  3. Vera
  4. Sending Variables to a arduino switch
28 Posts 8 Posters 15.2k Views 6 Watching
  • N Offline
    N Offline
    Nuubi
    Eh, how do you define or set a value for, let's say, V_VAR1 in Vera?
    • P Offline
      P Offline
      patrick schaerer
      in the advanced tab all the way down at the bottom there are should be Variable1. Put a value in the field and save.
      the next time your device requests the variable, the new value will be sent.
      N 1 Reply Last reply
      • P patrick schaerer
        N Offline
        N Offline
        Nuubi
        Thanks, though so, too.
        So the next question is, is it possible to add variables to sensor types that don't have those to begin with? In my case I'd like to add few variables to window covers (S_COVER in http://www.mysensors.org/download/serial_api_15). Can't test now, but would this gw.present(CHILD_ID_OF_BLINDS, V_VAR1) work in adding this property to the blinds?
        • P Offline
          P Offline
          patrick schaerer
          It should work. The variable1 appears in vera after the sensor had requested var1. (But Im not completely shure about that ... )
            N Offline
            N Offline
            Nuubi
            Oh yeah, works as you suggested. Thanks!
            First I didn't get it to work, but re-reading your answer solved it. One really needs to request the variable to make it appear in the controller (Vera, that is in this case).
            • P Offline
              P Offline
              patrick schaerer
              On my newest project I have several sensors on the same node. Some of those sensors demand values on Var1 and Var2.
              The code works fine so far, but I have to write those values all in the same number of digits. (sorry for my english) For example:
              Sensor 1 has V_Var1 422
              Sensor 2 has V_Var1 20
              In order to get the right value on my node I must write the value on Sensor2 in Vera like this: 020
              Otherwise Sensor 2 would receive a V_Var1 of 420.
              Also I had to write a workaround for the incoming message of the switch states. I receive a String and check if the first value is asci 48 for 0 or asci 49 for 1
              It looks to me that some memory in receiving values is left after a value is received. Is it possible to clear that memory?
              Here is the code I am talking about:
               * Version 1.0 - Henrik Ekblad
              #define SKETCH_NAME "Bewässerung"
              #define SKETCH_VERSION "0.7a"
              #include "DHT.h"
              #include <Wire.h>
              #include <BH1750.h>
              DHT dht;
              BH1750 lightMeter;
              int dhtpin = 47;
              int strom_beet_pin = 48;
              int first_hum_pin = 0;
              int first_temp_pin = 4;
              int first_valve_pin = 43;
              unsigned long timer_manual;
              unsigned long timer_umgebung;
              unsigned long timer_beet;
              unsigned long zeit_umgebung = 30;
              unsigned long zeit_beet = 50;
              unsigned long zeit_manual = 60;
              unsigned int helligkeit = 700; // Schwellenwert für Licht bei Bewässerung
              int feuchtigkeit = 50; // Schwellenwert für Erdfeuchtigkeit bei Bewässerung
              int temperatur = 25; //Schwellenwert für Erdtemperatur bei Bewässerung
              // 0 wasser ein, 1-4 hum, 5-8 temp, 9-12 valve, 13 DHT temp, 14 DHT hum, 15 light
              float beet_data[16];
              //definitions for mySensors
              #define DHT_TEMP_ID 13
              #define DHT_HUM_ID 14
              #define LIGHT_ID 15
              //Initialize MySensors
              MyTransportNRF24 transport(49, 53);
