  3. st:fail sometimes and sometimes OK
24 Posts 5 Posters 8.8k Views 2 Watching
  • F
    F
    flopp
    wrote on last edited by flopp
    Controller:
    Domoticz, version 2.3867
    Sensor:
    Arduino Nano Clone, nRF24L01+(maybe clone) with one sensor BMP180, battery powered by a LiPo 300 mAh directly to Arduino, no step-down- PWR LED removed, regulator for RAW removed
    BMP180 and NRF is connected via a step-down, 3.3 volt
    Battery level right now is 4 volt
    Gateway:
    Arduino Pro Mini Clone, nRF24L01+(maybe clone). Powered by USB
    Serial gateway
    Sensor code, added Battery reading from Arduino VCC, not analog input
     * Version 1.0 - Henrik Ekblad
     * Pressure sensor example using BMP085 module
     * http://www.mysensors.org/build/pressure
    #include <Wire.h>
    #include <Adafruit_BMP085.h>
    #define BARO_CHILD 0
    #define TEMP_CHILD 1
    #define BATT_CHILD 2
    const float ALTITUDE = 8; // <-- adapt this value to your own location's altitude.
    // Sleep time between reads (in seconds). Do not change this value as the forecast algorithm needs a sample every minute.
    const unsigned long SLEEP_TIME = 60000;
    const char *weather[] = { "stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown" };
    enum FORECAST
    	STABLE = 0,			// "Stable Weather Pattern"
    	SUNNY = 1,			// "Slowly rising Good Weather", "Clear/Sunny "
    	CLOUDY = 2,			// "Slowly falling L-Pressure ", "Cloudy/Rain "
    	UNSTABLE = 3,		// "Quickly rising H-Press",     "Not Stable"
    	THUNDERSTORM = 4,	// "Quickly falling L-Press",    "Thunderstorm"
    	UNKNOWN = 5			// "Unknown (More Time needed)
    Adafruit_BMP085 bmp = Adafruit_BMP085();      // Digital Pressure Sensor
    //int BATTERY_SENSE_PIN = A0;  // select the input pin for the battery sense point
    //int oldBatteryPcnt = 0;
    long result;
    float lastPressure = -1;
    float lastTemp = -1;
    int lastForecast = -1;
    const int LAST_SAMPLES_COUNT = 5;
    float lastPressureSamples[LAST_SAMPLES_COUNT];
    // this CONVERSION_FACTOR is used to convert from Pa to kPa in forecast algorithm
    // get kPa/h be dividing hPa by 10
    #define CONVERSION_FACTOR (1.0/10.0)
    int minuteCount = 0;
    bool firstRound = true;
    // average value is used in forecast algorithm.
    float pressureAvg;
    // average after 2 hours is used as reference value for the next iteration.
    float pressureAvg2;
    float dP_dt;
    boolean metric;
    MyMessage tempMsg(TEMP_CHILD, V_TEMP);
    MyMessage pressureMsg(BARO_CHILD, V_PRESSURE);
    MyMessage forecastMsg(BARO_CHILD, V_FORECAST);
    MyMessage battMsg(BATT_CHILD, V_VOLTAGE);
       analogReference(INTERNAL1V1);
    #else
       analogReference(INTERNAL);
    	gw.begin();
    	gw.sendSketchInfo("Pressure Sensor", "1.1");
    	if (!bmp.begin())
    		Serial.println("Could not find a valid BMP085 sensor, check wiring!");
    		while (1) {}
    	// Register sensors to gw (they will be created as child devices)
    	gw.present(BARO_CHILD, S_BARO);
    	gw.present(TEMP_CHILD, S_TEMP);
      gw.present(BATT_CHILD, S_MULTIMETER);
       // get the battery Voltage
       #ifdef DEBUG
       Serial.println(sensorValue);
       // ((305400+100000)/100000)*1.1 = Vmax = 4.46 Volts
       // 4.46/1023 = Volts per bit = 0.0043591398
       //float batteryV  = sensorValue * 0.004359140;
       float batteryV  = sensorValue * 4.2 / 1023;
       #ifdef DEBUG
       Serial.print(batteryV);
       Serial.println(" V");
       Serial.print(batteryPcnt);
       Serial.println(" %");
    	float pressure = bmp.readSealevelPressure(ALTITUDE) / 100.0;
    	float temperature = bmp.readTemperature();
