  3. Home Assistant
  4. Home Assistant v 0.11.1 with switch support
switchserial gatewayhome assistant
53 Posts 5 Posters 27.6k Views 5 Watching
  • D Offline
    drock1985
    Ok, here is a better log. I decided to set up a new node, one that would auto get the node_ID to see if there was atleast some communication both ways. There seems to be, as the gateway did assign a node_ID, but it didn't show up in HA on the web at all.
    Maybe I need to start HA all over again, just keep the configuration.yaml file?
    pi@home-assistant:~/.homeassistant $ hass
    Config directory: /home/pi/.homeassistant
    WARNING:homeassistant.bootstrap:Colorlog package not found, console coloring disabled
    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_off>
    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=turn_on>
    INFO:homeassistant.bootstrap:Home Assistant core initialized
    INFO:homeassistant.loader:Loaded logbook from homeassistant.components.logbook
    INFO:homeassistant.loader:Loaded recorder from homeassistant.components.recorder
    INFO:homeassistant.loader:Loaded http from homeassistant.components.http
    INFO:homeassistant.loader:Loaded history from homeassistant.components.history
    INFO:homeassistant.loader:Loaded discovery from homeassistant.components.discovery
    INFO:homeassistant.loader:Loaded camera from homeassistant.components.camera
    INFO:homeassistant.loader:Loaded updater from homeassistant.components.updater
    INFO:homeassistant.loader:Loaded sun from homeassistant.components.sun
    INFO:homeassistant.loader:Loaded frontend from homeassistant.components.frontend
    INFO:homeassistant.loader:Loaded api from homeassistant.components.api
    INFO:homeassistant.loader:Loaded media_player from homeassistant.components.media_player
    INFO:homeassistant.loader:Loaded mysensors from homeassistant.components.mysensors
    INFO:homeassistant.loader:Loaded conversation from homeassistant.components.conversation
    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=recorder>
    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=http>
    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=logbook>
    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=history>
    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=discovery>
    INFO:homeassistant.loader:Loaded camera.mjpeg from homeassistant.components.camera.mjpeg
    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453761305.5420914, friendly_name=LivingRoom Camera @ 18:35:05 25-01-2016>, entity_id=camera.livingroom_camera>
    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=camera>
    INFO:urllib3.connectionpool:Starting new HTTPS connection (1): pypi.python.org
    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=updater>
    INFO:urllib3.connectionpool:Starting new HTTP connection (1): maps.googleapis.com
    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=below_horizon; friendly_name=Sun, next_rising=11:42:09 26-01-2016, next_setting=21:17:57 26-01-2016, elevation=-14.01 @ 18:35:11 25-01-2016>, entity_id=sun.sun>
    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sun>
    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=api>
    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=frontend>
    INFO:homeassistant.loader:Loaded media_player.squeezebox from homeassistant.components.media_player.squeezebox
    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state media_player.airspeaker=off; supported_media_commands=447, friendly_name=AirSpeaker @ 18:35:11 25-01-2016>, entity_id=media_player.airspeaker>
    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_play>
    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_pause>
    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=turn_on>
    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=play_media>
    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=turn_off>
    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_up>
    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_down>
    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_play_pause>
    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_next_track>
    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_previous_track>
    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_set>
    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=volume_mute>
    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=media_seek>
    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=start_fireplace>
    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=start_epic_sax>
    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=media_player, service=play_youtube_video>
    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=media_player>
    INFO:mysensors.mysensors:File does not exist or is not readable: /home/pi/.homeassistant/mysensors1.pickle
    INFO:homeassistant.loader:Loaded sensor from homeassistant.components.sensor
    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sensor>
    INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=, service=mysensors.sensors>
    INFO:homeassistant.loader:Loaded switch from homeassistant.components.switch
    INFO:homeassistant.loader:Loaded sensor.mysensors from homeassistant.components.sensor.mysensors
    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_off>
    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=switch, service=turn_on>
    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=switch>
    INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=, service=mysensors.switches>
    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=mysensors>
    INFO:homeassistant.loader:Loaded switch.mysensors from homeassistant.components.switch.mysensors
    /home/pi/.homeassistant/lib/fuzzywuzzy/fuzz.py:33: UserWarning: Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove this warning
      warnings.warn('Using slow pure-python SequenceMatcher. Install python-Levenshtein to remove this warning')
    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=conversation, service=process>
    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=conversation>
    INFO:homeassistant.core:Starting Home Assistant (17 threads)
    INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=homeassistant, service=stop>
    INFO:mysensors.mysensors:Trying to connect to /dev/ttyUSB0
    INFO:homeassistant.components.http:Starting web interface at http://0.0.0.0:8123
    INFO:homeassistant.core:Timer:starting
    INFO:homeassistant.components.http:"GET /api/stream?api_password=no_password_set&restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 -
    INFO:homeassistant.components.http:"GET /api/bootstrap HTTP/1.1" 200 -
    INFO:netdisco.service:Scanning
    WARNING:homeassistant.components.recorder:Found unfinished sessions
    INFO:mysensors.mysensors:/dev/ttyUSB0 is open...