              MySensor gw(transport);
              MyMessage msg_temp(DHT_TEMP_ID, V_TEMP);
              MyMessage msg_hum(DHT_HUM_ID, V_HUM);
              MyMessage msg_light(LIGHT_ID, V_LIGHT_LEVEL);
              MyMessage msg_hum1(1,V_HUM);
              MyMessage msg_hum2(2,V_HUM);
              MyMessage msg_hum3(3,V_HUM);
              MyMessage msg_hum4(4,V_HUM);
              MyMessage msg_temp1 (5,V_TEMP);
              MyMessage msg_temp2 (6,V_TEMP);
              MyMessage msg_temp3 (7,V_TEMP);
              MyMessage msg_temp4 (8,V_TEMP);
              MyMessage msg_valve1 (9,V_LIGHT);
              MyMessage msg_valve2 (10,V_LIGHT);
              MyMessage msg_valve3 (11,V_LIGHT);
              MyMessage msg_valve4 (12,V_LIGHT);
              //Initialize mySensor Variables
              MyMessage msg_zeit_umgebung(DHT_TEMP_ID, V_VAR1);
              MyMessage msg_helligkeit(LIGHT_ID, V_VAR1);
              MyMessage msg_feuchtigkeit(1, V_VAR1);
              MyMessage msg_zeit_beet(1, V_VAR2);
              MyMessage msg_temperatur(5, V_VAR1);
              MyMessage msg_zeit_manual(9, V_VAR1);
                // put your setup code here, to run once:
                Serial.begin(115200);
                Serial1.begin(115200);
                gw.begin(incomingMessage);
                gw.sendSketchInfo(SKETCH_NAME, SKETCH_VERSION);
                lightMeter.begin();
                dht.setup(dhtpin);
                pinMode(strom_beet_pin, OUTPUT);
                gw.present(DHT_TEMP_ID, S_TEMP);
                gw.present(DHT_HUM_ID, S_HUM);
                gw.present(LIGHT_ID, S_LIGHT_LEVEL);
                int i=0;
                for ( i=0;i<4;i++) {
                  pinMode(first_valve_pin+i,OUTPUT);
                  gw.present(i+1,S_HUM);
                  gw.present(i+5,S_TEMP);
                  gw.present(i+9, S_LIGHT);
                  digitalWrite(first_valve_pin+i,HIGH);
                getVariables();
                timer_umgebung = millis()-zeit_umgebung*1000;
                timer_beet = millis()-zeit_beet*1000;
                Serial.println("Initialized");
               gw.process();
                // Abfrage der Umgebungsdaten
              if (zeit_umgebung*1000 <= millis()- timer_umgebung) {
                umgebung();
                timer_umgebung = millis();
                Ausgabe();
              //Abfrage der Beetdaten und evtl. Wässerung
              if (zeit_beet*1000 <= millis() - timer_beet) {
                beet();
                send_beet_data();
                wassern_entscheid();
                timer_beet = millis();
                getVariables();
              for (int i=0;i<4;i++) {
                if (beet_data[9+i] == HIGH) {
                beet();
              // Manuelle Wässerung nach zeit_manual ausschalten
              if (zeit_manual*1000 <= millis() - timer_manual && beet_data[0] == HIGH) {
                Serial.println("Manual time is up");
                  beet_data[i+9] = LOW;
                  wasser(i,LOW);
                 beet_data[0] = LOW;
              // Alle Timer nach Overflow von millis() zurücksetzen
              if (millis() < timer_umgebung) {
                timer_manual = millis();
              void getVariables() {
                gw.request(DHT_TEMP_ID, V_VAR1);
                gw.request(LIGHT_ID, V_VAR1);
                gw.request(1, V_VAR1);
                gw.request(1, V_VAR2);
                gw.request(5, V_VAR1);
                gw.request(9, V_VAR1);
              void wassern_entscheid() {
                /* kriterien:
                 *  Morgen oder Abend d.h. Lux unter bestimmtem Wert
                 *  Feuchtigkeit Beet unter bestimmtem Wert
                 *  Temperatur Beet über bestimmtem Wert ?
