  3. OpenHAB
  4. MQTT Binging - Possible two MQTT broker?
10 Posts 2 Posters 5.0k Views 1 Watching
  • X
    X
    xefil
    Hello to all!
    I'm using OpenHAB with an arduino network powered by mysensors.org project.
    OpenHAB is working well using a MQTT connection to this arduino gateway. Until here all works fine.
    I would like to add a second MQTT broker on the mysensors network, because I would like to add a second arduino gateway with a different radio hardware. Actually I'm using all nodes with nRF24L01+ nodes. I would like to add a RFM69 network as well.
    Can Openhab handle the same time comunication to TWO MQTT brokers?
    I cannot try because I need to buy the needed hardware and I would like to do it only if I know it's working.
    Or In case do you suggest a different approach? Using in example the new gateway with a serial gateway?
    Any suggestion would be really appreciated!
    Many thanks for the help!
    Simon
    • dakkyD
      dakkyD
      dakky
      wrote on last edited by dakky
      maybe the solution is to use an alternative setup:
      Not using the mqtt gateway from the example, but using the mqtt CLIENT gateway (currently on the development branch)
      This allows u to set up an mqtt broker (mosquitto) on your openhap host and the two gateways are sending their messages to this broker instead of being the broker themselves.
      Edit:
      narf. i see the client gateway examples are only for w5100 and ESP8266
      Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
      Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
      Software: MySensors 2.0development
      • X
        X
        xefil
        Hello @dakky ,
        I've asked the same on OpenHAB and the answer was that it is possible to add a second MQTT Instance:
        https://community.openhab.org/t/mqtt-binging-possible-two-mqtt-broker/5193
        BTW could you give me some other informations on your solution?
        Could I already implement this setup? How?
        Thanks!
        Simon
        • dakkyD
          dakkyD
          dakky
          The setup itself is working. The problem is, that you're using the RFM69 module as network device. There is no client gateway example for that device and i think i've read somehere here, that it won't become implemented (to large footprint?).
          EDIT:
          in case u're still interested, here a small impression how simple this setup works:
          • install mosquitto on raspbian
            quite simple apt-get install and ready to run
          • modify gateway client example (mac, ip, mqtt broker ip) and uplaod it
            this is a little bit annoying: I needed to upgrade to an arduino mega because the uno was too small for softISP, message singing and debug. But nevertheless ...
          • subscribing to all moqsuitto messages on rasbian:
            mosquitto_sub  -v -t '#'
            results in appearing messages from the node
            sensor-gw1-out/99/255/3/0/11 Test Sensor
            sensor-gw1-out/99/255/3/0/12 0.1
            sensor-gw1-out/99/3/1/0/16 1
          • item in openhab listening to that event:
            String  sketch_name_99    "Sketch name 99 (Test Item) [%s]"  (sketch,all) { mqtt="<[mysensors:sensor-gw1-out/99/255/3/0/11:state:default]" }
          Thats it
          • X
            X
            xefil
            @dakky, you mean there is not a controller gateway working with the radios RFM69?
            The doc is mentioning it:
            http://www.mysensors.org/build/connect_radio
            "Wiring the RFM69 Radio"
            Then, on the MQTT gateway side, I've seen in the code:
            #include <MyTransportRFM69.h>
            MyTransportNRF24 transport(RADIO_CE_PIN, RADIO_SPI_SS_PIN, RF24_PA_LEVEL_GW);
            //MyTransportRFM69 transport;
            So I think it shoud be enough to commet out the MyTransportNRF24 and uncomment the MyTransportRFM69, right??
            Then, I'm not understanding your instructions:
            Which gateway client? The arduino gateway? It's in listening mode AFAYK also, as soon there is a subscription on it, it would comunicate with it, not?
            And why you need an arduino mega? Isn't it using the same PINS like them on a gateway using the NRF24?
            I would expect that the final result would be, from the controller up to the sensors
            • OpenHAB with two MQTT instances pointing to two MQTT Broker, one for the NRF24 sensors, second for RFM69 sensors
              • Gateway MQTT for the NRF24 sensors
                • NRF24 sensors and repeaters
              • Gateway MQTT for RFM69 sensors
                • RFM69 sensors and repeaters
            So I cannot understood why I need mosquito server :sweat:
            Thanks again for the help!
            Simon
            • dakkyD
              dakkyD
              dakky
              I use a different kind of setup. I'm not using the mqttGateway example but die mqttClientGateway.
              This means the arduino gateway is not the messagebroker (server) itself, but is forwarding the messages to another broker (mosquitto)
              This allows me to post non-mysensors messages to the broker and openhab can consume them. A external broker is nessecary, because the mqttClientGateway can handle only one single connection (openhab, so no new messages from external tools, no debugging while openhab is connected etc) and i'm much more experienced in using software on the linux side instead on arduino => external broker
              When looking in the examples of mysensors, there are only 2 examples for mqttClientGateways (development branch):
              • GatewayESP8266MQTTClient (wlan afaik)
              • GatewayW5100MQTTClient (shield/module with w5100 chip)
              The Mega is nessecary, because the sketch size with optiboot was 108% of the allowed size without debugging (as far as i remember)
              And Yes the pins are other ones on the mega, but that requires just changing the sketch.
              • X
                X
                xefil
                Ok @dakky, it means simply that with your setup you have more control and debug over the mqtt broker. And you are using the mega256 because the soft-spi uses more space.
                My only limitation is I need the MEGA256 and I would like to use my own arduino boards and the network shield I've already purchased.
                BTW my setup should work as well, right?
                Then I could move to your setup when the library will be optimized to stay on an arduino uno/nano/promini... :)
                Thanks!
                Simon
                • dakkyD
                  dakkyD
                  dakky
                  As long as openhab supports (u did already verify that) 2 mqtt connections, you should be fine.
                  • X
                    X
                    xefil
                    Thanks @dakky for the support!!! :-)
                    Simon
                    • dakkyD
                      dakkyD
                      dakky
                      You're welcome
