  3. Can't get DHT22 working with MySbootloader
13 Posts 3 Posters 4.5k Views 1 Watching
  • fifipil909F
    fifipil909F
    fifipil909
    After some successful test with MySensor for Tempeture, Humidity, Motion, Light, battery voltage I would like to go through MYSbootloader.
    After that OTA firmware upgrade works perfectly but I've got issue to get DHT22 working.
    here is my code :
    #include <DHT.h>
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_MOTION 2
    #define CHILD_ID_LIGHT 3
    #define HUMIDITY_SENSOR_DIGITAL_PIN 5
    #define MOTION_SENSOR_DIGITAL_PIN 2
    #define INTERRUPT DIGITAL_INPUT_SENSOR 2
    #define LIGHT_SENSOR_ANALOG_PIN A0
    #define BATTERY_SENSE_PIN A1 // select the input pin for the battery sense point
    unsigned long SLEEP_TIME = 60000; // Sleep time between reads (in milliseconds)
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
    int lastLightLevel;
    char lasttripped;
    int lastBatteryPcnt;
    MyMessage msg(CHILD_ID_MOTION, V_TRIPPED);
    MyMessage msglight(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
      gw.begin(NULL, 28, false);
      pinMode(MOTION_SENSOR_DIGITAL_PIN, INPUT);
      attachInterrupt(digitalPinToInterrupt(MOTION_SENSOR_DIGITAL_PIN), loop, CHANGE);
      gw.sendSketchInfo("Sensor Pack", "1.2");
      gw.present(CHILD_ID_MOTION, S_MOTION);
      gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
      metric = true;
      // Motion Sensor
      boolean tripped = digitalRead(MOTION_SENSOR_DIGITAL_PIN) == HIGH;
      if (tripped != lasttripped)
        Serial.print("Motion : ");
        Serial.println(tripped);
        gw.send(msg.set(tripped ? "1" : "0")); // Send tripped value to gw
        lasttripped = tripped;
      // DHT sensor for Humidity and temperature
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("Temperature : ");
        Serial.println(temperature);
      if (isnan(humidity)) {
        lastHum = humidity;
        Serial.print("Humidity: ");
        Serial.println(humidity);
      // Batt
      // Diviseur de tension : Vbatt = VCC*(R2/(R1+R2)
      // Vbatt Max : 3.3x(463000/(981000 + 463000)
      // Vbatt Max : 3.3 / 0,3206371191135734
      // vbatt Max : 1.05
      // --> Resolution : (1.05 * 1023) / 3.3
      // --> ADC Max batt value 328
      // Vbatt Min : 2.4 x(463000/(981000 + 463000)
      // Vbatt Min : 2.4 / 0,3206371191135734
      // vbatt Min : 0.7695
      // --> Resolution : (0.7695 * 1023) / 3.3
      // --> ADC Min batt value 238
      int batteryPcnt = map(sensorValue, 238, 328, 0, 100);
      if (lastBatteryPcnt != batteryPcnt) {
        lastBatteryPcnt = batteryPcnt;
        Serial.print(batteryPcnt);
        Serial.println(" %");
     // Light Sensor
      //  int lightLevel = analogRead(0);
      int lightLevel = (1023 - analogRead(LIGHT_SENSOR_ANALOG_PIN)) / 10.23;
      Serial.print("Light level : ");
      Serial.println(lightLevel);
        Serial.print("Light : ");
        gw.send(msglight.set(lightLevel));
        lastLightLevel = lightLevel;
      gw.sleep(SLEEP_TIME); //sleep a bit
    The DHT report nothing.
    I already try to change DHT pin, but still the same. when returning to the default bootloader DHT report successfully temperature and Humidity.
    So I suspect something wrong when going to 16Mhz clock. do you have any idea ?
    Thanks in Advance.
    • fifipil909F
      fifipil909F
      fifipil909
      Just to add some things.
      I'm using 1.5 lib.
      Here is a screenshot from Myscontroller and my serial debug line :
      upload-de0889f3-c9b7-4784-8476-a423e25e1adb
      upload-993a2926-4a7e-48f0-bad3-2beaae3189a9
      tekkaT 1 Reply Last reply
      • fifipil909F fifipil909
        I'm using 1.5 lib.
        tekkaT
        tekkaT
        tekka
        @fifipil909 sounds like a frequency mismatch. What board and settings are you using for standard upload and to generate the .hex file?
