  3. esp8266 gateway keeps resetting on keepalive
resetesp8266
14 Posts 5 Posters 8.5k Views 2 Watching
  • V Offline
    V Offline
    vlad
    Hey guys, I've set up esp8266 gateway and one of the opensource controllers. esp8266 keeps restarting with the errors below. If I disable the controller then esp seems to work fine.
    The software has keepalive set and I believe that might be triggering this error. Has anyone seen anything like that?
    Thanks.
    ESP8266 MySensors Gateway
    Connecting to vhome
    .......Connected!
    IP: 192.168.0.51
    Client 0 connected
    Client 0: 0;255;3;0;2;
    Exception (28):
    epc1=0x4000bf80 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
    ctx: cont
    sp: 3ffeaca0 end: 3ffeaf20 offset: 01a0
    >>>stack>>>
    3ffeae40:  00000000 3fffdc20 3ffe97c7 40203ac0
    3ffeae50:  3ffeaf80 00000001 3ffe8fc9 4020b73c
    3ffeae60:  3ffeaf80 0000000b 3ffe98bf 00000000
    3ffeae70:  00000003 00000000 3ffe98a8 4020ae11
    3ffeae80:  00000001 3ffe98b4 3ffeaf80 4020ae11
    3ffeae90:  3ffe98b4 3ffe98b4 3ffeaf80 3ffeaf80
    3ffeaea0:  3ffe98b4 3ffe97c0 3ffe97c7 402024b4
    3ffeaeb0:  3ffe9ab8 3ffe98b4 00000000 40202784
    3ffeaec0:  3ffe8e48 00000000 000003e8 3ffe9c4c
    3ffeaed0:  00000000 3fff4c88 3fff4c18 3ffeaf4c
    3ffeaee0:  00000000 0000000a 00000000 00000000
    3ffeaef0:  40201c35 3300a8c0 00000000 3ffeaf4c
    3ffeaf00:  3fffdc20 00000000 3ffeaf44 40201c92
    3ffeaf10:  00000000 00000000 3ffe9f00 40100378
    <<<stack<<<
     ets Jan  8 2013,rst cause:1, boot mode:(3,7)
    load 0x4010f000, len 1264, room 16
    tail 0
    chksum 0x42
    csum 0x42
    ~ld
    Connecting to vhome
    .....Connected!
    IP: 192.168.0.51
    • L Offline
      L Offline
      Luppie
      It looks like the problem that I also have with my gateway described in my topic
      • T Offline
        T Offline
        twisted
        Snap here too.
        • V Offline
          V Offline
          vlad
          It does look like the same issue. Mine does not restart on a sensor connection (I have one node with 4 reed switches) but totally restarts on keepalive call.
          • V Offline
            V Offline
            vlad
            wrote on last edited by vlad
            On further inspection it looks like a different issue since I don't get reboots unless connected to Mycontroller. If I shut down the software reboots stop. Sensors send things to the gateway just fine.
            If I set keepalive to very long then things are good and there are no reboots all the time(assuming it will reboot once that timer lapses). If I start mycontroller while esp is running then esp will reboot for sure.
            This has something to do with tcp sockets and keepalive.
            • H Offline
              H Offline
              Are you guys getting the same resets when using dev-branch?
              • V Offline
                V Offline
                vlad
                Can't get dev branch to build -
                GatewayESP8266.ino:131:27: fatal error: ESP8266WiFi.h: No such file or directory
                • H Offline
                  H Offline
                  Did you change board type to NodeMCU?
                  • V Offline
                    V Offline
                    vlad
                    Very sorry, I got past that point but forgot about it. I ended up having to remove all of the libraries and then extract dev branch, otherwise merging the two didn't work.
                    I think this issue is now gone, I can keep controller running and the gateway doesn't reboot. I do have a new issue though, sensors now crash the controller (was not the case in 1.5)
                    I just used a simple trigger example from dev branch and that crashes the gateway in some scenarios. It crashed it when I turned off the sensor node, it crashed when I opened serial monitor for sensor node, it crashes mid way, etc
                    Seems like any client communication has a high chance to crash it.
                    âm+ÿ¡šóÿ0;0;3;0;9;Starting gateway (1.6.0-beta)
                    0;0;3;0;9;Radio init successful.
                    scandone
                    f 0, scandone
                    .add 0
                    aid 1
                    pm open phy_2,type:2 0 0
                    cnt
                    connected with vhome, channel 6
                    dhcp client start...
