  3. Publish --> MQTT Gateway very slow
8 Posts 2 Posters 4.9k Views 1 Watching
    mickaelh51
    I wrote an issue on github: https://github.com/mysensors/Arduino/issues/309
    Do you have an idea please ?
    thanks in advance
    Controller: OpenVZ :: OpenHab 1.8.0 :: MQTT Broker
    Gateway: Arduino UNO :: W5100 :: MQTTClient
    Software: MySensors 1.6beta
    R 1 Reply Last reply
    • M mickaelh51
      thanks in advance
      R
      R
      robosensor
      @mickaelh51 can you check speed of _ethernetServer.write(_ethernetMsg); call using the same debug code as for esp8266 gateway code here: http://forum.mysensors.org/topic/1870/esp8266-wifi-gateway-port-for-mysensors/225 ?
      Something like this:
              // Send message to connected clients
              #if defined(MY_GATEWAY_ESP8266)
                  for (uint8_t i = 0; i < ARRAY_SIZE(clients); i++)
                      if (clients[i] && clients[i].connected())
                          clients[i].write((uint8_t*)_ethernetMsg, strlen(_ethernetMsg));
              #else
                  unsigned long start_time = hwMillis();
                  debug(PSTR("Ethernet transaction time: %u ms\n"), hwMillis() - start_time);
      File to patch is libraries\MySensors\Core\MyGatewayTransportEthernet.cpp
        mickaelh51
        wrote on last edited by mickaelh51
        thanks for your answer @robosensor .
        But, I'm sorry, I don't know where add the patch in file :(
        I patched MyGatewayTransportEthernet.cpp with your code, but I don't use ESP8266. I use W5100 + NRF24L01.
        I patched in MY_CONTROLLER_IP_ADDRESS too => no result (not debug in serial monitor)
        For me, when W5100 receive MQTT messages there is a reception problem (because MQTT server send several times the same MQTT message.
        Can you help me to write patch please ;) ?
        thanks in advance
        FYI
        STATUS		0x0E RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
        RX_ADDR_P0-1	0x00003B3F00 00003B3F0E
        RX_ADDR_P2-5	0xFF C4 C5 C6
        TX_ADDR		0x00003B3F00
        RX_PW_P0-6	0x20 20 20 00 00 00
        EN_AA		0x3B
        EN_RXADDR	0x06
        RF_CH		0x4C
        RF_SETUP	0x07
        CONFIG		0x0E
        DYNPD/FEATURE	0x3F 06
        Data Rate	1MBPS
        Model		nRF24L01+
        CRC Length	16 bits
        PA Power	PA_MAX
        • M mickaelh51
          thanks in advance
          FYI
          EN_AA		0x3B
          EN_RXADDR	0x06
          RF_CH		0x4C
          RF_SETUP	0x07
          CONFIG		0x0E
          Data Rate	1MBPS
          Model		nRF24L01+
          CRC Length	16 bits
          PA Power	PA_MAX
          R
          R
          robosensor
          @mickaelh51 I'm sorry, MQTT gateway is slightly different.
          Please replace function in file MyGatewayTransportMQTTClient.cpp
          bool gatewayTransportSend(MyMessage &message) {
          	if (!_client.connected())
          		return false;
          	snprintf_P(_fmtBuffer, MY_GATEWAY_MAX_SEND_LENGTH, PSTR(MY_MQTT_PUBLISH_TOPIC_PREFIX "/%d/%d/%d/%d/%d"), message.sender, message.sensor, mGetCommand(message), mGetAck(message), message.type);
          	debug(PSTR("Sending message on topic: %s\n"), _fmtBuffer);
          	return _client.publish(_fmtBuffer, message.getString(_convBuffer));
          With something like this:
          		return false;
          	bool bReturnValue = _client.publish(_fmtBuffer, message.getString(_convBuffer));
          	return bReturnValue;
          I just want to know speed of _client.publish() call, but I don't have W5100.
            mickaelh51
            the results @robosensor :
            0;0;3;0;9;read: 9-9-0 s=3,c=0,t=3,pt=0,l=0,sg=0:
            0;0;3;0;9;Sending message on topic: mygateway1-out/9/3/0/0/3
            0;0;3;0;9;Ethernet transaction time: 1 ms
            1 ms for all received messages. indeed when sensor send temp + humidity from DHT11, the messages the messages arrive quickly to OpenHAB.
            But when I send MQTT message from OpenHAB to Gateway, it's very long (https://youtu.be/zQxLzGmCKlY).
            • M mickaelh51
              R
              R
              robosensor
              @mickaelh51 thank you very much for test results! Where is openhab located? Raspberry Pi? Or PC?
                mickaelh51
                @robosensor openhab is located on a proxmox server (it's a container).
                Openhab server: 172.16.13.237/24 --> MQTTGateway: 172.16.13.145/24
                I have many others sensors on arduino that are using MQTT directly (Not mysensors Framework) and they're ok and fast ;)
                I think, the MQTT gateway is very slow at some moments and it don't process MQTT messages received (as you can see in my youtube video).
                but at some others moments it can process this messages
                For your information, MQTT message is slow before incomingMQTT
                void incomingMQTT(char* topic, byte* payload,
                                        unsigned int length)
                debug(PSTR("Message arrived on topic: %s\n"), topic);
                Because when I send MQTT message with OpenHAB or MQTT.fx to mosquitto, it's send immediatly this message.
                After X seconds I can see in serial monitor log: "Message arrived...."
                Have you an idea ?
                thanks a lot !
                  mickaelh51
                  HAAAAAAAAAAAAAAAAAA !!!!!! pffffffffffff !!!!
                  so noob I am :(
                  it's work now !
                  I have a lot of arduino in my network, and there are diffrent MAc address => normal !
                  But in arduino with my sensor there wasn't MY_MAC_ADDRESS defined.
                  and... two arduino with the same MAC (default MAC) ... pffff ==> doesn't work fine!!!!
                  now it's work perfectly ! I'm sorry for you waste time !
                  thanks !