    INFO:mysensors.mysensors:Connected to /dev/ttyUSB0
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, distance=0
    INFO:homeassistant.components.media_player:Updating media_player entities
    INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.4
    INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.102
    INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.199
    INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.113
    INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.101
    INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.163
    INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.108
    INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.111
    INFO:homeassistant.components.discovery:Found new service: DLNA http://192.168.86.4:32469/DeviceDescription.xml
    INFO:homeassistant.components.discovery:Found new service: DLNA http://192.168.86.113:9000/plugins/UPnP/MediaServer.xml
    INFO:homeassistant.components.discovery:Found new service: plex_mediaserver ('Rocknet Server', 'https://192.168.86.4:32400')
    INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=('Rocknet Server', 'https://192.168.86.4:32400'), service=plex_mediaserver>
    INFO:homeassistant.components.discovery:Found new service: google_cast ('192.168.86.102', 8009)
    INFO:homeassistant.loader:Loaded media_player.plex from homeassistant.components.media_player.plex
    INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=('192.168.86.102', 8009), service=google_cast>
    INFO:homeassistant.components.discovery:Found new service: google_cast ('192.168.86.142', 8009)
    INFO:homeassistant.loader:Loaded media_player.cast from homeassistant.components.media_player.cast
    INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=('192.168.86.142', 8009), service=google_cast>
    INFO:homeassistant.components.discovery:Found new service: google_cast ('192.168.86.101', 8009)
    INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=('192.168.86.101', 8009), service=google_cast>
    INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('Christmas Tree Lights', 'Insight', 'http://192.168.86.111:49153/setup.xml', '94103E395F2C')
    INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=('Christmas Tree Lights', 'Insight', 'http://192.168.86.111:49153/setup.xml', '94103E395F2C'), service=belkin_wemo>
    INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('LivingRoomLamp', 'Socket', 'http://192.168.86.163:49153/setup.xml', '94103E30C688')
    INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=('LivingRoomLamp', 'Socket', 'http://192.168.86.163:49153/setup.xml', '94103E30C688'), service=belkin_wemo>
    INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('CatFan', 'Socket', 'http://192.168.86.108:49153/setup.xml', '94103E30CDBC')
    INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=('CatFan', 'Socket', 'http://192.168.86.108:49153/setup.xml', '94103E30CDBC'), service=belkin_wemo>
    INFO:homeassistant.components.discovery:Found new service: philips_hue ('Philips hue (192.168.86.199)', 'http://192.168.86.199:80/')
    INFO:homeassistant.loader:Loaded switch.wemo from homeassistant.components.switch.wemo
    INFO:homeassistant.loader:Loaded light from homeassistant.components.light
    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=light, service=turn_on>
    INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: domain=light, service=turn_off>
    INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=light>
    INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: discovered=('Philips hue (192.168.86.199)', 'http://192.168.86.199:80/'), service=philips_hue>
    INFO:homeassistant.loader:Loaded light.hue from homeassistant.components.light.hue
    INFO:phue:Attempting to connect to the bridge...
