  3. Can't get RFM69 working
27 Posts 5 Posters 12.0k Views 3 Watching
  • SweebeeS Offline
    SweebeeS Offline
    Sweebee
    I created a gateway with the RFM69 and a sensor with it. When i look at the serial monitor from the gateway i get
    Now i try to send something like: 10;1;1;1;2;0
    then i get the startup message again:
    When i try to send something with the sensor i get the know fail message.
    When uploading the serial gateway i enabled the RFM69:
    //MyTransportNRF24 transport(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
    MyTransportRFM69 transport;
    How can i set this for the sensors?
    • C Offline
      C Offline
      carlierd
      Did you set RFM69 parameters in MyConfig.h ?
      Put your gateway and sensor code. Without it's difficult to help you.
      I spent several hours to set mine.
      David
      • SweebeeS Offline
        SweebeeS Offline
        Sweebee
        Gateway:
         * The ArduinoGateway prints data received from sensors on the serial link.
         * The gateway accepts input on seral which will be sent out on radio network.
         * The GW code is designed for Arduino Nano 328p / 16MHz
         * Wire connections (OPTIONAL):
         * - Inclusion button should be connected between digital pin 3 and GND
         * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
         * LEDs (OPTIONAL):
        #define NO_PORTB_PINCHANGES
        #include <MySigningNone.h>
        #include <MyTransportRFM69.h>
        #include <MyTransportNRF24.h>
        #include <MyHwATMega328.h>
        #include <MySigningAtsha204Soft.h>
        #include <MySigningAtsha204.h>
        #include <MyParserSerial.h>
        #include <stdarg.h>
        #include <PinChangeInt.h>
        #include "GatewayUtil.h"
        #define INCLUSION_MODE_TIME 1 // Number of minutes inclusion mode is enabled
        #define INCLUSION_MODE_PIN  3 // Digital pin used for inclusion mode button
        #define RADIO_ERROR_LED_PIN 4  // Error led pin
        #define RADIO_RX_LED_PIN    6  // Receive led pin
        #define RADIO_TX_LED_PIN    5  // the PCB, on board LED
        // Message signing driver (signer needed if MY_SIGNING_FEATURE is turned on in MyConfig.h)
        //MySigningNone signer;
        //MySigningAtsha204Soft signer;
        //MySigningAtsha204 signer;
        // Hardware profile
        MyHwATMega328 hw;
        // Construct MySensors library (signer needed if MY_SIGNING_FEATURE is turned on in MyConfig.h)
        // To use LEDs blinking, uncomment WITH_LEDS_BLINKING in MyConfig.h
        #ifdef WITH_LEDS_BLINKING
        MySensor gw(transport, hw /*, signer*/, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
        #else
        MySensor gw(transport, hw /*, signer*/);
        char inputString[MAX_RECEIVE_LENGTH] = "";    // A string to hold incoming commands from serial/ethernet interface
        int inputPos = 0;
        boolean commandComplete = false;  // whether the string is complete
        void parseAndSend(char *commandBuffer);
        void output(const char *fmt, ... ) {
           va_list args;
           va_start (args, fmt );
           vsnprintf_P(serialBuffer, MAX_SEND_LENGTH, fmt, args);
           va_end (args);
           Serial.print(serialBuffer);
          gw.begin(incomingMessage, 0, true, 0);
          setupGateway(INCLUSION_MODE_PIN, INCLUSION_MODE_TIME, output);
          // Add interrupt for inclusion button to pin
          PCintPort::attachInterrupt(pinInclusion, startInclusionInterrupt, RISING);
          // Send startup log message on serial
          serial(PSTR("0;0;%d;0;%d;Gateway startup complete.\n"),  C_INTERNAL, I_GATEWAY_READY);
          gw.process();
          checkButtonTriggeredInclusion();
          checkInclusionFinished();
          if (commandComplete) {
            // A command wass issued from serial interface
            // We will now try to send it to the actuator
            parseAndSend(gw, inputString);
            inputPos = 0;
          SerialEvent occurs whenever a new data comes in the
         hardware serial RX.  This routine is run between each
         time loop() runs, so using delay inside loop can delay
         response.  Multiple bytes of data may be available.
