        #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygatewayin"
                        This is how I send my mqtt pattern using MQTTlens or Mosquitto to be published to the gateway. My message contains 1 or 0 to turn ON or OFF a relay in my sensor node with id 4, child id 19, set, no ack, V_LIGHT
                        mygatewayin/4/19/1/0/2
                        The first problem which I faced is that my mqtt buffer wasn't evaluated in the callback function incomingMQTT() found in MyGatewayTransportMQTTClient.cpp
                        After checking the case switch I found out that the rest of the case switches doesn't continue because the code returns due to the following line
                        if (strcmp_P(str, MY_MQTT_SUBSCRIBE_TOPIC_PREFIX) != 0)
                            return;
                        According to http://www.nongnu.org/avr-libc/user-manual/group__avr__pgmspace.html#gad34d5b7d040fcb97939e939f19d88a5f
                        The strcmp_PF() function returns an integer less than, equal to, or greater than zero if s1 is found, respectively, to be less than, to match, or be greater than s2. The contents of RAMPZ SFR are undefined when the function returns
                        Actually I haven't used this function before but according to description it will return 0 if they are identical, so using != shall be right, but actually it was solved when I replaced it with == instead of !=
                        Finally I was able to evaluate the buffer and the case switches continued.
                        But Also this didn't solve the problem and the buffer wasn't sent to the sensor node id 4
                        After lots of printing functions for debugging I found that in serial monitoring, the following is printed
                        send: 0-0-0-4 s=19,c=1,t=2,pt=0,l=1,sg=0,st=fail:1
                        While when I use Serial gateway which is working well till now, the following is printed instead
                        send: 0-0-4-4 s=19,c=1,t=2,pt=0,l=1,sg=0,st=ok:1
                        Thus I found that the difference is in 0-0-X-4.
                        Searching further in the code, I found that the debug function for this line is used in MyTransport.cpp in function transportSendWrite(uint8_t to, MyMessage &message)
                        debug(PSTR("send: %d-%d-%d-%d s=%d,c=%d,t=%d,pt=%d,l=%d,sg=%d,st=%s:%s\n"),
                        			message.sender,message.last, to, message.destination, message.sensor, mGetCommand(message), message.type,
                        			mGetPayloadType(message), mGetLength(message), mGetSigned(message), to==BROADCAST_ADDRESS ? "bc" : (ok ? "ok":"fail"), message.getString(_convBuf));
                        So the difference here is that the variable to is set as 0 in case of mqttgateway, while it is set as 4 correctly using Serial gateway.
                        So finally this is what I have reached.
                        In MyTransport.cpp in function boolean transportSendRoute(MyMessage &message)
                        #if !defined(MY_REPEATER_FEATURE)
                            // None repeating node... We can only send to our parent\\
                            ok = transportSendWrite(_nc.parentNodeId, message);
                        The above is called because MY_REPEATER_FEATURE is not defined, thus the mqttgateway sends always 0 instead of the required node id.
                        I tried to define MY_REPEATER_FEATURE but I found big memory size and the software was crazy.
                        Also in MySensor.h it is not mentioned to be defined
                        #if defined(MY_GATEWAY_MQTT_CLIENT)
                        ... some code ...
                        ... some code ...
                        #elif defined(MY_GATEWAY_FEATURE)
                        ... some code ...
                        	#if defined(MY_RADIO_FEATURE)
                        		// We assume that a gateway having a radio also should act as repeater
                        		#define MY_REPEATER_FEATURE
                        What I did now as a workaround because it is 2:40 AM here and I need to sleep :D Is the following
                        In MyTransport.cpp
                        			ok = transportSendWrite(message.destination, message);
                        		#else
                        	#else
                        Please check whether this will solve the problem or not. Please correct me if I was wrong. It's my first time to look around in the library today.
                        Thanks.
                          @ahmedadelhosni said:
                          MY_REPEATER_FEATURE
                          Good catch, I'll do some tests and check in something.
                          ahmedadelhosniA 1 Reply Last reply
                            MY_REPEATER_FEATURE
                            ahmedadelhosniA
                            ahmedadelhosniA
                            ahmedadelhosni
                            @hek Thanks. I am sure you will come up with a better general solution :D
