  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 255.8k Views 53 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    I have used my sensebender gateway for more than a year now, only difference is that I use NRF24 radio.. Haven't had any hickups yet..
    Which version of mysensors are you using?
    • F
      F
      Fabien
      I'm using version 2.1
      • tbowmoT
        tbowmoT
        tbowmo
        @Fabien
        Could you try the latest dev, and see how that behaves?
        • F
          F
          Fabien
          @tbowmo : with wich RFM69 driver ?
          tbowmoT 1 Reply Last reply
          • F Fabien
            tbowmoT
            tbowmoT
            tbowmo
            @Fabien legacy, unless you would reflash all your nodes with the new driver as well. (they are not compatible)
            F 1 Reply Last reply
            • F
              F
              Fabien
              @tbowmo : Just flash my SBGW today with arduino 1.8.5, last boards.txt and dev branch of mysensors.
              We will see if it's more stable. All my Node still in 2.1.1
              • stefaanvS
                stefaanvS
                stefaanv
                Which driver to use on Ubuntu 16.04 ?
                • stefaanvS
                  stefaanvS
                  stefaanv
                  Hi, I'm trying to activate a sensebender gateway in OH2 on Ubuntu 16.04, however I'm having trouble setting up the serial port. Is there a how-to somewhere ? I suspect the serial port name is /dev/ttyACM0, but I'm not sure. How can I test ?
                  MySensors bundle is reported to be active, but there's no messages coming in. I set the log level for mysensors to DEBUG, but nothing on the log.
                  • stefaanvS
                    stefaanvS
                    stefaanv
                    Here is my configuration file (mysensors.things)
                    Bridge mysensors:bridge-ser:gateway [ serialPort="/dev/ttyACM0", sendDelay=200 ]
                    humidity keuken_vochtigheid [ nodeId="3", childId="2", smartSleep=true ]
                    temperature keuken_temperatuur [ nodeId="3", childId="1", smartSleep=true ]
                    I suppose ttyACM0 because of
                    stefaan@home:~$ dmesg |grep -i tty
                    [ 0.000000] console [tty0] enabled
                    [ 22.328631] 8086228A:00: ttyS4 at MMIO 0x81420000 (irq = 39, base_baud = 2764800) is a 16550A
                    [ 22.329059] 8086228A:01: ttyS5 at MMIO 0x8141e000 (irq = 40, base_baud = 2764800) is a 16550A
                    [ 23.106128] usb 1-4: FTDI USB Serial Device converter now attached to ttyUSB0
                    [362074.592743] cdc_acm 1-3:1.0: ttyACM0: USB ACM device
                    There seems to be a premissions problem om the port :
                    stefaan@home:~$ cat /dev/ttyACM0
                    cat: /dev/ttyACM0: Permission denied
                    doing 'sudo usermod -a -G dialout openhab' doesn't help
                    Anyone any ideas ?
                    • stefaanvS
                      stefaanvS
                      stefaanv
                      ttyUSB0 is a (different) RFXcom device
                      • stefaanvS stefaanv
                        Anyone any ideas ?
                        zboblamontZ
                        zboblamontZ
                        zboblamont
                        @stefaanv I can only suggest scanning the ports. When I connected the Gateway to the Pi3 it came up with /dev/ttyS0 instead of the listed options, although I ultimately ended up changing to a Pro-Mini as the radio did not work, and connected direct to the GPIO the serial port it worked with.
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          it should pop up as ttyACM0 or ttyACM1 (if you have another usb device that enumerates first and gets ttyACM0)
                          I added the following to /etc/udev/rules.d/10-local.rules file:
                          ACTION=="add", ATTRS{idVendor}=="1209", ATTRS{idProduct}=="6949", SYMLINK+="ttyNRF24"
                          What that does is to create a symlink from the real device to ttyNRF24, so regardless of what I add to my rPI, i always know that ttyNRF24 is for my gateway.