        void serialEvent() {
          while (Serial.available()) {
            // get the new byte:
            char inChar = (char)Serial.read();
            // if the incoming character is a newline, set a flag
            // so the main loop can do something about it:
            if (inputPos<MAX_RECEIVE_LENGTH-1 && !commandComplete) {
              if (inChar == '\n') {
                inputString[inputPos] = 0;
                commandComplete = true;
              } else {
                // add it to the inputString:
                inputString[inputPos] = inChar;
                inputPos++;
            } else {
               // Incoming message too long. Throw away
                inputPos = 0;
        Sensor (default binaryswitchsleep):
         * Interrupt driven binary switch example with dual interrupts
         * Author: Patrick 'Anticimex' Fallberg
         * Connect one button or door/window reed switch between
         * digitial I/O pin 3 (BUTTON_PIN below) and GND and the other
         * one in similar fashion on digital I/O pin 2.
         * This example is designed to fit Arduino Nano/Pro Mini
        #define SKETCH_NAME "Binary Sensor"
        #define SKETCH_MAJOR_VER "1"
        #define SKETCH_MINOR_VER "0"
        #define PRIMARY_CHILD_ID 3
        #define SECONDARY_CHILD_ID 4
        #define PRIMARY_BUTTON_PIN 2   // Arduino Digital I/O pin for button/reed switch
        #define SECONDARY_BUTTON_PIN 3 // Arduino Digital I/O pin for button/reed switch
        #if (PRIMARY_BUTTON_PIN < 2 || PRIMARY_BUTTON_PIN > 3)
        #error PRIMARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
        #if (SECONDARY_BUTTON_PIN < 2 || SECONDARY_BUTTON_PIN > 3)
        #error SECONDARY_BUTTON_PIN must be either 2 or 3 for interrupts to work
        #if (PRIMARY_BUTTON_PIN == SECONDARY_BUTTON_PIN)
        #error PRIMARY_BUTTON_PIN and BUTTON_PIN2 cannot be the same
        #if (PRIMARY_CHILD_ID == SECONDARY_CHILD_ID)
        #error PRIMARY_CHILD_ID and SECONDARY_CHILD_ID cannot be the same
        MySensor sensor_node;
        MyMessage msg(PRIMARY_CHILD_ID, V_TRIPPED);
        MyMessage msg2(SECONDARY_CHILD_ID, V_TRIPPED);
          sensor_node.begin();
          // Setup the buttons
          pinMode(PRIMARY_BUTTON_PIN, INPUT);
          pinMode(SECONDARY_BUTTON_PIN, INPUT);
          // Activate internal pull-ups
          digitalWrite(PRIMARY_BUTTON_PIN, HIGH);
          digitalWrite(SECONDARY_BUTTON_PIN, HIGH);
          sensor_node.sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER"."SKETCH_MINOR_VER);
          // Register binary input sensor to sensor_node (they will be created as child devices)
          sensor_node.present(PRIMARY_CHILD_ID, S_DOOR);
          sensor_node.present(SECONDARY_CHILD_ID, S_DOOR);
          uint8_t value;
          static uint8_t sentValue=2;
          static uint8_t sentValue2=2;
          sensor_node.sleep(5);
          value = digitalRead(PRIMARY_BUTTON_PIN);
          if (value != sentValue) {
             // Value has changed from last transmission, send the updated value
             sensor_node.send(msg.set(value==HIGH ? 1 : 0));
             sentValue = value;
          value = digitalRead(SECONDARY_BUTTON_PIN);
          if (value != sentValue2) {
             sensor_node.send(msg2.set(value==HIGH ? 1 : 0));
             sentValue2 = value;
          // Sleep until something happens with the sensor
          sensor_node.sleep(PRIMARY_BUTTON_PIN-2, CHANGE, SECONDARY_BUTTON_PIN-2, CHANGE, 0);
        And i have set the RFM in the config.h to: #define RFM69_FREQUENCY RF69_433MHZ
        • R Offline
          R Offline
          rene_2k2
          What is your hardware configuration ? Looks like the gateway is in a reset loop, no ? Possible power issue ?