    INFO:phue:Using ip: 192.168.86.199
    INFO:phue:Using username from config: 30f609e6210320e41f0dfc32220a525f
    INFO:plexapi:GET http://192.168.86.4:32400/
    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_1=off; friendly_name=Master bedroom 1 @ 18:35:27 25-01-2016>, entity_id=light.master_bedroom_1>
    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.aprils_lamp=off; friendly_name=April's lamp @ 18:35:27 25-01-2016>, entity_id=light.aprils_lamp>
    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_2=off; friendly_name=Master bedroom 2 @ 18:35:27 25-01-2016>, entity_id=light.master_bedroom_2>
    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_light_strip=off; friendly_name=Master bedroom light strip @ 18:35:27 25-01-2016>, entity_id=light.master_bedroom_light_strip>
    INFO:homeassistant.components.media_player.plex:Connected to: htts://192.168.86.4:32400
    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.living_room_light_2=on; brightness=254, friendly_name=Living room light 2 @ 18:35:27 25-01-2016>, entity_id=light.living_room_light_2>
    INFO:plexapi:GET http://192.168.86.4:32400/clients
    INFO:pywemo.subscribe:Listening on port 8989
    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.master_bedroom_3=off; friendly_name=Master bedroom 3 @ 18:35:27 25-01-2016>, entity_id=light.master_bedroom_3>
    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state light.living_room_light_1=on; brightness=254, friendly_name=Living room light 1 @ 18:35:27 25-01-2016>, entity_id=light.living_room_light_1>
    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_lights=unknown; entity_id=[], auto=True, friendly_name=all lights @ 18:35:27 25-01-2016>, entity_id=group.all_lights>
    INFO:plexapi:GET http://192.168.86.4:32400/status/sessions
    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_lights=on; entity_id=('light.aprils_lamp', 'light.master_bedroom_1', 'light.living_room_light_1', 'light.living_room_light_2', 'light.master_bedroom_light_strip', 'light.master_bedroom_3', 'light.master_bedroom_2'), auto=True, friendly_name=all lights @ 18:35:27 25-01-2016>, entity_id=group.all_lights>
    ERROR:homeassistant.components.media_player:Error while setting up platform cast
    Traceback (most recent call last):
      File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity_component.py", line 145, in _setup_platform
        self.hass, platform_config, self.add_entities, discovery_info)
      File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/media_player/cast.py", line 39, in setup_platform
        import pychromecast
      File "/home/pi/.homeassistant/lib/pychromecast/__init__.py", line 14, in <module>
        from . import socket_client
    ImportError: cannot import name 'socket_client'
        import pychromecast
      File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/media_player/cast.py", line 68, in setup_platform
        casts.append(CastDevice(host))
      File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/media_player/cast.py", line 84, in __init__
        import pychromecast.controllers.youtube as youtube
    AttributeError: 'module' object has no attribute 'controllers'
    INFO:pywemo.subscribe:Subscribing to events from <WeMo Switch "CatFan">
    INFO:pywemo.subscribe:Resubscribe for <WeMo Switch "CatFan">
    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state switch.catfan=off; friendly_name=CatFan @ 18:35:29 25-01-2016>, entity_id=switch.catfan>
    INFO:pywemo.subscribe:Received event from <WeMo Switch "CatFan">(192.168.86.108)
    INFO:pywemo.subscribe:Subscribing to events from <WeMo Switch "LivingRoomLamp">
    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=unknown; entity_id=[], auto=True, friendly_name=all switches @ 18:35:29 25-01-2016>, entity_id=group.all_switches>
    INFO:homeassistant.components.switch.wemo:Subscription update for  <WeMo Switch "CatFan">
    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=off; entity_id=('switch.catfan',), auto=True, friendly_name=all switches @ 18:35:29 25-01-2016>, entity_id=group.all_switches>
    INFO:pywemo.subscribe:Subscribing to events from <WeMo Insight "Christmas Tree Lights">
    INFO:pywemo.subscribe:Resubscribe for <WeMo Switch "LivingRoomLamp">