                 if (beet_data[0] == HIGH) {
                  Serial.println("Manual Valve override");
                 else {
                 if (beet_data[15] < helligkeit) {
                    if (beet_data[i+1] < feuchtigkeit) {
                      if (beet_data[i+9] == LOW) wasser(i,HIGH);
                    else {
                      if (beet_data[i+9] == HIGH) wasser(i,LOW);
                 else {
              void umgebung() {
                uint16_t lux = lightMeter.readLightLevel();
                gw.send(msg_temp.set(temperature,1));
                gw.send(msg_hum.set(humidity,1));
                gw.send(msg_light.set(lux,1));
                beet_data[13] = temperature;
                beet_data[14] = humidity;
                beet_data[15] = lux;
              void beet() {
                digitalWrite(strom_beet_pin, HIGH);
                gw.wait(2000);
                int i=0;
                for(i = 0;i<4;i++) {
                  int hum = analogRead(first_hum_pin+i);
                  hum = map(hum,1023,0,0,100);
                  beet_data[1+i] = hum;
                  int rawvoltage= analogRead(first_temp_pin+i);
                  rawvoltage = 1024 - rawvoltage;
                  float temp= ((rawvoltage/1024.0) * 5000/10)-273.15;
                  beet_data[5+i] = temp;
                digitalWrite(strom_beet_pin, LOW);
              void send_beet_data() {
                  gw.send(msg_hum1.set(beet_data[1],1));
                  gw.send(msg_hum2.set(beet_data[2],1));
                  gw.send(msg_hum3.set(beet_data[3],1));
                  gw.send(msg_hum4.set(beet_data[4],1));
                  gw.send(msg_temp1.set(beet_data[5],1));
                  gw.send(msg_temp2.set(beet_data[6],1));
                  gw.send(msg_temp3.set(beet_data[7],1));
                  gw.send(msg_temp4.set(beet_data[8],1));
                  Serial.println("beet data sent");
              void Ausgabe() {
                Serial.print("Hum: ");
               for (int i=0; i<4; i++) {
                Serial.print(beet_data[i+1]);
                Serial.print(" ");
               Serial.print(" Temp: ");
                Serial.print(beet_data[i+5]);
                Serial.print(" ");
               Serial.print(" Valve: ");
                Serial.print(beet_data[i+9]);
                Serial.print(" ");
               Serial.print(" Zeit Beet: ");
               Serial.print(millis() - timer_beet);
               Serial.println("finished");
               //Variabeln anzeigen
                 Serial.print("Variables ");
                 Serial.print(zeit_umgebung);
                 Serial.print("  ");
                 Serial.print(zeit_beet);
                 Serial.print("  ");
                 Serial.print(zeit_manual);
                 Serial.print("  ");
                 Serial.print(feuchtigkeit);
                 Serial.print("  ");
                 Serial.print(helligkeit);
                 Serial.print("  ");
                 Serial.print(temperatur);
                 Serial.println("  ");
              void wasser(int valve_nr,boolean state) {
                  digitalWrite(first_valve_pin+valve_nr,!state);
                  beet_data[valve_nr+9] = state;
                  if (valve_nr == 0) gw.send(msg_valve1.set(state,1));
                  if (valve_nr == 1) gw.send(msg_valve2.set(state,1));
                  if (valve_nr == 2) gw.send(msg_valve3.set(state,1));
                  if (valve_nr == 3) gw.send(msg_valve4.set(state,1));
                int i;
                for (i=0;i<4;i++) {
                   if (message.sensor == i+9) {
                      char buffer[10];
                      char* empfang = message.getString(buffer);
                      int asci = buffer[0];
                      boolean state;
                      if (asci == 49) state=HIGH;
                      if (asci == 48) state = LOW;
                      wasser(i,state);
                      if (state == HIGH) beet_data[0] = HIGH;
                      Serial.print(i+9);
                      //Serial.print(" Empfangen:  ");
                      //Serial.print(asci);
                      Serial.print(" State: ");
                      Serial.println(state);
                if (message.sensor == DHT_TEMP_ID && message.type == V_VAR1) zeit_umgebung = message.getULong();
                if (message.sensor == LIGHT_ID && message.type == V_VAR1) helligkeit = message.getInt();
                if (message.sensor == 1 && message.type == V_VAR1) feuchtigkeit = message.getInt();
                if (message.sensor == 1 && message.type == V_VAR2) zeit_beet = message.getULong();
                if (message.sensor == 5 && message.type == V_VAR1) temperatur = message.getInt();
                if (message.sensor == 9 && message.type == V_VAR1) zeit_manual = message.getULong();
              • M Offline
                M Offline
                Magiske
                I have started to use ESP8266 for some of my devices with my Vera. So a combination of mysensors and esp's.
                How would I go around reading values via WIFI only(esp8266) ? I can do a HTTP request to put values but how would I do a READ ?
                /M
                • hekH Offline
                  hekH Offline
                  The ESP gateway will send any incoming (radio messages) or locally sent messages on to the socket you have opened from the controller.
                  The ESP gateway doesn't differ from the Ethernet variant in any way (from the controllers point of view).