          • SweebeeS Offline
            SweebeeS Offline
            Sweebee
            Arduino uno > level shifter > RFM69HW
            the level shifter / RFM is powered by a separate 5 > 3.3v converter.
            • C Offline
              C Offline
              carlierd
              hello,
              How did you powered the rfm69 on the uno ? using the 3.3 from the uno or using a voltage regulator ?
              I first used voltage regulator but I encountered some issues with the uno so I finally directly used the 3.3 from the uni board.
              another thing, remove not used include such 'MyTransportNRF24' in your code.
              I will post my gateway and sensor code thus evening as I can't do it from my phone now ...
              • SweebeeS Offline
                SweebeeS Offline
                Sweebee
                The RFM is powered by the regulator. Havent tried to power it from the 3v from the arduino yet.
                • C Offline
                  C Offline
                  carlierd
                  The code as promise.
                  For the gateway I don't change a lot of thing from the example provided in the lib:
                  /* Serial gateway (RFM69 with encryption, soft signing and LEDs).                     */
                  /* Version     : 0.1.1        */
                  /* Date        : 29/11/2015                                                           */
                  /* Modified by : David Carlier                                                        */
                  #include <stdarg.h>
                  //Construct MySensors library
                  MyHwATMega328 hw;
                  MySensor gw(transport, hw, signer, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
                  //Variables
                  int inputPos = 0;
                     va_list args;
                     va_end (args);
                  /* Initialization        */
                    //Start MySensors
                    //Add interrupt for inclusion button to pin
                    //Send startup log message on serial
                  /* Main loop        */
                    gw.process();
                      //A command wass issued from serial interface
                      //We will now try to send it to the actuator
                      inputPos = 0;
                        } else {
                          inputPos++;
                      } else {
                          inputPos = 0;
                  For the sensor, there is more difference from the humidity example:
                  /* Temperature, humidity and luminosity measurements.                                 */
                  /* Version     : 1.1.5        */
                  /* Date        : 04/01/2016                                                           */
                  /*                            RST |             |  A5                                 */
                  /*                            RX  |             |  A4                                 */
                  /*                            TX  |   ARDUINO   |  A3                                 */
                  /*     RFM69 (DIO0) --------- D2  |     UNO     |  A2                                 */
                  /*            DHT22 --------- D3  |             |  A1                                 */
                  /*            Power --------- D4  | ATMEGA 328p |  A0 --------- Light dep. resistor   */
                  /*              +3v --------- VCC |             | GND --------- GND                   */
                  /*              GND --------- GND |  8MHz int.  | REF                                 */
                  /*                            OSC |             | VCC --------- +3v                   */
                  /*                            OSC |             | D13 --------- RFM69 (SCK)           */
                  /*                            D5  |             | D12 --------- RFM69 (MISO)          */
                  /*                            D6  |             | D11 --------- RFM69 (MOSI)          */
                  /*                            D7  |             | D10 --------- RFM69 (NSS)           */
                  /*                            D8  |             |  D9                                 */
                  /* Power = Vcc for LDR and DHT22 et SWITCH.                                           */
                  /* +3v = 2*AA        */
                  #include <dht.h>
                  #define CHILD_ID_HUM 0
                  #define CHILD_ID_TEMP 1
                  #define CHILD_ID_LIGHT 2
                  #define CHILD_ID_VOLTAGE 3
                  #define LIGHT_SENSOR_ANALOG_PIN 0
                  #define POWER_PIN 4
                  unsigned long SLEEP_TIME = 275000; // Sleep time between reads (in milliseconds)
                  MyHwATMega328 hw;
                  MySensor gw(transport, hw, signer);
                  dht DHT;
                  MyMessage msgLum(CHILD_ID_LIGHT, V_LEVEL);
                  MyMessage msgVolt(CHILD_ID_VOLTAGE, V_VOLTAGE);
                    //Get time (for setup duration)