    INFO:pywemo.subscribe:Resubscribe for <WeMo Insight "Christmas Tree Lights">
    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state switch.livingroomlamp=on; friendly_name=LivingRoomLamp @ 18:35:29 25-01-2016>, entity_id=switch.livingroomlamp>
    INFO:pywemo.subscribe:Received event from <WeMo Switch "LivingRoomLamp">(192.168.86.163)
    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=on; entity_id=('switch.livingroomlamp', 'switch.catfan'), auto=True, friendly_name=all switches @ 18:35:29 25-01-2016>, entity_id=group.all_switches>
    INFO:homeassistant.components.switch.wemo:Subscription update for  <WeMo Switch "LivingRoomLamp">
    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state switch.christmas_tree_lights=off; friendly_name=Christmas Tree Lights @ 18:35:29 25-01-2016>, entity_id=switch.christmas_tree_lights>
    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state group.all_switches=on; entity_id=('switch.livingroomlamp', 'switch.christmas_tree_lights', 'switch.catfan'), auto=True, friendly_name=all switches @ 18:35:29 25-01-2016>, entity_id=group.all_switches>
    INFO:pywemo.subscribe:Received event from <WeMo Insight "Christmas Tree Lights">(192.168.86.111)
    INFO:homeassistant.components.switch.wemo:Subscription update for  <WeMo Insight "Christmas Tree Lights">
    INFO:homeassistant.components.light:Updating light entities
    INFO:homeassistant.components.camera:Updating camera entities
    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453761330.5161493, friendly_name=LivingRoom Camera @ 18:35:05 25-01-2016>, entity_id=camera.livingroom_camera, old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453761305.5420914, friendly_name=LivingRoom Camera @ 18:35:05 25-01-2016>>
    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state sun.sun=below_horizon; friendly_name=Sun, next_rising=11:42:09 26-01-2016, next_setting=21:17:57 26-01-2016, elevation=-14.07 @ 18:35:11 25-01-2016>, entity_id=sun.sun, old_state=<state sun.sun=below_horizon; friendly_name=Sun, next_rising=11:42:09 26-01-2016, next_setting=21:17:57 26-01-2016, elevation=-14.01 @ 18:35:11 25-01-2016>>
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=0,t=17,pt=0,l=5,sg=0:1.5.1
    INFO:homeassistant.components.mysensors:update sensor_update: node 1
    INFO:homeassistant.components.mysensors:No sketch_name: node 1
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-1-1 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=11,pt=0,l=13,sg=0:Motion Sensor
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:1.0
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=1,c=0,t=1,pt=0,l=0,sg=0:
    INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=1,c=1,t=16,pt=0,l=1,sg=0:1
    INFO:homeassistant.components.http:"GET /api/error_log HTTP/1.1" 200 -
    INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453761360.5125034, friendly_name=LivingRoom Camera @ 18:35:05 25-01-2016>, entity_id=camera.livingroom_camera, old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453761330.5161493, friendly_name=LivingRoom Camera @ 18:35:05 25-01-2016>>
    INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.117
    INFO:homeassistant.components.http:"GET /states HTTP/1.1" 200 -
    INFO:homeassistant.components.http:"GET /static/frontend-1003c31441ec44b3db84b49980f736a7.html HTTP/1.1" 200 -
    INFO:homeassistant.components.http:"GET /static/favicon-192x192.png HTTP/1.1" 200 -
    INFO:homeassistant.components.http:"GET /static/favicon.ico HTTP/1.1" 200 -
    ^CINFO:homeassistant.core:Stopping
    INFO:homeassistant.core:Bus:Handling <Event homeassistant_stop[L]>
    INFO:homeassistant.components.switch.wemo:Shutting down subscriptions.
    INFO:mysensors.mysensors:Disconnecting from /dev/ttyUSB0
    INFO:mysensors.mysensors:Stopping thread
    INFO:homeassistant.components.recorder:Closing database
    My Projects
    2 Door Chime Sensor
    Washing Machine Monitor
    asmA martinhjelmareM 2 Replies Last reply
    • D drock1985
          import pychromecast
          import pychromecast
      asmA Offline
      asmA Offline
      asm
      @drock1985 Interesting ! I restarted a few times too with persistence enabled and at some point the json file gets populated. Another restart and the sensor appears in the UI ...