                          (and then I use /dev/ttyNRF24 for the serial port in my controller)
                          stefaanvS 1 Reply Last reply
                          • tbowmoT tbowmo
                            stefaanvS
                            stefaanvS
                            stefaanv
                            @tbowmo Definately ttyACM0
                            However, the setserial command returns information that doesn't look good : port0 and IRQ0. Does the board need a driver under Linux ?
                            stefaan@home:~$ sudo setserial /dev/ttyACM0
                            /dev/ttyACM0, UART: unknown, Port: 0x0000, IRQ: 0, Flags: low_latency```
                            • tbowmoT
                              tbowmoT
                              tbowmo
                              @stefaanv
                              No, it doesn't need a driver..
                              I get the same for mine, if I use setserial:
                              thomas at jarvis in ~
                              >sudo setserial /dev/ttyNRF24
                              /dev/ttyNRF24, UART: unknown, Port: 0x0000, IRQ: 0, Flags: low_latency
                              >ll /dev/ttyNRF24
                              lrwxrwxrwx 1 root root 7 nov 11 13:39 /dev/ttyNRF24 -> ttyACM1
                              Btw. the permission problem.. You are logged in using your normal user (stefaan) and then you set permissions for openhab user? (see below). Have you tried setting the permissions for your user, and then cat /dev/ttyACM0?
                              @stefaanv said in 💬 Sensebender Gateway:
                              Anyone any ideas ?
                              • tbowmoT tbowmo
                                @stefaanv
                                >ll /dev/ttyNRF24
                                Anyone any ideas ?
                                stefaanvS
                                stefaanvS
                                stefaanv
                                @tbowmo OK, is working now after restarting the bundle in OH.
                                Must have been the permission problem after all.
                                Thanks for your help !!
                                • rzyliusR
                                  rzyliusR
                                  rzylius
                                  When I try to compile SensebenderGW sketch with signing features, I receive a bunch of errors. What am I missing?
                                  Arduino: 1.8.5 (Windows Store 1.8.10.0) (Windows 10), Board: "Sensebender Gateway"
                                  In file included from C:\Users\rzylius\AppData\Local\Temp\arduino_modified_sketch_737033\SensebenderGatewaySerial.ino:88:0:
                                  C:\Users\rzylius\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:6:16: error: redefinition of 'uint8_t device_pin'
                                  static uint8_t device_pin;
                                  In file included from C:\Users\rzylius\Documents\Arduino\libraries\MySensors/MySensors.h:131:0,
                                               from C:\Users\rzylius\AppData\Local\Temp\arduino_modified_sketch_737033\SensebenderGatewaySerial.ino:86:
                                  C:\Users\rzylius\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:6:16: error: 'uint8_t device_pin' previously declared here
                                  C:\Users\rzylius\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'void swi_set_signal_pin(uint8_t)':
                                  C:\Users\rzylius\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:24:13: error: redefinition of 'void swi_set_signal_pin(uint8_t)'
                                  static void swi_set_signal_pin(uint8_t is_high)
                                  C:\Users\rzylius\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:24:13: error: 'void swi_set_signal_pin(uint8_t)' previously defined here
                                  and the same type of errors reoccurs multiple times.
                                  AnticimexA 1 Reply Last reply
                                  • rzyliusR rzylius
                                    AnticimexA
                                    AnticimexA
                                    Anticimex
                                    @rzylius I think you have an #include in the sketch for the atsha driver. Try to remove that #include from the sketch.
                                    • rzyliusR
                                      rzyliusR
                                      rzylius
                                      @Anticimex yes, when I delete #include atsha driver line, it compiles well. thanks.
                                      • tbowmoT tbowmo
                                        F
                                        F
                                        Fabien
                                        @tbowmo After 2 month on the dev version, no more problem with the gateway. Perhaps it's time to made a new stable release ?
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @Fabien
                                          It's on the todo list.. :)
