  3. 💬 Sensebender Gateway
mysensorsgatewaysamd
382 Posts 59 Posters 257.0k Views 53 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    @Fabien
    Could you try the latest dev, and see how that behaves?
    • F
      F
      Fabien
      @tbowmo : with wich RFM69 driver ?
      tbowmoT 1 Reply Last reply
      • F Fabien
        tbowmoT
        tbowmoT
        tbowmo
        @Fabien legacy, unless you would reflash all your nodes with the new driver as well. (they are not compatible)
        F 1 Reply Last reply
        • F
          F
          Fabien
          @tbowmo : Just flash my SBGW today with arduino 1.8.5, last boards.txt and dev branch of mysensors.
          We will see if it's more stable. All my Node still in 2.1.1
          • stefaanvS
            stefaanvS
            stefaanv
            Which driver to use on Ubuntu 16.04 ?
            • stefaanvS
              stefaanvS
              stefaanv
              Hi, I'm trying to activate a sensebender gateway in OH2 on Ubuntu 16.04, however I'm having trouble setting up the serial port. Is there a how-to somewhere ? I suspect the serial port name is /dev/ttyACM0, but I'm not sure. How can I test ?
              MySensors bundle is reported to be active, but there's no messages coming in. I set the log level for mysensors to DEBUG, but nothing on the log.
              • stefaanvS
                stefaanvS
                stefaanv
                Here is my configuration file (mysensors.things)
                Bridge mysensors:bridge-ser:gateway [ serialPort="/dev/ttyACM0", sendDelay=200 ]
                humidity keuken_vochtigheid [ nodeId="3", childId="2", smartSleep=true ]
                temperature keuken_temperatuur [ nodeId="3", childId="1", smartSleep=true ]
                I suppose ttyACM0 because of
                stefaan@home:~$ dmesg |grep -i tty
                [ 0.000000] console [tty0] enabled
                [ 22.328631] 8086228A:00: ttyS4 at MMIO 0x81420000 (irq = 39, base_baud = 2764800) is a 16550A
                [ 22.329059] 8086228A:01: ttyS5 at MMIO 0x8141e000 (irq = 40, base_baud = 2764800) is a 16550A
                [ 23.106128] usb 1-4: FTDI USB Serial Device converter now attached to ttyUSB0
                [362074.592743] cdc_acm 1-3:1.0: ttyACM0: USB ACM device
                There seems to be a premissions problem om the port :
                stefaan@home:~$ cat /dev/ttyACM0
                cat: /dev/ttyACM0: Permission denied
                doing 'sudo usermod -a -G dialout openhab' doesn't help
                Anyone any ideas ?
                • stefaanvS
                  stefaanvS
                  stefaanv
                  ttyUSB0 is a (different) RFXcom device
                  • stefaanvS stefaanv
                    Anyone any ideas ?
                    zboblamontZ
                    zboblamontZ
                    zboblamont
                    @stefaanv I can only suggest scanning the ports. When I connected the Gateway to the Pi3 it came up with /dev/ttyS0 instead of the listed options, although I ultimately ended up changing to a Pro-Mini as the radio did not work, and connected direct to the GPIO the serial port it worked with.
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      it should pop up as ttyACM0 or ttyACM1 (if you have another usb device that enumerates first and gets ttyACM0)
                      I added the following to /etc/udev/rules.d/10-local.rules file:
                      ACTION=="add", ATTRS{idVendor}=="1209", ATTRS{idProduct}=="6949", SYMLINK+="ttyNRF24"
                      What that does is to create a symlink from the real device to ttyNRF24, so regardless of what I add to my rPI, i always know that ttyNRF24 is for my gateway.
                      (and then I use /dev/ttyNRF24 for the serial port in my controller)
                      stefaanvS 1 Reply Last reply
                      • tbowmoT tbowmo
                        stefaanvS
                        stefaanvS
                        stefaanv
                        @tbowmo Definately ttyACM0
                        However, the setserial command returns information that doesn't look good : port0 and IRQ0. Does the board need a driver under Linux ?