      • D Offline
        drock1985
        Hi @asm
        Glad to hear you had some luck. I'm getting closer (i think), getting different errors in the log now. The Motion sensor shows up in terminal, and even identifies it just not in the GUI.
        ARG! I bet it is something so small it's not funny anymore!
        Jan 25 19:03:23 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTPS connection (1): pypi.python.org
        Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=updater>
        Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=history>
        Jan 25 19:03:24 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): maps.googleapis.com
        Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=sun.sun, new_state=<state sun.sun=below_horizon; elevation=-18.97, next_setting=21:17:57 26-01-2016, friendly_name=Sun, next_rising=11:42:09 26-01-2016 @ 19:03:24 25-01-2016>>
        Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sun>
        Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.loader:Loaded sensor from homeassistant.components.sensor
        Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=sensor>
        Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.sensors, discovered=>
        Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.loader:Loaded sensor.mysensors from homeassistant.components.sensor.mysensors
        Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.loader:Loaded switch from homeassistant.components.switch
        Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_off, domain=switch>
        Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_on, domain=switch>
        Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=switch>
        Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=mysensors.switches, discovered=>
        Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=mysensors>
        Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.loader:Loaded switch.mysensors from homeassistant.components.switch.mysensors
        Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=discovery>
        Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Starting Home Assistant (17 threads)
        Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event homeassistant_start[L]>
        Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=stop, domain=homeassistant>
        Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.components.http:Starting web interface at http://0.0.0.0:8123
        Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.core:Timer:starting
        Jan 25 19:03:24 home-assistant hass[1416]: INFO:mysensors.mysensors:Trying to connect to /dev/ttyUSB0
        Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.components.mysensors:update persistence: node 1
        Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.components.mysensors:No sketch_name: node 1
        Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.components.http:"GET /api/stream?api_password=no_password_set&restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 -
        Jan 25 19:03:24 home-assistant hass[1416]: INFO:netdisco.service:Scanning
        Jan 25 19:03:24 home-assistant hass[1416]: INFO:homeassistant.components.http:"GET /api/bootstrap HTTP/1.1" 200 -
        Jan 25 19:03:27 home-assistant hass[1416]: INFO:mysensors.mysensors:/dev/ttyUSB0 is open...
        Jan 25 19:03:27 home-assistant hass[1416]: INFO:mysensors.mysensors:Connected to /dev/ttyUSB0
        Jan 25 19:03:27 home-assistant hass[1416]: INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:gateway started, id=0, parent=0, distance=0
        Jan 25 19:03:30 home-assistant hass[1416]: INFO:homeassistant.components.media_player:Updating media_player entities
        Jan 25 19:03:30 home-assistant hass[1416]: INFO:homeassistant.components.camera:Updating camera entities
        Jan 25 19:03:30 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453763003.501535, friendly_name=LivingRoom Camera @ 19:03:23 25-01-2016>, entity_id=camera.livingroom_camera, new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453763010.532438, friendly_name=LivingRoom Camera @ 19:03:23 25-01-2016>>
        Jan 25 19:03:30 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=<state sun.sun=below_horizon; elevation=-18.97, next_setting=21:17:57 26-01-2016, friendly_name=Sun, next_rising=11:42:09 26-01-2016 @ 19:03:24 25-01-2016>, entity_id=sun.sun, new_state=<state sun.sun=below_horizon; elevation=-18.99, next_setting=21:17:57 26-01-2016, friendly_name=Sun, next_rising=11:42:09 26-01-2016 @ 19:03:24 25-01-2016>>
        Jan 25 19:03:37 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.1
        Jan 25 19:03:37 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.101
        Jan 25 19:03:37 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.113
