  3. Noob, 1st sensor (Motion) and SerialGW not talking
6 Posts 2 Posters 2.2k Views
  • A
    A
    atomicpapa
    wrote on last edited by atomicpapa
    Setting up my first sensor (motion sensor) on a serial gateway connected to a RPi running Domoticz. Sensor is running on a Geuine Uno r3, GW is running on a Nano. Domoticz recognizes the gateway and is visible in Log. Looks like mybe they are talking based on serial monitor on gateway...
    0;0;3;0;9;read: 255-255-255 s=250;0;3;0;9;gateway started, id=0, parent=0, distance=0
    0;0;3;0;9;read: 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
    0;0;3;0;9;send: 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,st=bc:0
    0;0;3;0;9;send: 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,st=bc:0```
    Serial Monitor for sensor shows...
    find parent
    send: 255-255-ind parent
    s0,l=0,sg=0,st=bc:
    find parent
    send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
    find parent
    find parent
    find parent
    and repeats ad infinitum. No nodes or children show up in Domoticz. I am running stock Gateway and Sensor scripts with only 2 changes in MyConfig.h - Channel set to 100 and signal strength for sensors set to MAX.
    MyConfig.h
    #ifndef MyConfig_h
    #define MyConfig_h
    #include <stdint.h>
    // Enable debug flag for debug prints. This will add a lot to the size of the final sketch but good
    // to see what is actually is happening when developing
    #define DEBUG
    // Disable this line, If you are using TX(1), RX(0) as normal I/O pin
    #define ENABLED_SERIAL
    // Serial output baud rate (for debug prints and serial gateway)
    #define BAUD_RATE 115200
    *  Over the air firmware updates
    // The following define enables the safe over-the-air firmware update feature
    // which requires external flash and the DualOptiBoot bootloader.
    // Note: You can still have OTA FW updates without external flash but it
    // requires the MYSBootloader and disabled MY_OTA_FIRMWARE_FEATURE
    //#define MY_OTA_FIRMWARE_FEATURE
    // Slave select pin for external flash
    #define MY_OTA_FLASH_SS 8
    // Flash jdecid
    #define MY_OTA_FLASH_JDECID 0x1F65
    *  Information LEDs blinking
    // This feature enables LEDs blinking on message receive, transmit
    // or if some error occured. This was commonly used only in gateways,
    // but now can be used in any sensor node. Also the LEDs can now be
    // disabled in the gateway.
    // #define WITH_LEDS_BLINKING
    // The following setting allows you to inverse the blinking feature WITH_LEDS_BLINKING
    // When WITH_LEDS_BLINKING_INVERSE is enabled LEDSs are normally turned on and switches
    // off when blinking
    //#define WITH_LEDS_BLINKING_INVERSE
    // default LEDs blinking period in milliseconds
    #define DEFAULT_LED_BLINK_PERIOD 300
    // The RX LED default pin
    #define DEFAULT_RX_LED_PIN 6
    // The TX LED default pin
    #define DEFAULT_TX_LED_PIN 5
    // The Error LED default pin
    #define DEFAULT_ERR_LED_PIN 4
    *  Message Signing Settings
    // Disable to completly disable signing functionality in library
    //#define MY_SIGNING_FEATURE
    // Define a suitable timeout for a signature verification session
    // Consider the turnaround from a nonce being generated to a signed message being received
    // which might vary, especially in networks with many hops. 5s ought to be enough for anyone.
    #define MY_VERIFICATION_TIMEOUT_MS 5000
    // Enable to turn on whitelisting
    // When enabled, a signing node will salt the signature with it's unique signature and nodeId.
    // The verifying node will look up the sender in a local table of trusted nodes and
    // do the corresponding salting in order to verify the signature.
    // For this reason, if whitelisting is enabled on one of the nodes in a sign-verify pair, both
    // nodes have to implement whitelisting for this to work.
    // Note that a node can still transmit a non-salted message (i.e. have whitelisting disabled)
    // to a node that has whitelisting enabled (assuming the receiver does not have a matching entry
    // for the sender in it's whitelist)
    //#define MY_SECURE_NODE_WHITELISTING
    // MySigningAtsha204 default setting
    #define MY_ATSHA204_PIN 17 // A3 - pin where ATSHA204 is attached
    // MySigningAtsha204Soft default settings
    #define MY_RANDOMSEED_PIN 7 // A7 - Pin used for random generation (do not connect anything to this)
    // Key to use for HMAC calculation in MySigningAtsha204Soft (32 bytes)
    #define MY_HMAC_KEY 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
    *  NRF24L01 Driver Defaults
    #define RF24_CE_PIN		   9
    #define RF24_CS_PIN		   10
    #define RF24_PA_LEVEL 	   RF24_PA_MAX
    #define RF24_PA_LEVEL_GW   RF24_PA_MAX
    // RF channel for the sensor net, 0-127
    #define RF24_CHANNEL	   100
    //RF24_250KBPS for 250kbs, RF24_1MBPS for 1Mbps, or RF24_2MBPS for 2Mbps
    #define RF24_DATARATE 	   RF24_250KBPS
    // This is also act as base value for sensor nodeId addresses. Change this (or channel) if you have more than one sensor network.
    #define RF24_BASE_RADIO_ID ((uint64_t)0xA8A8E1FC00LL)
    // Enable SOFTSPI for NRF24L01 when using the W5100 Ethernet module
    //#define SOFTSPI
    #ifdef SOFTSPI
    	// Define the soft SPI pins used for NRF radio
    	const uint8_t SOFT_SPI_MISO_PIN = 16;
        const uint8_t SOFT_SPI_MOSI_PIN = 15;
        const uint8_t SOFT_SPI_SCK_PIN = 14;
    *  RFM69 Driver Defaults
    // Default network id. Use the same for all nodes that will talk to each other
    #define RFM69_NETWORKID     100
    // Default frequency to use. This must match the hardware version of the RFM69 radio (uncomment one):
    // #define RFM69_FREQUENCY   RF69_433MHZ
    #define RFM69_FREQUENCY   RF69_868MHZ
    //#define FREQUENCY     RF69_915MHZ
    // Enable this for encryption of packets
    //#define RFM69_ENABLE_ENCRYPTION
    #define RFM69_ENCRYPTKEY    "sampleEncryptKey" //exactly the same 16 characters/bytes on all nodes!
    Am I missing something simple here?
      Do you use an amplified radio on the gateway? How are you powering it? Capacitor?
      • A
        A
        atomicpapa
        Should have mentioned that. Running NRF24's, both with capacitors, both being powered off a USB hub hooked to my laptop.
          Strange.
          You node isn't receiving the FIND_PARENT broadcast message sent by your gateway. Hard to say what the problem is.. Try lowering the signal strength to see if that helps.. in that case you have a powering issue.
          • A
            A
            atomicpapa
            changed the MyConfig.h to lower power, but now getting an out of sync error from avrdude when I try to upload sketch, which appears to mean I need to reflash the bootloader from what I have been able to find. I'll update you on sig strength result when that's done.
              Not sure why the bootloader should have been corrupted? Have you disconnected everything from the Arduino board?