    	if (!metric)
    		// Convert to fahrenheit
    		temperature = temperature * 9.0 / 5.0 + 32.0;
    	int forecast = sample(pressure);
    	Serial.print("Temperature = ");
    	Serial.print(temperature);
    	Serial.println(metric ? " *C" : " *F");
    	Serial.print("Pressure = ");
    	Serial.print(pressure);
    	Serial.println(" hPa");
    	Serial.print("Forecast = ");
    	Serial.println(weather[forecast]);
    	if (temperature != lastTemp)
    		gw.send(tempMsg.set(temperature, 1));
    		lastTemp = temperature;
    	if (pressure != lastPressure)
    		gw.send(pressureMsg.set(pressure, 1));
    		lastPressure = pressure;
    	if (forecast != lastForecast)
    		gw.send(forecastMsg.set(weather[forecast]));
    		lastForecast = forecast;
      //if (oldBatteryPcnt != batteryPcnt) {
       // Power up radio after sleep
       //gw.sendBatteryLevel(batteryPcnt);
       readVcc();
       Serial.println(result/10);
       gw.send(battMsg.set(result/1000.000, 3));
    //   oldBatteryPcnt = batteryPcnt;
    	gw.sleep(SLEEP_TIME);
    float getLastPressureSamplesAverage()
    	float lastPressureSamplesAverage = 0;
    	for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
    		lastPressureSamplesAverage += lastPressureSamples[i];
    	lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
    	return lastPressureSamplesAverage;
    // Algorithm found here
    // http://www.freescale.com/files/sensors/doc/app_note/AN3914.pdf
    // Pressure in hPa -->  forecast done by calculating kPa/h
    int sample(float pressure)
    	// Calculate the average of the last n minutes.
    	int index = minuteCount % LAST_SAMPLES_COUNT;
    	lastPressureSamples[index] = pressure;
    	minuteCount++;
    	if (minuteCount > 185)
    		minuteCount = 6;
    	if (minuteCount == 5)
    		pressureAvg = getLastPressureSamplesAverage();
    	else if (minuteCount == 35)
    		float lastPressureAvg = getLastPressureSamplesAverage();
    		float change = (lastPressureAvg - pressureAvg) * CONVERSION_FACTOR;
    		if (firstRound) // first time initial 3 hour
    			dP_dt = change * 2; // note this is for t = 0.5hour
    		else
    			dP_dt = change / 1.5; // divide by 1.5 as this is the difference in time from 0 value.
    	else if (minuteCount == 65)
    		if (firstRound) //first time initial 3 hour
    			dP_dt = change; //note this is for t = 1 hour
    		else
    			dP_dt = change / 2; //divide by 2 as this is the difference in time from 0 value
    	else if (minuteCount == 95)
    			dP_dt = change / 1.5; // note this is for t = 1.5 hour
    		else
    			dP_dt = change / 2.5; // divide by 2.5 as this is the difference in time from 0 value
    	else if (minuteCount == 125)
    		pressureAvg2 = lastPressureAvg; // store for later use.
    			dP_dt = change / 2; // note this is for t = 2 hour
    		else
    			dP_dt = change / 3; // divide by 3 as this is the difference in time from 0 value
    	else if (minuteCount == 155)
    			dP_dt = change / 2.5; // note this is for t = 2.5 hour
    		else
    			dP_dt = change / 3.5; // divide by 3.5 as this is the difference in time from 0 value
    	else if (minuteCount == 185)
    			dP_dt = change / 3; // note this is for t = 3 hour
    		else
    			dP_dt = change / 4; // divide by 4 as this is the difference in time from 0 value
    		pressureAvg = pressureAvg2; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
    		firstRound = false; // flag to let you know that this is on the past 3 hour mark. Initialized to 0 outside main loop.
    	int forecast = UNKNOWN;
    	if (minuteCount < 35 && firstRound) //if time is less than 35 min on the first 3 hour interval.
