  3. SceneController
SceneController
28 Posts 9 Posters 19.8k Views 5 Watching
  • D dayve218
    @Dalhoj is it possible to have one button stop/start the same scene, as an on/off switch for a light for example?
    @dayve218
    Some "scene controllers" I've seen triggers "scene off" when you push-and-hold button for say one a second.
    • D
      D
      dayve218
      wrote on last edited by dayve218
      #22
      how would i make that happen?
      @korttoma i dont, PLEG is infinitely confusing to me.
      • D
        D
        Dalhoj
        I dont know if you can have a 1 sec press!
        but i uses LUUP and a simple ex could be turn on a lamp and if the lamp if on turn it off:
        local relay1 = 114 --Light ID
        local relay1_status = luup.variable_get("urn:upnp-org:serviceId:SwitchPower1", "Status", relay1) --Status of Light
        if (relay1_status == "0") then
        luup.call_action("urn:upnp-org:serviceId:SwitchPower1","SetTarget",{ newTargetValue="1" }, relay1)
        else
        luup.call_action("urn:upnp-org:serviceId:SwitchPower1","SetTarget",{ newTargetValue="0" }, relay1)
        end
        Or you can use a toggle from the advanced scene menu:
        upload-cb06931d-0aaa-4ee3-b90f-345180b5247c
        That is how I do it.
        hekH 1 Reply Last reply
        • D Dalhoj
          else
          end
          I mean that the Arduino checks if user presses button for one sec and send the SCENE_OFF. You probably shouldn't let Vera handle this.
          D 1 Reply Last reply
          • NuubiN
            NuubiN
            Nuubi
            Hey! Any pictures of scene controller installations? I'm planning on DIY'ing some "aesthetically pleasing" ones :-)
              D
              D
              Dalhoj
              I would make the Arduino send ie. for button 1 send scene ID 0 at short press and scene ID 1 for long press and so on.
              @Nuubi Here is two of my scene controllers:
              The first one is installed in my bedtable upload-c29b281d-083c-4b73-a4df-b27240ee9e31 and is a combination of a scenecontroller and a relaysensor for controling the 3 leds.
              The 2. is installed in the living room, and is a 8 button scenecontroller.
              upload-aee5fc51-3dea-4a00-b592-db58744e1e87
              It controlles
              • the lights in the living room
              • Blinds Open / Close
              • a power outlet On/Off
              • pause/plays my XBMC Medie Center
              • starts my Yamaha reciver and starts playing net radio
              • stops the radion again and turn of the reciver
              • turns up / down the volume on the reciver
              That is what I use it for at the moment.
              S 1 Reply Last reply
              • D Dalhoj
                It controlles
                Smelliot
                @Dalhoj what enclosures are they? They look really slick!
                • D
                  D
                  Dalhoj
                  Its a danish enclosure: http://www.lk.dk/produkter/afbrydermateriel-lk-fuga/lk-fuga/antibakteriel/underlag/baseline-2-modul-346dd488/ for the button one and: http://www.lk.dk/produkter/afbrydermateriel-lk-fuga/lk-fuga/antibakteriel/underlag/baseline-1-modul-hvid/ for the top one.
                  Its a danish department of Schneider Electric called LK(Lauritz Knudsen)
