  3. Domoticz
  4. Error Sending switch command
57 Posts 11 Posters 34.6k Views 5 Watching
  • macieiksM
    macieiksM
    macieiks
    Hello guys,
    I had the same problem with st=fail, also with this output: "Error sending command, check your hardware/device (blablabla :D)". I can give you here my hints, maybe they will help you. First of all I am using the latest beta domoticz and beta mysensors library v1.6.
    I am using two types of nrf24L01+ (with built-in antenna and external). For built-in antenna I am using #define RF24_PA_LEVEL_GW RF24_PA_HIGH in my sketches, BUT for external I need to lower the power because Arduino cannot provide enought current for it (even with attached capacitor): define RF24_PA_LEVEL_GW RF24_PA_LOW. I had this st=fail when I was using HIGH settings for nrf with external antenna, but now it is fixed. Also make sure that you have enough coverage.
    I have Arduino Mega2560 installed 1 week ago with 16 channel 12v relay board together. I had the the same problem like you "Error sending command, check your hardware/device". Two days ago I realized that maybe there is a problem with my powering my gateway. I have RFXtrx433, APCups and Ethernet Arduino Uno gateway connected to Raspberry Pi USB. I connected my MySensors gateway separately via 5V charge to the wall socket and this error problem is gone. Conclusion was this that my Raspberry couldnt supply enough current for all attached devices. Now I am planning to install PiHut USB hub with external power supply and move all connected USB interfaces to it and then just with one connection cable to my raspberry (maybe RFX will work better :) we will see).
    Update us if these two hints helped you ;D.
    Cheers
    Maciek
    RPI2 + RFLink + PiFace D2 + Aeon Z-Wave Gen5 + Foscams FI9821P&R2 + MySensors + UPS APC Back-UPS 950VA
    RPI2 + RFXtrx433e + Foscams FI9821P + MySensors + UPS APC Back-UPS 950VA
    RPIB+ + TP-Link MR3420 + Huawei E173 GarageDomoticz :)
    H J 3 Replies Last reply
    • sundberg84S sundberg84
      In new Domoticz beta there is so you can enable/disable ack. Havent tried that myself but maybe you can try to change that.
      Also what does your gw serial log say? Maybe we can find some clues there...
      H
      H
      hugo_pn
      Sorry for not replying but the error hasn't been appearing, só I cant show the log. From what I've read there is no log file in Domoticz.
      Haven't tried to enable/disable ack.
      • macieiksM macieiks
        Hello guys,
        Cheers
        Maciek
        H
        H
        hugo_pn
        wrote on last edited by hugo_pn
        #23
        @macieiks said:
        Hello guys,
        I am using two types of nrf24L01+ (with built-in antenna and external). For built-in antenna I am using #define RF24_PA_LEVEL_GW RF24_PA_HIGH in my sketches, BUT for external I need to lower the power because Arduino cannot provide enought current for it (even with attached capacitor): define RF24_PA_LEVEL_GW RF24_PA_LOW. I had this st=fail when I was using HIGH settings for nrf with external antenna, but now it is fixed. Also make sure that you have enough coverage."
        This may come into a great help, I have two external antennas that I thought where damaged since arrival, maybe this is the problem. I'm going to try this next week.
        Although, this still makes me thinking of distance, the error appears with the hardware separated by +- 3m with no obstacles .
        Cheers
        N 1 Reply Last reply
          Hello guys,
          Cheers
          Maciek
          J
          J
          jlaraujo
          @macieiks Could't find what my problem was. I've tried changing the gateway code to the sensor, same issue, change the radios, the same thing.
          I ended up downloading again the Mysensors library, the same issue, i then changed the baud rate for the debug and serial gateway to 19200 and that seemed to solve the issue, i can now issue commands to the nodes, thanks for the help.
          My sensor and gateway are all Pro mini, 8v 8Mhz, i remember now that i've read something in the forum, but can't find it now.
          Domoticz, mysensors 2.3.1, RFM69 and RF24 sensors
          • H hugo_pn
            @macieiks said:
            Hello guys,
            Cheers
            N
            N
            NBM
            @hugo_pn Is's possible to see the sketch? Im insecure where to alter the sketch.
            H 1 Reply Last reply
            • N NBM
              H
              H
              hugo_pn
              @NBM
              I'm trying to find it. As soon as I do and if I do I'll tell.
              Chears
                Hello guys,
                Cheers
                Maciek
                H
                H
                hugo_pn
                #27
                @macieiks said:
                Hello guys,
                Can't find the specific line. The most similar one is in the MyConfig.h line 115
                #define RF24_PA_LEVEL_GW RF24_PA_LOW
                Going with the GitHub file I don't even find it...
                Where exactly did you change the mentioned above?
                Hugo
                P.S. I can't find the V 1.6 library for my sensors. That's why I mentioned github
                  1.6 is the default branch when you go to the github project.
                  • N
                    N
                    NBM
                    This is what im getting when im trying to turn on the light.
                    0;0;3;0;9;send: 0-0-1-1 s=1,c=1,t=2,pt=0,l=1,sg=0,st=fail:1
                    • sundberg84S
                      #30
                      st=fail means the gw radio doesnt reach the node.
                      It can be a power issue (search the forum) which can be fixed with caps and/or other power.
                      It can be a range issue and then you need a repeater.
                        N
                        N
                        NBM
                        @sundberg84 The node is 2 meters from the gateway.
                        It most be an power problem. Is it with the gateway or node?
                        • sundberg84S
                          #32
                          Hi!
                          Can be both (or even worse, faulty hardware/bad fake nrf radios).
                          I power my gateway through USBCharger and have a 4.7 + 47 uF cap paralell on VCC/Gnd.