        Jan 25 19:03:38 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.142
        Jan 25 19:03:38 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.199
        Jan 25 19:03:38 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.113
        Jan 25 19:03:38 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.102
        Jan 25 19:03:38 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.108
        Jan 25 19:03:38 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.163
        Jan 25 19:03:38 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.111
        Jan 25 19:03:38 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.4
        Jan 25 19:03:38 home-assistant hass[1416]: INFO:homeassistant.components.discovery:Found new service: DLNA http://192.168.86.113:9000/plugins/UPnP/MediaServer.xml
        Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.components.discovery:Found new service: plex_mediaserver ('Rocknet Server', 'https://192.168.86.4:32400')
        Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=plex_mediaserver, discovered=('Rocknet Server', 'https://192.168.86.4:32400')>
        Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.components.discovery:Found new service: google_cast ('192.168.86.142', 8009)
        Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=google_cast, discovered=('192.168.86.142', 8009)>
        Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.components.discovery:Found new service: google_cast ('192.168.86.101', 8009)
        Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=google_cast, discovered=('192.168.86.101', 8009)>
        Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.components.discovery:Found new service: google_cast ('192.168.86.102', 8009)
        Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=google_cast, discovered=('192.168.86.102', 8009)>
        Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('LivingRoomLamp', 'Socket', 'http://192.168.86.163:49153/setup.xml', '94103E30C688')
        Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=belkin_wemo, discovered=('LivingRoomLamp', 'Socket', 'http://192.168.86.163:49153/setup.xml', '94103E30C688')>
        Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.loader:Loaded media_player.plex from homeassistant.components.media_player.plex
        Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.loader:Loaded media_player.cast from homeassistant.components.media_player.cast
        Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('Christmas Tree Lights', 'Insight', 'http://192.168.86.111:49153/setup.xml', '94103E395F2C')
        Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=belkin_wemo, discovered=('Christmas Tree Lights', 'Insight', 'http://192.168.86.111:49153/setup.xml', '94103E395F2C')>
        Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.loader:Loaded switch.wemo from homeassistant.components.switch.wemo
        Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.components.discovery:Found new service: belkin_wemo ('CatFan', 'Socket', 'http://192.168.86.108:49153/setup.xml', '94103E30CDBC')
        Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=belkin_wemo, discovered=('CatFan', 'Socket', 'http://192.168.86.108:49153/setup.xml', '94103E30CDBC')>
        Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.components.discovery:Found new service: philips_hue ('Philips hue (192.168.86.199)', 'http://192.168.86.199:80/')
        Jan 25 19:03:39 home-assistant hass[1416]: INFO:homeassistant.loader:Loaded light from homeassistant.components.light
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_on, domain=light>
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event service_registered[L]: service=turn_off, domain=light>
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=light>
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event platform_discovered[L]: service=philips_hue, discovered=('Philips hue (192.168.86.199)', 'http://192.168.86.199:80/')>
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.loader:Loaded light.hue from homeassistant.components.light.hue
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:phue:Attempting to connect to the bridge...
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:phue:Using ip: 192.168.86.199
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:phue:Using username from config: 30f609e6210320e41f0dfc32220a525f
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:plexapi:GET http://192.168.86.4:32400/
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.4
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=light.master_bedroom_1, new_state=<state light.master_bedroom_1=off; friendly_name=Master bedroom 1 @ 19:03:40 25-01-2016>>
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=light.master_bedroom_light_strip, new_state=<state light.master_bedroom_light_strip=off; friendly_name=Master bedroom light strip @ 19:03:40 25-01-2016>>