    		forecast = UNKNOWN;
    	else if (dP_dt < (-0.25))
    		forecast = THUNDERSTORM;
    	else if (dP_dt > 0.25)
    		forecast = UNSTABLE;
    	else if ((dP_dt > (-0.25)) && (dP_dt < (-0.05)))
    		forecast = CLOUDY;
    	else if ((dP_dt > 0.05) && (dP_dt < 0.25))
    		forecast = SUNNY;
    	else if ((dP_dt >(-0.05)) && (dP_dt < 0.05))
    		forecast = STABLE;
    	else
    		forecast = UNKNOWN;
    	// uncomment when debugging
    	//Serial.print(F("Forecast at minute "));
    	//Serial.print(minuteCount);
    	//Serial.print(F(" dP/dt = "));
    	//Serial.print(dP_dt);
    	//Serial.print(F("kPa/h --> "));
    	//Serial.println(weather[forecast]);
    	return forecast;
    long readVcc() {
      ADCSRA |= _BV(ADSC); // Convert
      while (bit_is_set(ADCSRA,ADSC));
      result = ADCL;
      result |= ADCH<<8;
      result = 1126400L / result; // Back-calculate AVcc in mV
      return result;
    Sensor output:
    **Temperature = 20.90 C
    Pressure = 1005.88 hPa
    Forecast = stable
    send: 2-2-0-0 s=0,c=1,t=4,pt=7,l=5,sg=0,st=fail:1005.9
    403
    send: 2-2-0-0 s=2,c=1,t=38,pt=7,l=5,sg=0,st=fail:4.037
    Pressure = 1005.90 hPa
    Forecast = stable
    403
    Pressure = 1005.81 hPa
    Forecast = stable
    send: 2-2-0-0 s=0,c=1,t=4,pt=7,l=5,sg=0,st=fail:1005.8
    403
    find parent
    send: 2-2-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
    read: 0-0-2 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    parent=0, d=1
    Pressure = 1005.92 hPa
    Forecast = stable
    send: 2-2-0-0 s=0,c=1,t=4,pt=7,l=5,sg=0,st=ok:1005.9
    403
    send: 2-2-0-0 s=2,c=1,t=38,pt=7,l=5,sg=0,st=ok:4.037
    Temperature = 21.20 *C
    Pressure = 1005.95 hPa
    Forecast = stable
    send: 2-2-0-0 s=0,c=1,t=4,pt=7,l=5,sg=0,st=ok:1006.0
    403
    Pressure = 1005.96 hPa
    Forecast = stable
    403
    Pressure = 1005.93 hPa
    Forecast = stable
    403
    Temperature = 21.20 C
    Pressure = 1006.01 hPa
    Forecast = stable
    403
    Pressure = 1005.89 hPa
    Forecast = stable
    403
    Gateway code, without any change from original sketch
     * The ArduinoGateway prints data received from sensors on the serial link.
     * The gateway accepts input on seral which will be sent out on radio network.
     * The GW code is designed for Arduino Nano 328p / 16MHz
     * Wire connections (OPTIONAL):
     * - Inclusion button should be connected between digital pin 3 and GND
     * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
     * LEDs (OPTIONAL):
    #define NO_PORTB_PINCHANGES
    #include <MySigningNone.h>
    #include <MyTransportRFM69.h>
    #include <MyTransportNRF24.h>
    #include <MyHwATMega328.h>
    #include <MySigningAtsha204Soft.h>
    #include <MySigningAtsha204.h>
    #include <MyParserSerial.h>
    #include <stdarg.h>
    #include <PinChangeInt.h>
    #include "GatewayUtil.h"
    #define INCLUSION_MODE_TIME 1 // Number of minutes inclusion mode is enabled
    #define INCLUSION_MODE_PIN  3 // Digital pin used for inclusion mode button
    #define RADIO_ERROR_LED_PIN 4  // Error led pin
    #define RADIO_RX_LED_PIN    6  // Receive led pin
    #define RADIO_TX_LED_PIN    5  // the PCB, on board LED
    MyTransportNRF24 transport(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
    //MyTransportRFM69 transport;
    // Message signing driver (signer needed if MY_SIGNING_FEATURE is turned on in MyConfig.h)
    //MySigningNone signer;
    //MySigningAtsha204Soft signer;
    //MySigningAtsha204 signer;
    // Hardware profile
    MyHwATMega328 hw;
    // Construct MySensors library (signer needed if MY_SIGNING_FEATURE is turned on in MyConfig.h)
    // To use LEDs blinking, uncomment WITH_LEDS_BLINKING in MyConfig.h
    #ifdef WITH_LEDS_BLINKING
    MySensor gw(transport, hw /*, signer*/, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
    #else
    MySensor gw(transport, hw /*, signer*/);
    char inputString[MAX_RECEIVE_LENGTH] = "";    // A string to hold incoming commands from serial/ethernet interface
    int inputPos = 0;
    boolean commandComplete = false;  // whether the string is complete
    void parseAndSend(char *commandBuffer);
    void output(const char *fmt, ... ) {
       va_list args;
       va_start (args, fmt );
       vsnprintf_P(serialBuffer, MAX_SEND_LENGTH, fmt, args);
       va_end (args);
       Serial.print(serialBuffer);
      gw.begin(incomingMessage, 0, true, 0);
      setupGateway(INCLUSION_MODE_PIN, INCLUSION_MODE_TIME, output);
      // Add interrupt for inclusion button to pin
      PCintPort::attachInterrupt(pinInclusion, startInclusionInterrupt, RISING);
      // Send startup log message on serial
      serial(PSTR("0;0;%d;0;%d;Gateway startup complete.\n"),  C_INTERNAL, I_GATEWAY_READY);
      gw.process();
      checkButtonTriggeredInclusion();
      checkInclusionFinished();
      if (commandComplete) {
        // A command wass issued from serial interface
        // We will now try to send it to the actuator
        parseAndSend(gw, inputString);
        inputPos = 0;
      SerialEvent occurs whenever a new data comes in the
     hardware serial RX.  This routine is run between each
     time loop() runs, so using delay inside loop can delay
     response.  Multiple bytes of data may be available.
