  3. 5v Battery level
5v Battery level
7 Posts 3 Posters 3.2k Views 3 Watching
  • ErrKE
    ErrKE
    ErrK
    Hi.
    I have a Arduino mini 5v node with DHT11 and a Motion Sensor.
    Now i want to add a battery level function but i have only find how to do it with 3.3v.
    I am currently using 4st AA batteries for this node.
      @ErrK you're using http://www.mysensors.org/build/battery#measuring-and-reporting-battery-level ?
      If so, use the following numbers instead:
      // 1M, 200K divider across battery and using internal ADC ref of 1.1V
      // Vmax = 1.1*((1e6+200e3)/200e3) = 6.6 Volts
      // 6.6/1023 = Volts per bit = 0.006451613
      float batteryV = sensorValue * 0.006451613;
      (switch the 470k resistor to a 200k resistor and use 0.006451613 in the code)
      ErrKE 1 Reply Last reply
        ErrKE
        ErrKE
        ErrK
        @mfalkvidd that's exactly what I was looking for.
        Thanks for the quick answer.
          Great! You're welcome.
          • ErrKE
            ErrKE
            ErrK
            My node has been on for a week now and the battery meter shows 102%. It feels like a bit to much.
            • sundberg84S
              @ErrK thats nothing unusual. I use this code on 2x1.5A batterys and normally you get readings on 3.2V which is over 100%,
              • sundberg84S sundberg84
                ErrKE
                ErrKE
                ErrK
                @sundberg84 ok. Thanks for the help and the quick reply.