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=light.master_bedroom_3, new_state=<state light.master_bedroom_3=off; friendly_name=Master bedroom 3 @ 19:03:40 25-01-2016>>
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=light.master_bedroom_2, new_state=<state light.master_bedroom_2=off; friendly_name=Master bedroom 2 @ 19:03:40 25-01-2016>>
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=light.living_room_light_1, new_state=<state light.living_room_light_1=on; friendly_name=Living room light 1, brightness=254 @ 19:03:40 25-01-2016>>
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=light.aprils_lamp, new_state=<state light.aprils_lamp=on; friendly_name=April's lamp, brightness=254 @ 19:03:40 25-01-2016>>
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=light.living_room_light_2, new_state=<state light.living_room_light_2=on; friendly_name=Living room light 2, brightness=254 @ 19:03:40 25-01-2016>>
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.components.media_player.plex:Connected to: htts://192.168.86.4:32400
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, new_state=<state group.all_lights=unknown; entity_id=[], auto=True, friendly_name=all lights @ 19:03:40 25-01-2016>>
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:plexapi:GET http://192.168.86.4:32400/clients
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, new_state=<state group.all_lights=on; entity_id=('light.master_bedroom_3', 'light.aprils_lamp', 'light.living_room_light_1', 'light.master_bedroom_1', 'light.master_bedroom_2', 'light.master_bedroom_light_strip', 'light.living_room_light_2'), auto=True, friendly_name=all lights @ 19:03:40 25-01-2016>>
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:plexapi:GET http://192.168.86.4:32400/status/sessions
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.163
        Jan 25 19:03:40 home-assistant hass[1416]: ERROR:homeassistant.components.switch:Error while setting up platform wemo
        Jan 25 19:03:40 home-assistant hass[1416]: Traceback (most recent call last):
        Jan 25 19:03:40 home-assistant hass[1416]: File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity_component.py", line 145, in _setup_platform
        Jan 25 19:03:40 home-assistant hass[1416]: self.hass, platform_config, self.add_entities, discovery_info)
        Jan 25 19:03:40 home-assistant hass[1416]: File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/switch/wemo.py", line 25, in setup_platform
        Jan 25 19:03:40 home-assistant hass[1416]: import pywemo.discovery as discovery
        Jan 25 19:03:40 home-assistant hass[1416]: AttributeError: 'module' object has no attribute 'discovery'
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:pywemo.subscribe:Listening on port 8989
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.components.media_player:Updating media_player entities
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:pychromecast:Querying device status
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.102
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.101
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.142
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=1,c=1,t=16,pt=0,l=1,sg=0:0
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.components.mysensors:update sensor_update: node 1
        Jan 25 19:03:40 home-assistant hass[1416]: INFO:homeassistant.components.mysensors:No sketch_name: node 1
        Jan 25 19:03:41 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=media_player.man_cave, new_state=<state media_player.man_cave=off; supported_media_commands=1021, friendly_name=Man Cave @ 19:03:40 25-01-2016>>
        Jan 25 19:03:41 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.163
        Jan 25 19:03:41 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=media_player.master_bedroom, new_state=<state media_player.master_bedroom=off; supported_media_commands=1021, friendly_name=Master Bedroom @ 19:03:41 25-01-2016>>
        Jan 25 19:03:41 home-assistant hass[1416]: INFO:pywemo.subscribe:Subscribing to events from <WeMo Switch "LivingRoomLamp">
        Jan 25 19:03:41 home-assistant hass[1416]: INFO:pywemo.subscribe:Resubscribe for <WeMo Switch "LivingRoomLamp">
        Jan 25 19:03:41 home-assistant hass[1416]: INFO:pywemo.subscribe:Received event from <WeMo Switch "LivingRoomLamp">(192.168.86.163)
        Jan 25 19:03:41 home-assistant hass[1416]: INFO:homeassistant.components.switch.wemo:Subscription update for  <WeMo Switch "LivingRoomLamp">
        Jan 25 19:03:41 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=switch.livingroomlamp, new_state=<state switch.livingroomlamp=on; friendly_name=LivingRoomLamp @ 19:03:41 25-01-2016>>