    void serialEvent() {
      while (Serial.available()) {
        // get the new byte:
        char inChar = (char)Serial.read();
        // if the incoming character is a newline, set a flag
        // so the main loop can do something about it:
        if (inputPos<MAX_RECEIVE_LENGTH-1 && !commandComplete) {
          if (inChar == '\n') {
            inputString[inputPos] = 0;
            commandComplete = true;
          } else {
            // add it to the inputString:
            inputString[inputPos] = inChar;
            inputPos++;
        } else {
           // Incoming message too long. Throw away
            inputPos = 0;
    Output from Gateway not possible since it is in use by Domoticz. Of course I can disconnect it for test but I don't think Sensor will work correctly without a controller.
    Domoticz log:
    2016-01-05 14:06:15.639 (Test_First) General/Voltage (Voltage_strom)
    2016-01-05 14:08:26.481 (Test_First) General/Voltage (Voltage_strom)
    2016-01-05 14:09:32.184 (Test_First) General/Voltage (Voltage_strom)
    Missing minute 7
    Questions:
    1. Any ideas what this can be or is this normal?
    2. Why do it suddenly says Find parent, is it because it fails for both data that sensor should send? I have seen that if one fails it doesn't say Find parent.
    3. Why does it send Pressure when the code say, IF new is same as last don't send.
    EDIT: added more Sensor output
    EDIT2: distance between sensor and gateway is 1 meter
    EDIT3: add question 3
    EDIT4: Gateway as Pro Mini
    F 1 Reply Last reply
    • F
      F
      flopp
      I disconnected Serial gateway from Domoticz and it seems to work anyway, but not receive the data in Domoticz of course
      I aslo added delay(100) after each gw.send
      It seems that Gateway gets the data but not tells the sensor OK
      I also saw that there is an extra -0 at sensor data but not in gateway, BOLD below
      Gateway:
      0;0;3;0;9;read: 2-2-0 s=1,c=1,t=0,pt=7,l=5,sg=0:21.0
      2;1;1;0;0;21.0
      0;0;3;0;9;read: 2-2-0 s=0,c=1,t=4,pt=7,l=5,sg=0:1006.3
      2;0;1;0;4;1006.3
      2;0;1;0;4;1006.3
      0;0;3;0;9;read: 2-2-0 s=2,c=1,t=38,pt=7,l=5,sg=0:4.037
      2;2;1;0;38;4.037
      Sensor:
      Temperature = 21.00 *C
      Pressure = 1006.31 hPa
      Forecast = unknown
      send: 2-2-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:21.0
      send: 2-2-0-0 s=0,c=1,t=4,pt=7,l=5,sg=0,st=ok:1006.3
      403
      Pressure = 1006.29 hPa
      Forecast = unknown
      send: 2-2-0-0 s=0,c=1,t=4,pt=7,l=5,sg=0,st=fail:1006.3
      403
      • sundberg84S
        Hi!
        Do you have any caps on the radio(s)?
        • sundberg84S sundberg84
          Hi!
