  3. gw.request() and domoticz - problem with get V_DISTANCE
7 Posts 3 Posters 3.1k Views
  • E
    E
    Eoreh
    wrote on last edited by Eoreh
    Hey !
    I have a problem with receiving from the controller Domoticz (V2.3799) the V_DISTANCE by gw.request()
    MySensors is 1.5 - Latest Release.
    I wrote a short test program that shows a problem.
    #define CHILD_ID 1                              // Id of the sensor child
    MyMessage msg(CHILD_ID, V_DISTANCE);
    MyMessage msg2(CHILD_ID, V_VAR1);
    unsigned long SEND_FREQUENCY = 3000;  // 1 sekunda = 1000;
    	gw.begin(incomingMessage);
    	gw.sendSketchInfo("Test", "1.1");
    	gw.present(CHILD_ID, S_DISTANCE);
    	gw.process();
    	gw.request(CHILD_ID, V_DISTANCE, 0);
    	gw.request(CHILD_ID, V_VAR1, 0);
    		delay(2000);
    			gw.send(msg.set(0));
    		delay(2000);
    			gw.send(msg2.set(1));
    		delay(2000);
    	gw.sleep(SEND_FREQUENCY);
    	if (message.type == V_VAR1) {
    		Serial.println("Received V_VAR1 from gw ");
    	if (message.type == V_DISTANCE) {
    	Serial.println("Received V_DISTANCE from gw ");
    	Serial.println("incomingMessage");
    I do not know why I get message for V_VAR1 and didnt get for V_DISTANCE. ?
    And short LOG from my node here:
    Opening port
    Port open
    find parent
    send: 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
    read: 0-0-255 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    parent=0, d=1
    req id
    send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok:
    read: 0-0-255 s=255,c=3,t=4,pt=0,l=2,sg=0:20
    send: 20-20-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=fail:1.5
    send: 20-20-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    read: 0-0-20 s=255,c=3,t=6,pt=0,l=1,sg=0:M
    id=20
    send: 20-20-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
    sensor started, id=20, parent=0, distance=1
    send: 20-20-0-0 s=255,c=3,t=11,pt=0,l=4,sg=0,st=ok:Test
    send: 20-20-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
    send: 20-20-0-0 s=1,c=0,t=15,pt=0,l=0,sg=0,st=ok:
    send: 20-20-0-0 s=1,c=2,t=13,pt=0,l=0,sg=0,st=ok:
    send: 20-20-0-0 s=1,c=2,t=24,pt=0,l=0,sg=0,st=ok:
    send: 20-20-0-0 s=1,c=1,t=13,pt=2,l=2,sg=0,st=ok:0
    send: 20-20-0-0 s=1,c=1,t=24,pt=2,l=2,sg=0,st=ok:1
    read: 0-0-20 s=1,c=2,t=24,pt=0,l=0,sg=0:
    incomingMessage
    read: 0-0-20 s=1,c=2,t=24,pt=0,l=1,sg=0:1
    incomingMessage
    Port closed
    I dont know why i get only message for V_VAR1 and I didnt get for V_DISTANCE. ?
      You're issuing a gw.sleep(). That shuts down the radio thus no incoming data.
      • E
        E
        Eoreh
        Thx for quick answer Hek !.
        I comment this line
        	//gw.sleep(SEND_FREQUENCY);
        upload sketch by still no have log from "V_DISTANCE". Any other idea ?
          Use gw.wait(2000) instead of delay()
          • E
            E
            Eoreh
            Hi !.
            Sure next sketch I will use. But the problem looks like it is elsewhere.
            I found that if i change in this sketch
            • S_DISTANCE -> S_LIGHT
            • V_DISTANCE -> V_LIGHT
            its works ! :smiley: Maybe just this type (V_DISTANCE) is not supported in Domoticz and gw.request() (?)
            So now I will start a little more test. I'm going to check other types.
            • E
              E
              Eoreh
              .. after some tests. If Im not wrong only few messages / variables - is support by gw.request() and domoticz.
              I used sketch belowe to tests, and i found only supports for:
              • S_LIGHT / V_LIGHT
              • S_DIMMER / V_DIMMER
              • S_BINARY / V_LIGHT
              • S_BINARY / V_STATUS
              My check list is in this sketch for tests in section comments
              #include <EEPROM.h>
              /*  list of checked types /variables */
              /* supported by domoticz and gw.request -> type/variable:
              	S_LIGHT / V_LIGHT
              	S_DIMMER / V_DIMMER
              	S_BINARY / V_LIGHT
              	S_BINARY / V_STATUS
              /* NOT supported by domoticz and gw.request -> type/variable:
              	S_DOOR / V_TRIPPED
              	S_MOTION / V_TRIPPED
              	S_DISTANCE / V_DISTANCE
              	S_TEMP / V_TEMP
              	S_BINARY / V_WATT
              	S_HUM / V_HUM
              	S_WIND / V_WIND
              	S_POWER / V_KWH
              #define S_type   S_LIGHT      // here change type
              #define V_type   V_LIGHT   		// here change variable
              int clearEEPROM = 1;				// if required reset memory change for 1
              MyMessage msg(CHILD_ID, V_type);
              unsigned long SEND_FREQUENCY = 1000;  // 1 sec = 1000;
              	if (clearEEPROM == 1) {
              		Serial.println("Reset EEPROM");
              		ClearEEPROM();
              		clearEEPROM = 0;
              	gw.present(CHILD_ID, S_type);
              	gw.process();
              	gw.request(CHILD_ID, V_type, 0);
              	gw.wait(1000);
              	gw.wait(1000);
              	if (message.type == V_type) {
              		Serial.println("Received from gw ");
              void ClearEEPROM()
              	Serial.println("Clearing EEPROM");
              	for (int i = 0;i<512;i++) {
              		EEPROM.write(i, 0xff);
              	Serial.println("Cleared EEPROM");
              AWIA 1 Reply Last reply
              • E Eoreh
                • S_LIGHT / V_LIGHT
                #include <EEPROM.h>
                	S_LIGHT / V_LIGHT
                	S_DIMMER / V_DIMMER
                	S_BINARY / V_LIGHT
                	S_BINARY / V_STATUS
                	S_DOOR / V_TRIPPED
                	S_TEMP / V_TEMP
                	S_BINARY / V_WATT
                	S_HUM / V_HUM
                	S_WIND / V_WIND
                	S_POWER / V_KWH
                		ClearEEPROM();
                		clearEEPROM = 0;
                	gw.process();
                	gw.wait(1000);
                	gw.wait(1000);
                void ClearEEPROM()
                AWIA
                AWIA
                AWI
                @Eoreh you found out the hard way.. Domoticz only supports actuators with gw.request exception is V_TEXT (development) an the new CUSTOM type..