                    .........ip:192.168.0.51,mask:255.255.255.0,gw:192.168.0.1
                    .IP: 192.168.0.51
                    0;0;3;0;9;Init complete, id=0, parent=0, distance=0
                    0;0;3;0;9;Client 0 connected
                    0;0;3;0;9;read: 20-20-0 s=255,c=0,t=17,pt=0,l=10,sg=0:1.6.0-beta
                    0;0;3;0;9;read: 20-20-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
                    0;0;3;0;9;Client 0: 20;255;3;0;6;M
                    0;0;3;0;9;send: 0-0-20-20 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
                    0;0;3;0;9;read: 20-20-0 s=3,c=0,t=0,pt=0,l=0,sg=0:
                    0;0;3;0;9;read: 20-20-0 s=3,c=1,t=16,pt=2,l=2,sg=0:1
                    0;0;3;0;9;read: 20-20-0 s=3,c=1,t=16,pt=2,l=2,sg=0:0
                    0;0;3;0;9;Client 0: 0;255;3;0;2;
                    Fatal exception (28):
                    epc1=0x4000bf80, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x0
                    0000000
                    Exception (28):
                    000
                    ctx: cont
                    sp: 3ffea5f0 end: 3ffea8a0 offset: 01a0
                    >>>stack>>>
                    3ffea790:  3fff1c88 40219430 3ffea980 402039e4
                    3ffea7a0:  40213751 3fff4b78 00000001 3ffea7d0
                    3ffea7b0:  3ffea7c0 00000004 3ffeabfc 00000000
                    3ffea7c0:  00000003 00000000 00000001 00000000
                    3ffea7d0:  3ffeaa68 3ffeaa74 0000000a 3ffeaac8
                    3ffea7e0:  00000001 3ffeab98 00000000 40203f34
                    3ffea7f0:  00000000 3ffeaa68 3ffeab98 40203624
                    3ffea800:  3fffdc20 00000000 3ffeaa58 3ffeabfb
                    3ffea810:  00000000 00000003 00000000 402042f3
                    3ffea820:  3ffea8cc 3ffea924 00000014 4020217e
                    3ffea830:  00000000 3fff4bc8 3ffea950 00000000
                    3ffea840:  00000010 00000000 00000014 00000002
                    3ffea850:  00000003 00000012 00000000 3ffeaa60
                    3ffea860:  3fffdc20 00000000 3ffeaa58 40204a1c
                    3ffea870:  40203c55 00000000 3ffeaa58 4020435f
                    3ffea880:  00000000 00000000 3ffeaa58 4020496a
                    3ffea890:  00000000 00000000 3ffe9880 40100118
                    <<<stack<<<
                    òm+ÿ(æz=0;0;3;0;9;Starting gateway (1.6.0-beta)
                    scandone
                    f 0, scandone
                    .add 0
                    aid 1
                    cnt
                    .IP: 192.168.0.51
                    • V Offline
                      V Offline
                      vlad
                      Removed the sensor completely and gateway still reboots, it just takes much longer now
                      scandone
                      f 0, ....scandone
                      .add 0
                      aid 1
                      cnt
                      .IP: 192.168.0.51
                      epc1=0x4000bf80, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
                      Exception (28):
                      ctx: cont
                      >>>stack>>>
                      3ffea790:  3fff1c28 40219388 3ffea980 402039e4
                      3ffea7a0:  402136a9 3fff4b68 3ffeaa58 3ffea7d0
                      3ffea7b0:  3ffea7c0 00000004 3ffeabf4 00000000
                      3ffea7d0:  3ffeaa60 3ffeaa6c 0000000a 3ffeaac0
                      3ffea7e0:  00000001 3ffeab90 00000000 40203ec8
                      3ffea7f0:  00000000 3ffeaa60 3fff4bb8 40206a0a
                      3ffea800:  3fffdc20 00000000 3ffeaa50 3ffeabf3
                      3ffea810:  00000000 00000003 00000000 4020428b
                      3ffea820:  3ffe8f20 00000000 000003e8 402024f1
                      3ffea830:  00000000 3fff4bb8 3ffea950 3ffea860
                      3ffea840:  00000000 00000004 3ffea950 40202d34
                      3ffea850:  3fffdc20 00000000 00000000 3ffeaa58
                      3ffea860:  3fffdc20 00000000 3ffeaa50 40204994
                      3ffea870:  40203be9 00000000 3ffeaa50 402042e3
                      3ffea880:  00000000 00000000 3ffeaa50 402048e6
                      <<<stack<<<
                      òm+ÿP9<áÿ0;0;3;0;9;Starting gateway (1.6.0-beta)
                      scandone
                      f 0, ....scandone
                      .reconnect
                      f -240, ....scandone
                      .reconnect
                      f 0, ....scandone
                      .add 0
                      aid 1
                      cnt
                      .IP: 192.168.0.51
                      H 1 Reply Last reply
                      • V vlad
                        scandone
                        f 0, ....scandone
                        .add 0
                        aid 1
                        cnt
                        .IP: 192.168.0.51
                        Exception (28):
                        ctx: cont
                        >>>stack>>>
                        <<<stack<<<
                        scandone
                        f 0, ....scandone
                        .reconnect
                        .reconnect
                        f 0, ....scandone
                        .add 0
                        aid 1
                        cnt
                        .IP: 192.168.0.51
                        H Offline
                        H Offline
                        What do you mean by:
                        Did you alter the esp-gateway sketch? If so, you might wanna post it here.
                        • V Offline
                          V Offline
                          vlad
                          Other than login/password and commenting out static ip part nothing was changed.
                          I wonder if it's power even though I'm powering from one of those breadboard power sources that's connected to 9v and is feeding 3.3v to esp/radio.
                          • V Offline
                            V Offline
                            vlad
                            Looks like I might have jumped the gun on dev being better than release branch. I changed the keepalive timeout to a long time and constant reboots stopped.
                            So this is the same issue then, it might just get exacerbated when node has something to say to the gateway/controller.
                            By removed sensor I meant I turned it off completely (it is the only sensor node in the network). Gateway was still rebooting even with no nodes on the network.
                            I took apart my ethernet gateway so I think I'll just stick with this one and set keepalive to a long time. Gateway will still reboot but it won't be every minute and that should be ok until the fix is found.
                            tpenguin74T 1 Reply Last reply
                            • V vlad
                              tpenguin74T Offline
                              tpenguin74T Offline
                              tpenguin74
                              @vlad I am having the same issue. Where did you change keepalive timeout to a long time?
                              Essentially, what file did you edit, what parameter and to how long?
                              12.2k