          F
          F
          flopp
          @sundberg84
          Yes, on both
          • F flopp
            Gateway:
            2;1;1;0;0;21.0
            2;0;1;0;4;1006.3
            2;0;1;0;4;1006.3
            2;2;1;0;38;4.037
            Sensor:
            Forecast = unknown
            403
            Forecast = unknown
            403
            F
            F
            flopp
            I saw that I had forgot to put the delay for TEMP, i add it and now it seems to be better
            • F flopp
              Controller:
              Sensor:
              Gateway:
              Serial gateway
              #include <Wire.h>
              enum FORECAST
              long result;
              float pressureAvg;
              float pressureAvg2;
              float dP_dt;
              boolean metric;
              #else
              	gw.begin();
              	if (!bmp.begin())
              		while (1) {}
                 #ifdef DEBUG
                 #ifdef DEBUG
              	if (!metric)
                 readVcc();
              	minuteCount++;
              		minuteCount = 6;
              		else
              		else
              		else
              		else
              		else
              		else
              		forecast = UNKNOWN;
              		forecast = CLOUDY;
              		forecast = SUNNY;
              		forecast = STABLE;
              	else
              		forecast = UNKNOWN;
              	return forecast;
              long readVcc() {
                result = ADCL;
                result |= ADCH<<8;
                return result;
              Sensor output:
              Forecast = stable
              403
              Forecast = stable
              403
              Forecast = stable
              403
              find parent
              parent=0, d=1
              Forecast = stable
              403
              Forecast = stable
              403
              Forecast = stable
              403
              Forecast = stable
              403
              Forecast = stable
              403
              Forecast = stable
              403
               * LEDs (OPTIONAL):
              #include <stdarg.h>
              // Hardware profile
              MyHwATMega328 hw;
              #else
              int inputPos = 0;
                 va_list args;
                 va_end (args);
                gw.process();
                  inputPos = 0;
                    } else {
                      inputPos++;
                  } else {
                      inputPos = 0;
              Domoticz log:
              Missing minute 7
              Questions:
              F
              F
              flopp
              @flopp said:
              Questions:
              3.Why does it send Pressure when the code say, IF new is same as last don't send.
              I read the code again, and I have not change this part of the code
              Pressure is a float so it will get decimals when it reads from BMP.
              This will almost every time send data because there are two decimals which will change.
              I changed it to INT instead of FLOAT and now I get value without decimals and it will not send data every loop, if it not changes of course
              • dakkyD
                dakkyD
                dakky
                did you change the caps? I had massive problem with 4,7nF Caps at my gateway: random fails when transmitting. I now use 100nF and 4,7nF at the gateway and it works like a charm
                Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
                Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
                Software: MySensors 2.0development
                • dakkyD dakky
                  F
                  F
                  flopp
                  I have not solder them there, will do now.
                  I saw some fails again :pensive: after it worked for 10-15 minutes without any fail
                  I think you mean uF not nF? Guide says uF.
                  • dakkyD
                    dakkyD
                    dakky
                    of course u're right. was a little brainf*ck ;)
                    soldering or not does not change anything as long as the parts are fixed.
                    • F
                      F
                      flopp
                      I know but I just put the cap pin in a hole of the dupont cable.
                      • rvendrameR
                        rvendrameR
                        rvendrame
                        Once I had similar problems, a 4.7nF cap and gw.wait(100) after each transmit did the trick for me... Hope it helps somehow.
                        ESP8266 GW + mySensors 2.3.2
                        Alexa / Google Home
                        F M 2 Replies Last reply
                        • rvendrameR rvendrame
                          F
                          F
                          flopp
                          @rvendrame
                          Where did you put ge.wait, sensor code or gateway code?
                          • rvendrameR
                            rvendrameR
                            rvendrame
                            @flopp said:
                            @rvendrame
                            Sensor. And capacitors on both.
                            Alexa / Google Home
                              @flopp said:
                              @rvendrame
                              F
                              F
                              flopp
                              sorry for asking so much :smile:
                              after each gw.send?
                              rvendrameR 1 Reply Last reply
                              • F flopp
                                after each gw.send?
                                rvendrameR
                                rvendrameR
                                rvendrame
                                after each gw.send?
                                Yes
                                Alexa / Google Home
                                  after each gw.send?
                                  Yes
                                  F
                                  F
                                  flopp
                                  @rvendrame said:
                                  after each gw.send?
                                  Yes
                                  • F
                                    F
                                    flopp
                                    It have now been running for 35 minutes without any error, 100uF on both NRF. Delay(100); after each gw.send. Will try later to remove that and see it the problem was the caps.
                                    Thanks everyone 👊
                                    • F
                                      F
                                      flopp
                                      During I wrote above reply it reported 3 fails!!!
                                      I hope that was just a glitch and will let it run without any changes
                                      • sundberg84S
                                        What do you power the nodes with? Since it seems to work better with caps on, there might be something to your power or wiring you can do to make it better.
                                          F
                                          F
                                          flopp
                                          I wrote it in first post, no hard feelings
                                          sensor, lipo batt
                                          gateway, usb from PC