        • fifipil909F
          fifipil909F
          fifipil909
          with the default bootloader I use : Arduino pro mini 3.3V - 8Mhz
          For the MYSbootloader I use :
          proMYSBL.name=ATmega328 16Mhz MYSBootloader
          proMYSBL.upload.tool=avrdude
          proMYSBL.upload.protocol=arduino
          proMYSBL.upload.maximum_size=30720
          proMYSBL.upload.maximum_data_size=2048
          proMYSBL.upload.speed=115200
          proMYSBL.bootloader.tool=avrdude
          proMYSBL.bootloader.low_fuses=0xF7
          proMYSBL.bootloader.high_fuses=0xDA
          proMYSBL.bootloader.extended_fuses=0x06
          proMYSBL.bootloader.unlock_bits=0x3F
          proMYSBL.bootloader.lock_bits=0x0F
          proMYSBL.bootloader.file=MySensors/MYSBootloader.hex
          proMYSBL.build.mcu=atmega328p
          proMYSBL.build.f_cpu=16000000L
          proMYSBL.build.board=AVR_UNO
          proMYSBL.build.core=arduino
          proMYSBL.build.variant=standard
          I try to change the f_cpu settings to 8000000L but same result.
            tekkaT
            tekkaT
            tekka
            wrote on last edited by tekka
            @fifipil909 8mhz crystal on your board, 3v3? Did you change f_cpu for compiling or for flashing?
            • fifipil909F
              fifipil909F
              fifipil909
              Yes i'm using the 8mhz external oscilator.
              I just change f_cpu while flashing the bootloader.
              Didn't try yet to recompile.
              • fifipil909F
                fifipil909F
                fifipil909
                I confirm it was due to Clock mismatch.
                I burnt a 8mhz version of the bootloader, assign good fuse.
                and now get everything working.
                upload-f27afbdf-a303-4d4b-b8e2-c58903d9d083
                  tekkaT
                  tekkaT
                  tekka
                  Importantly, it's not the bootloader at 8mhz that fixed the issue, it's the correct fuse settings matching f_cpu and the crystal. The bootloader is not controlling anything but OTA FW update.
                  • carlierdC
                    carlierdC
                    carlierd
                    I have an issue really close to yours. I burnt MYSBootloader to an Arduino Pro Mini at 8MHz and 3.3v.
                    Burning is ok and using Nick Gammon sketch I confirm it's correct:
                    Atmega fuse calculator.
                    Written by Nick Gammon.
                    Version 1.10
                    Compiled on Nov 21 2015 at 10:56:15 with Arduino IDE 10605.
                    Attempting to enter programming mode ...
                    Entered programming mode OK.
                    Signature = 0x1E 0x95 0x0F
                    Processor = ATmega328P
                    Flash memory size = 32768
                    LFuse = 0xF7
                    HFuse = 0xDA
                    EFuse = 0xFE
                    Lock byte = 0xCF
                    Clock calibration = 0xA8
                    External Reset Disable.................. [ ]
                    Debug Wire Enable....................... [ ]
                    Enable Serial (ICSP) Programming........ [X]
                    Watchdog Timer Always On................ [ ]
                    Preserve EEPROM through chip erase...... [ ]
                    Boot into bootloader.................... [X]
                    Divide clock by 8....................... [ ]
                    Clock output............................ [ ]
                    Bootloader size: 2048 bytes.
                    Start-up time: SUT0: [ ]  SUT1: [ ] (see datasheet)
                    Clock source: full-swing crystal.
                    Brownout detection at: 1.8V.
                    But impossible to upload a sketch after that. I got the 'not in sync' problem:
                    avrdude: stk500_recv(): programmer is not responding
                    avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
                    avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
                    @tekka: I understood from your last reply that I need to change fuse settings for matching f_cpu and the crystal ? I only change f_cpu to 8000000L in board.txt but without fuses modification and no bootloader compilation. Can you confirm modifications I have to do ?
                    Thanks !
                    • carlierdC carlierd
                      Version 1.10
                      LFuse = 0xF7
                      HFuse = 0xDA
                      EFuse = 0xFE
                      Lock byte = 0xCF
                      Thanks !
                      tekkaT
                      tekkaT
                      tekka
                      @carlierd With MYSBootloader you cannot upload a sketch the conventional way, i.e. you cannot upload via a serial connection. MYSBootloader is OTA upload only.
                      • carlierdC
                        carlierdC
                        carlierd
                        Oups !! Shame on me :joy:
                        It's also working using RFM69 ?
                          tekkaT
                          tekkaT
                          tekka
                          @carlierd no, not implemented (at the moment)
                          • carlierdC
                            carlierdC
                            carlierd
                            One more question (or perhaps no ;) ) signing is working without MYSBootloader ?
                            Thanks a lot for your replies.
                            David.