                    #ifdef DEBUG
                      unsigned long startTime = millis();
                    //Start MySensors
                    gw.begin();
                    //Send the Sketch Version Information to the Gateway
                    gw.sendSketchInfo("GHAS sensor", "1.1.5");
                    //Register all sensors to gw (they will be created as child devices)
                    gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
                    gw.present(CHILD_ID_VOLTAGE, S_MULTIMETER);
                    //Delay for DHT22
                    delay(1500);
                    //Print setup debug
                    #ifdef DEBUG
                      int duration = millis() - startTime;
                      Serial.print("[Setup duration: "); Serial.print(duration, DEC); Serial.println(" ms]");
                  /* Main loop        */
                    //Get time (for a complete loop)
                    #ifdef DEBUG
                    //Power on
                    powerOnPeripherals();
                    delay(2000);
                    //Get DHT22 data
                    int dht22Result = DHT.read22(HUMIDITY_SENSOR_DIGITAL_PIN);
                    switch (dht22Result)
                      case DHTLIB_OK:
                                  //Serial.println("OK,\t");
                                  break;
                      case DHTLIB_ERROR_CHECKSUM:
                                  #ifdef DEBUG
                                    Serial.println("Checksum error,\t");
                                  break;
                      case DHTLIB_ERROR_TIMEOUT:
                                  #ifdef DEBUG
                                    Serial.println("Time out error,\t");
                                  break;
                      case DHTLIB_ERROR_CONNECT:
                                  #ifdef DEBUG
                                    Serial.println("Connect error,\t");
                                  break;
                      case DHTLIB_ERROR_ACK_L:
                                  #ifdef DEBUG
                                    Serial.println("Ack Low error,\t");
                                  break;
                      case DHTLIB_ERROR_ACK_H:
                                  #ifdef DEBUG
                                    Serial.println("Ack High error,\t");
                                  break;
                      default:
                                  #ifdef DEBUG
                                    Serial.println("Unknown error,\t");
                                  break;
                    //Get temperature and humidity
                    float temperature = 0;
                    float humidity = 0;
                    if (dht22Result == DHTLIB_OK)
                      temperature = DHT.temperature;
                      humidity = DHT.humidity;
                    //Get power before luminosity to use real voltage
                    float realVoltage = getVoltage() / 100.0;
                    int batteryPcnt = realVoltage * 100 / 3.0;
                    if (batteryPcnt > 100) {batteryPcnt = 100;}
                    int lux = computeIlluminance(realVoltage);
                    //Power off
                    powerOffPeripherals();
                    //Send data to gateway
                    gw.send(msgLum.set(lux));
                    gw.send(msgVolt.set(realVoltage, 2));
                    //Print debug
                    #ifdef DEBUG
                      Serial.print(temperature, 1);
                      Serial.print(" degC");
                      Serial.print("   ");
                      Serial.print(humidity, 1);
                      Serial.print(" %");
                      Serial.print("   ");
                      Serial.print(lux);
                      Serial.print(" lx");
                      Serial.print("   ");
                      Serial.print(realVoltage);
                      Serial.print(" v");
                      Serial.print("   ");
                      Serial.print("["); Serial.print(duration, DEC); Serial.println(" ms]");
                      Serial.flush();
                    //Sleep
                    gw.sleep(SLEEP_TIME);
                  /* Allows to compute illuminance (in LUX) from LIGHT_SENSOR_ANALOG_PIN.               */
                  int computeIlluminance(float realVoltage)
                    //Get luminosity
                    int luminosity = analogRead(LIGHT_SENSOR_ANALOG_PIN);
                    //Calculating the voltage in the input of the ADC
                    double voltage = realVoltage * ((double)luminosity / 1024.0);
                    //Calculating the resistance of the photoresistor in the voltage divider
                    double resistance = (10.0 * realVoltage) / voltage - 10.0;
                    //Calculating the intensity of light in lux and return it
                    int illuminance = 255.84 * pow(resistance, -10/9);
                    return illuminance;
                  /* Allows to get the real Vcc (return value * 100).                                   */
                  int getVoltage()