                          On my nodes i use a single 4.7uF cap VCC/GND
                          In best case its just one of your radios thats bad or misswired... check wiring and/or change the radios if you have another one.
                            Hi!
                            N
                            N
                            NBM
                            wrote on last edited by NBM
                            #33
                            @sundberg84 On my gateway (nano) is an 4.7 uF og it is connected with USB to the domoticz. How can I do it different?
                            Im getting this from the node. It reads okay.
                            1;255;3;0;11;RELAY_BUTTON_JUL
                            0;0;3;0;9;read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
                            1;255;3;0;12;1.0
                            0;0;3;0;9;read: 1-1-0 s=1,c=0,t=3,pt=0,l=0,sg=0:
                            1;1;0;0;3;
                            • N
                              N
                              NBM
                              I have made an temp node and it communicating okay.
                              0;0;3;0;9;read: 4-4-0 s=1,c=1,t=0,pt=7,l=5,sg=0:17.8
                              4;1;1;0;0;17.8
                              0;0;3;0;9;read: 4-4-0 s=0,c=1,t=1,pt=7,l=5,sg=0:45.2
                              4;0;1;0;1;45.2
                              0;0;3;0;9;read: 4-4-0 s=0,c=1,t=1,pt=7,l=5,sg=0:45.0
                              4;0;1;0;1;45.0
                              0;0;3;0;9;read: 4-4-0 s=0,c=1,t=1,pt=7,l=5,sg=0:45.3
                              4;0;1;0;1;45.3
                              4;0;1;0;1;45.0
                              Read is not the problem. it is send comands
                              • sundberg84S
                                #35
                                I had this problem due to range but 2m shouldnt be any problem... so strange you can recieve but not send.
                                Some things to consider if someone else doesnt know better than me:
                                • Change radios if possible
                                • Send commands without relays attached (to see if there is some spokes or disturabnce from relay)
                                • Connect MYSController to debug if possible
                                Whats your node ID on that node?
                                Im not good reading those serial lines but if they are beginning with 0 its like its sending to the gateway!?
                                In my case when i send: 103;1;1;1;2;1 where 103 is node ID, Child(Relay) 1, MsgType = 1 (Set), Ack = 1 (yes), 2 = V_LIGHT, 1 = On
                                • N
                                  N
                                  NBM
                                  #36
                                  My relay sensor
                                  How can i Send commands without relays attached? Where i see log from the gatway?
                                  I also tryed change radios. No change.
                                  • sundberg84S
                                    #37
                                    Sorry, Domoticz logs and hardware doesnt provide any info about the radio traffic. MySensors NodeID and Domoticz ID is not the same either.
                                    If you disconnect the relay from your Arduino you should still be able to send the switch command and with this the relay disconnected it doesnt make any power spikes that could interfere with the radio.
                                    Could you please post your sketch and logs from the gateway again... I cant seem to figure this out.
                                    • N
                                      N
                                      NBM
                                      The sketch to the relay
                                       * Version 1.0 - Henrik Ekblad
                                       * Example sketch for a "light switch" where you can control light or something
                                       * else from both HA controller and a local physical button
                                       * (connected between digital pin 3 and GND).
                                       * This node also works as a repeader for other nodes
                                      #include <Bounce2.h>
                                      #define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
                                      #define BUTTON_PIN  3  // Arduino Digital I/O pin number for button
                                      #define RELAY_ON 0
                                      #define RELAY_OFF 1
                                      Bounce debouncer = Bounce();
                                      int oldValue=0;
                                      bool state;
                                      MyMessage msg(CHILD_ID,V_LIGHT);
                                        gw.sendSketchInfo("RELAY_BUTTON_JUL", "1.0");
                                       // Setup the button
                                        pinMode(BUTTON_PIN,INPUT);
                                        // Activate internal pull-up
                                        debouncer.attach(BUTTON_PIN);
                                        debouncer.interval(5);
                                        gw.present(CHILD_ID, S_LIGHT);
                                        pinMode(RELAY_PIN, OUTPUT);
                                        state = gw.loadState(CHILD_ID);
                                        gw.process();
                                        debouncer.update();
                                        // Get the update value
                                        int value = debouncer.read();
                                        if (value != oldValue && value==0) {
                                            gw.send(msg.set(state?false:true), true); // Send new state and request ack back
                                        oldValue = value;
                                        if (message.isAck()) {
                                           // Change relay state
                                           state = message.getBool();
                                           // Store state in eeprom
                                           gw.saveState(CHILD_ID, state);
                                           // Write some debug info
                                           Serial.print(message.sensor);
                                      Log from gateway:
                                      1;255;3;0;12;1.0
                                      1;1;0;0;3;
                                      0;0;3;0;9;read: 4-4-0 s=1,c=1,t=0,pt=7,l=5,sg=0:17.9
                                      4;1;1;0;0;17.9
                                      0;0;3;0;9;read: 4-4-0 s=0,c=1,t=1,pt=7,l=5,sg=0:44.4
                                      4;0;1;0;1;44.4
                                      Without relay:
                                      0;0;3;0;9;send: 0-0-1-1 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:1
                                      0;0;3;0;9;read: 1-1-0 s=1,c=1,t=2,pt=0,l=1,sg=0:1
                                      1;1;1;1;2;1
                                      But in domoticz it still gives me hardware error.
                                      Gateway version 1.5.
                                      • N
                                        N
                                        NBM
                                        #39
                                        How do i change the node number?
                                        It select node 2 all the time with new nodes?
                                        In the sketch they are set to AUTO.
                                        Im using standard sketch from the libery.
                                        • sundberg84S
                                          #40
                                          Change: gw.begin(incomingMessage, AUTO, true);
                                          To: gw.begin(incomingMessage, 3, true); (If you want 3 as node id)
