  3. livolo Glass Panel Touch Light Wall Switch + arduino 433Mhz
135 Posts 31 Posters 135.4k Views 44 Watching
  • Nca78N
    Nca78N
    @Markhill it cannot work, this board needs external power because the ESP8266 he is using is too power hungry, the switch cannot provide enough power. And this board is sized for EU switch it will not work with US or US/AU switch.
    I'm working on 3 buttons and 4 buttons version with atmega and nrf24, power from the swith is enough so it's just a plug&play replacement. I'm testing the 3 buttons switch at the moment (same layout than 1 button in which only the center button is connected). It will be cheaper than 15$ if you solder it yourself, if you don't want to do smd soldering we can probably find a solution for pre-assembled boards.
    M A 2 Replies Last reply
    • Nca78N Nca78
      Markhill
      @Nca78 I'm in. Plug and play, same size, no external power and cheaper too. When will it be ready?
      Btw, your board will be able fit on a 3 buttons and 4 buttons too right? I got them.
      Will it provide status feed back, control remotely on phone app or ioBroker and is there any coding required?
      Nca78N 1 Reply Last reply
      • S
        Samuel235
        Keep us updated on your development, i'm working on a double relay module for lighting but i doubt its going to fit inside of a single gang wall box.
        MySensors 2.1.1
        • M Markhill
          Nca78N
          Nca78N
          @Markhill I have made 2 boards, one for 1/3 buttons, one for 4 buttons.
          It will be a MySensors actuator so yes status feedback etc.
          I'll make a script for basic switch function and probably a few extra things two. I'm planning to use 3 button switches in my home to command 2 light circuits with the top and bottom buttons, and AC with center button (not using the relay). I have included 2 extra leds on center button for that, to select different modes of AC.
          The 4 buttons version uses sx1509 extender to have more advanced feedback like breathing/flashing LEDs but it's probably not in a final form yet, it will take more time to be ready.
          M 1 Reply Last reply
            Markhill
            wrote on last edited by Markhill
            #85
            Here are pictures of the US/AU 2 switch main board
            Here is a 4 gang US/AU
            Here is a 3 Gang US/AU
            • Nca78N Nca78
              Markhill
              @Nca78 said in livolo Glass Panel Touch Light Wall Switch + arduino 433Mhz:
              Can you send me the 1/3 buttons so I can test it?
              The switch I use at home is a 3 gang 2 way. That is one light control by two switches. Will your board still work with these?
              Thanks.
              • M Markhill
                Thanks.
                Nca78N
                Nca78N
                I don't know about the 2 way switches so don't have one to check. But in my home I will just connect one side to a normal switch and use switch on the other side as radio switch only without the relay.
                You want a 1/3 switch PCB ? Where do you live ?
                • S
                  Samuel235
                  Do you guys happen to know what the capacitive touch button part is called? I'm trying to look for some of these on the internet and getting nothing relevant coming up. Just the little glass/acrylic parts of the livolo switches that recognise your touch.
                  MySensors 2.1.1
                  • S Samuel235
                    Nca78N
                    Nca78N
                    @Samuel235 there is no "capacitive touch button part", the touch function is managed directly by the IC of the board.
                    So they just have an electrode (big circle of copper) connected to an IC pin and a plastic circle glued to it to have more even light from the led.
                    What I am using is TTP223N (N version is more sensible) which is both very cheap and very easy to use
                    S 1 Reply Last reply
                    • Nca78N Nca78
                      Samuel235
                      #90
                      Not sure I completely get what you mean, but I will have a search for how these little IC's work. Their datasheet looks pretty nice tbh, small, low cost, easy to get. Do they basically look for a 'press' on their input and then output 1 or 0 to a MCU, one on each button too, correct?
                      MySensors 2.1.1
                      • S Samuel235
                        Nca78N
                        Nca78N
                        @Samuel235 They just have one output. You can have them work in "toggle" mode (press to set output high, press again to set output low) or in "normal" mode (default behavior) then output is high when touch is detected.
                        So yes, one ttp223 on each button. You can use other ics (TTP224 with 4 touch inputs for example) but I prefer TTP223 as you can put it very close to the touch electrode to avoid interferences.
                        TTP223 is the IC that is used in all the cheap "one touch button" breakout boards on ebay/aliexpress/...
                        S A 2 Replies Last reply
                        • Nca78N Nca78
                          Samuel235
                          #92
                          @Nca78 - These little beauties are perfect! I feel a light switch project coming on myself.... How is your development coming on?
                          Have you seen this: https://forum.mysensors.org/topic/4317/us-decora-style-wall-switch
                          Looks like it could be neat. But, not touch. Not sure what i would prefer tbh. Either way, i have myself a dual relay board that i'm in the finishing touches too before posting it up here and on Openhardware.IO.
                          How're you going about your switching, are you switching AC in the light switch, powering this from AC or DC or are you powering by battery and emitting wireless signals to the gateway to then switch relays not connected to this board?