                    const long InternalReferenceVoltage = 1056L;
                    ADMUX = (0<<REFS1) | (1<<REFS0) | (0<<ADLAR) | (1<<MUX3) | (1<<MUX2) | (1<<MUX1) | (0<<MUX0);
                    delay(50);  // Let mux settle a little to get a more stable A/D conversion
                    //Start a conversion
                    ADCSRA |= _BV( ADSC );
                    //Wait for it to complete
                    while (((ADCSRA & (1<<ADSC)) != 0));
                    //Scale the value
                    int result = (((InternalReferenceVoltage * 1023L) / ADC) + 5L) / 10L;
                    return result;
                  /* Allows to power ON peripherals.                                                    */
                  void powerOnPeripherals()
                    //Power-up
                    pinMode (POWER_PIN, OUTPUT);
                    digitalWrite (POWER_PIN, HIGH);
                    delay(1);
                  /* Allows to power OFF peripherals.                                                   */
                  void powerOffPeripherals()
                    //Power off
                    digitalWrite (HUMIDITY_SENSOR_DIGITAL_PIN, LOW);
                    digitalWrite (POWER_PIN, LOW);
                    pinMode (HUMIDITY_SENSOR_DIGITAL_PIN, INPUT);
                    pinMode (POWER_PIN, INPUT);
                  David
                  SweebeeS 1 Reply Last reply
                  • SweebeeS Offline
                    SweebeeS Offline
                    Sweebee
                    Thanks, will try it :)
                    • L Offline
                      L Offline
                      lafleur
                      How do you change I/O pins define for the RFM69 if using a different platform??
                      will this work under 1.6 development ?
                      • C carlierd
                        #include <stdarg.h>
                        MyHwATMega328 hw;
                        //Variables
                        int inputPos = 0;
                           va_list args;
                           va_end (args);
                          //Start MySensors
                        /* Main loop        */
                          gw.process();
                            inputPos = 0;
                              } else {
                                inputPos++;
                            } else {
                                inputPos = 0;
                        /*                            RST |             |  A5                                 */
                        /*                            RX  |             |  A4                                 */
                        /*                            D8  |             |  D9                                 */
                        /* +3v = 2*AA        */
                        #include <dht.h>
                        #define POWER_PIN 4
                        MyHwATMega328 hw;
                        dht DHT;
                          #ifdef DEBUG
                          //Start MySensors
                          gw.begin();
                          //Delay for DHT22
                          delay(1500);
                          //Print setup debug
                          #ifdef DEBUG
                        /* Main loop        */
                          #ifdef DEBUG
                          //Power on
                          delay(2000);
                          //Get DHT22 data
                            case DHTLIB_OK:
                                        break;
                                        #ifdef DEBUG
                                        break;
                                        #ifdef DEBUG
                                        break;
                                        #ifdef DEBUG
                                        break;
                                        #ifdef DEBUG
                                        break;
                                        #ifdef DEBUG
                                        break;
                            default:
                                        #ifdef DEBUG
                                        break;
                          float humidity = 0;
                          //Power off
                          //Print debug
                          #ifdef DEBUG
                            Serial.print("   ");
                            Serial.print(" %");
                            Serial.print("   ");
                            Serial.print(lux);
                            Serial.print("   ");
                            Serial.print(" v");
                            Serial.print("   ");
                            Serial.flush();
                          //Sleep
                          //Get luminosity
                          return illuminance;
                        int getVoltage()
                          //Scale the value
                          return result;
                          //Power-up
                          delay(1);
                          //Power off
                        David
                        SweebeeS Offline
                        SweebeeS Offline