                        stefaan@home:~$ sudo setserial /dev/ttyACM0
                        /dev/ttyACM0, UART: unknown, Port: 0x0000, IRQ: 0, Flags: low_latency```
                        • tbowmoT
                          tbowmoT
                          tbowmo
                          @stefaanv
                          No, it doesn't need a driver..
                          I get the same for mine, if I use setserial:
                          thomas at jarvis in ~
                          >sudo setserial /dev/ttyNRF24
                          /dev/ttyNRF24, UART: unknown, Port: 0x0000, IRQ: 0, Flags: low_latency
                          >ll /dev/ttyNRF24
                          lrwxrwxrwx 1 root root 7 nov 11 13:39 /dev/ttyNRF24 -> ttyACM1
                          Btw. the permission problem.. You are logged in using your normal user (stefaan) and then you set permissions for openhab user? (see below). Have you tried setting the permissions for your user, and then cat /dev/ttyACM0?
                          @stefaanv said in 💬 Sensebender Gateway:
                          Anyone any ideas ?
                          • tbowmoT tbowmo
                            @stefaanv
                            >ll /dev/ttyNRF24
                            Anyone any ideas ?
                            stefaanvS
                            stefaanvS
                            stefaanv
                            @tbowmo OK, is working now after restarting the bundle in OH.
                            Must have been the permission problem after all.
                            Thanks for your help !!
                            • rzyliusR
                              rzyliusR
                              rzylius
                              When I try to compile SensebenderGW sketch with signing features, I receive a bunch of errors. What am I missing?
                              Arduino: 1.8.5 (Windows Store 1.8.10.0) (Windows 10), Board: "Sensebender Gateway"
                              In file included from C:\Users\rzylius\AppData\Local\Temp\arduino_modified_sketch_737033\SensebenderGatewaySerial.ino:88:0:
                              C:\Users\rzylius\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:6:16: error: redefinition of 'uint8_t device_pin'
                              static uint8_t device_pin;
                              In file included from C:\Users\rzylius\Documents\Arduino\libraries\MySensors/MySensors.h:131:0,
                                           from C:\Users\rzylius\AppData\Local\Temp\arduino_modified_sketch_737033\SensebenderGatewaySerial.ino:86:
                              C:\Users\rzylius\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:6:16: error: 'uint8_t device_pin' previously declared here
                              C:\Users\rzylius\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp: In function 'void swi_set_signal_pin(uint8_t)':
                              C:\Users\rzylius\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:24:13: error: redefinition of 'void swi_set_signal_pin(uint8_t)'
                              static void swi_set_signal_pin(uint8_t is_high)
                              C:\Users\rzylius\Documents\Arduino\libraries\MySensors/drivers/ATSHA204/ATSHA204.cpp:24:13: error: 'void swi_set_signal_pin(uint8_t)' previously defined here
                              and the same type of errors reoccurs multiple times.
                              AnticimexA 1 Reply Last reply
                              • rzyliusR rzylius
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @rzylius I think you have an #include in the sketch for the atsha driver. Try to remove that #include from the sketch.
                                • rzyliusR
                                  rzyliusR
                                  rzylius
                                  @Anticimex yes, when I delete #include atsha driver line, it compiles well. thanks.
                                  • tbowmoT tbowmo
                                    F
                                    F
                                    Fabien
                                    @tbowmo After 2 month on the dev version, no more problem with the gateway. Perhaps it's time to made a new stable release ?
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @Fabien
                                      It's on the todo list.. :)
                                        I am looking for Gateway that will get me the results to MQTT but will support encryption + signing. That mean it should be easy to add new signatures (recompile/reflash) the module
                                        I suppose if I use Sensebender with LAN module it will be a pain to do that
                                        Is this doable if I use Orange zero as USB host for the Sensbender and let it act as serial gateway, then convert serial to mqtt with software on the Linux side? Also is it possible to reflash it easily this way? I do not want to rewire the hardware each time a add new node.
                                        • tbowmoT
                                          tbowmoT
                                          tbowmo
                                          @8667
                                          Is it over the air encryption / signing that you are aiming after? Then that is possible with the gateway, it has the ATSHA204 onboard for signing capabilities. And it also works with the W5100 module attached. The Gateway have 256Kb of flash onboard, so it has "enough" room for both network stack, and signing.