                          MySensors 2.1.1
                          • Nca78N
                            Nca78N
                            I'm keeping the relays from the original livolo switch. My goal is to still have basic switch functionality even if the controller box and gateway are switched off/dead. This is only possible if the switch and the relay are physically connected.
                            For the progress well I soldered all components on a first board and tested MySensors connexion and touch functions+led indicators and it's all fine.
                            Tomorrow I'll update the script to manage the relays and test on the real switch.
                            • Nca78N Nca78
                              Samuel235
                              @Nca78 - Keep us posted with images too if you could. Rather interested in your module!
                              MySensors 2.1.1
                              • Nca78N Nca78
                                A
                                A
                                achurak1
                                wrote on last edited by achurak1
                                #95
                                @Nca78, does that mean I can send high from arduino to this electrode thus imitating the touch? If so, would it be easier to do that or send the high/low directly to the HC238 (to A0 - A2)? It seems that in the first case I can also easily control the dimming function by keeping high for a few seconds. Is there a way to control dimming directly through HC238?
                                And an unrelated question, will you be able to sell these replacement PCBs you're working on right now and when? I'm not sure I will have enough patience to solder arduinos/radios to dozens of the switches, so I'd rather buy your plug-n-play solution if the price is reasonable.
                                • A achurak1
                                  Nca78N
                                  Nca78N
                                  wrote on last edited by Nca78
                                  #96
                                  @achurak1 said in livolo Glass Panel Touch Light Wall Switch + arduino 433Mhz:
                                  I think you can simulate the press by setting the pin to a high level, it will cheat the capacitance measurement and should generate a "click". But I take no responsibility for that :P
                                  I don't think the dimmer is using an HC238, which is a decoder that takes 3 pins as input and sets one of it's outputs high, it's convenient for the relays they use but not suitable for a dimmer. They are probably using PWM for that. I have no dimmer switch here, I ordered one but I still need time to receive it...
                                  So if you want to control a dimmer livolo switch at the moment, try to simulate touches on the buttons and the mcu on their sensor board will do the job for you.
                                  I will be able to sell them if they work fine on the long term, but that will need at least one month in the wall to be sure, then another month to order and get the fixed PCB (got some improvements to make already...).
                                  I want to get the dimmer swith also to have a look and if possible make a PCB compatible with both normal switch and dimmer.
                                  For the price I have no idea, either I get them done in China but I don't think there will be enough volume and it takes a lot of time to prepare (but that's an interesting process to learn :)), or I make them myself which takes a lot of time and logistics to assemble, test, ship. BOM is already around 10 US$ so I don't think it could go below 20US$ for final board. That would make the final swith around 10$ more than the radio version of livolo switch, as with my pcb you can just buy the cheapest switches, without radios.
                                  • Nca78N Nca78
                                    Hello, I just found out that Livolo is selling the glass plates (EU standard only, too bad for me :( ) alone on it's aliexpress shop. 3.72€ for square plate (1 or 2 switches), 6.24€ for double sized plate (up to 4 switches) and 8.77€ for triple size (up to 6 switches !).
                                    I have US(AU) sized switches here so I'm a bit screwed up, but I think I will try to order a double plate and put on top of one of my switches boxes which are a bit smaller.
                                    Check the "EU DIY Parts" category in the Livolo shop.
                                    http://www.aliexpress.com/item/Livolo-Luxury-White-Pearl-Crystal-Glass-80mm-80mm-EU-standard-Single-Glass-Panel-For-1-Gang/32484221458.html
                                    wallyllamaW
                                    wallyllamaW
                                    wallyllama
                                    @Nca78 if you search aliexpress hard enough you'll fund us standard plates only. Search "livolo glass plate -eu -uk"
                                    • Nca78N Nca78
                                      A
                                      A
                                      achurak1
                                      @Nca78, thanks! I'm going to try this touch simulation, probably tomorrow.
                                      They use PIC16F690 chip for the dimmable switch versions: http://www.microchip.com/wwwproducts/en/PIC16F690
                                      $20 seems reasonable, I paid $22 for the one gang dimmable switch, so the total would be $42.
                                      • wallyllamaW wallyllama
                                        Nca78N
                                        Nca78N
                                        @wallyllama said in livolo Glass Panel Touch Light Wall Switch + arduino 433Mhz:
                                        Maybe but I'm missing your point ?
                                        I still need to buy the switch to have the box + main power/relay board.
                                        They use the same PIC16F690 in all the switches but what is interesting is to know to which pins of the connector it is connected, and what is connected on the main/ac board to control the dimmers.
                                        If someone has the 2 way switches I'm interested to know what ics are connected to the A and B connectors and to which pins those ics are connected to on the 2x7 pins connectors.
                                        wallyllamaW M 2 Replies Last reply
                                        • Nca78N Nca78
                                          wallyllamaW
                                          wallyllamaW
                                          wallyllama
                                          Nope, I missed yours. Someone mentioned getting glass plates only, then i saw your comment about US plates, and I combined the two. I return you to your regularly scheduled project.