                        Sweebee
                        @carlierd I tried to compile your gateway but i get this error:
                        Arduino: 1.6.5 (Mac OS X), Board:"Arduino Uno"
                        SerialGateway:52: error: no matching function for call to 'MySensor::MySensor(MyTransportRFM69&, MyHwATMega328&, MySigningAtsha204Soft&, int, int, int)'
                        SerialGateway.ino:52:91: note: candidates are:
                        In file included from SerialGateway.ino:37:0:
                        /Users/Wiebe/Documents/Arduino/libraries/MySensors/MySensor.h:158:2: note: MySensor::MySensor(MyTransport&, MyHw&)
                          MySensor(MyTransport &radio =*new MyTransportNRF24(), MyHw &hw=*new MyHwDriver()
                        /Users/Wiebe/Documents/Arduino/libraries/MySensors/MySensor.h:158:2: note:   candidate expects 2 arguments, 6 provided
                        /Users/Wiebe/Documents/Arduino/libraries/MySensors/MySensor.h:149:7: note: MySensor::MySensor(const MySensor&)
                         class MySensor
                        /Users/Wiebe/Documents/Arduino/libraries/MySensors/MySensor.h:149:7: note:   candidate expects 1 argument, 6 provided
                        • C Offline
                          C Offline
                          carlierd
                          I am using stable version of MySensors not the dev branch. What version are you using ?
                          David
                          • C carlierd
                            David
                            SweebeeS Offline
                            SweebeeS Offline
                            Sweebee
                            @carlierd 1.5 https://github.com/mysensors/Arduino/tree/master
                            • C Offline
                              C Offline
                              carlierd
                              Did you enabled signing feature in MyConfig.h : #define MY_SIGNING_FEATURE ??
                              • SweebeeS Offline
                                SweebeeS Offline
                                Sweebee
                                I think the gateway works now, i removed the separate 5-3.3v converter and used the arduino 3.3v.
                                Now the sensor, i uploaden your sketch, but i get no init message?
                                • C Offline
                                  C Offline
                                  carlierd
                                  Did you connect the gateway to a controller ? or to MYSController ? You get the gateway ready message ?
                                  For the sensor, you are using the sketch I upload ?
                                  Debug mode is enable in MyConfig.h ?
                                  You should have some debug messages in the console when connecting to the node.
                                  David.
                                  • SweebeeS Offline
                                    SweebeeS Offline
                                    Sweebee
                                    wrote on last edited by Sweebee
                                    The problem is on the uno everything seems to work fine.
                                    for the sensor i attached the RFM to a arduino pro mini 3.3v
                                    double checked the wiring, tried 2 different RFM's, tried 2 arduino pro mini's.
                                    uploaden the gateway to it and i get:
                                    but when i try to send something with the pro mini i get nothing back, while on the UNO I get:
                                    0;0;3;0;9;send: 0-0-10-10 s=1,c=1,t=2,pt=0,l=1,sg=0,st=fail:1
                                    So on the pro mini i get the init message, but no message when i try to send something.
                                    • C Offline
                                      C Offline
                                      carlierd
                                      RFM69 or RFM69HW ?
                                      For RFM69HW you have to modify MyTransportRFM69.hand enable HW model on line 33.
                                      Replace bool isRFM69HW=falseby bool isRFM69HW=true.
                                      Nothing on the serial output of the pro mini ??
                                      • F Offline
                                        F Offline
                                        fets
                                        Do you use 4.7uF capacitor ?
                                        • SweebeeS Offline
                                          SweebeeS Offline
                                          Sweebee
                                          Yes i have the HW versions, so i replaced bool isRFM69HW=false by bool isRFM69HW=true
                                          added a capacitor.
                                          refreshed and still no feedback after sending.
                                          I get a serial output from the pro mini on start. but no more serial messages when i try to send a message.