        Jan 25 19:03:41 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=group.all_switches, new_state=<state group.all_switches=unknown; entity_id=[], auto=True, friendly_name=all switches @ 19:03:41 25-01-2016>>
        Jan 25 19:03:41 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=group.all_switches, new_state=<state group.all_switches=on; entity_id=('switch.livingroomlamp',), auto=True, friendly_name=all switches @ 19:03:41 25-01-2016>>
        Jan 25 19:03:41 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: entity_id=media_player.living_room, new_state=<state media_player.living_room=off; supported_media_commands=1021, friendly_name=Living Room @ 19:03:41 25-01-2016>>
        Jan 25 19:03:45 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.117
        Jan 25 19:03:50 home-assistant hass[1416]: INFO:homeassistant.components.media_player:Updating media_player entities
        Jan 25 19:03:51 home-assistant hass[1416]: INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=0,t=17,pt=0,l=5,sg=0:1.5.1
        Jan 25 19:03:51 home-assistant hass[1416]: INFO:homeassistant.components.mysensors:update sensor_update: node 1
        Jan 25 19:03:51 home-assistant hass[1416]: INFO:homeassistant.components.mysensors:No sketch_name: node 1
        Jan 25 19:03:51 home-assistant hass[1416]: INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
        Jan 25 19:03:51 home-assistant hass[1416]: INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-1-1 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
        Jan 25 19:03:53 home-assistant hass[1416]: INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=11,pt=0,l=13,sg=0:Motion Sensor
        Jan 25 19:03:53 home-assistant hass[1416]: INFO:homeassistant.components.mysensors:update sensor_update: node 1
        Jan 25 19:03:53 home-assistant hass[1416]: INFO:homeassistant.components.mysensors:adding new devices: [<Entity Motion Sensor 1.1: >]
        Jan 25 19:04:00 home-assistant hass[1416]: Exception in thread Thread-15:
        Jan 25 19:04:00 home-assistant hass[1416]: Traceback (most recent call last):
        Jan 25 19:04:00 home-assistant hass[1416]: File "/usr/lib/python3.4/threading.py", line 920, in _bootstrap_inner
        Jan 25 19:04:00 home-assistant hass[1416]: self.run()
        Jan 25 19:04:00 home-assistant hass[1416]: File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 312, in run
        Jan 25 19:04:00 home-assistant hass[1416]: response = self.handle_queue()
        Jan 25 19:04:00 home-assistant hass[1416]: File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 222, in handle_queue
        Jan 25 19:04:00 home-assistant hass[1416]: reply = func(*args, **kwargs)
        Jan 25 19:04:00 home-assistant hass[1416]: File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 112, in logic
        Jan 25 19:04:00 home-assistant hass[1416]: return self._handle_internal(msg)
        Jan 25 19:04:00 home-assistant hass[1416]: File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 74, in _handle_internal
        Jan 25 19:04:00 home-assistant hass[1416]: self.alert(msg.node_id)
        Jan 25 19:04:00 home-assistant hass[1416]: File "/home/pi/.homeassistant/lib/mysensors/mysensors.py", line 175, in alert
        Jan 25 19:04:00 home-assistant hass[1416]: self.event_callback("sensor_update", nid)
        Jan 25 19:04:00 home-assistant hass[1416]: File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 226, in node_update
        Jan 25 19:04:00 home-assistant hass[1416]: callback(self, node_id)
        Jan 25 19:04:00 home-assistant hass[1416]: File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/mysensors.py", line 165, in mysensors_callback
        Jan 25 19:04:00 home-assistant hass[1416]: add_devices(devices[node_id])
        Jan 25 19:04:00 home-assistant hass[1416]: File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity_component.py", line 81, in add_entities
        Jan 25 19:04:00 home-assistant hass[1416]: entity.update_ha_state()
        Jan 25 19:04:00 home-assistant hass[1416]: File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity.py", line 108, in update_ha_state
        Jan 25 19:04:00 home-assistant hass[1416]: self.unit_of_measurement is not None:
        Jan 25 19:04:00 home-assistant hass[1416]: File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/sensor/mysensors.py", line 137, in unit_of_measurement
        Jan 25 19:04:00 home-assistant hass[1416]: self.value_type == self.gateway.const.SetReq.V_PERCENTAGE or \
        Jan 25 19:04:00 home-assistant hass[1416]: File "/usr/lib/python3.4/enum.py", line 255, in __getattr__
        Jan 25 19:04:00 home-assistant hass[1416]: raise AttributeError(name) from None
        Jan 25 19:04:00 home-assistant hass[1416]: AttributeError: V_PERCENTAGE
        Jan 25 19:04:00 home-assistant hass[1416]: INFO:homeassistant.components.media_player:Updating media_player entities
        Jan 25 19:04:00 home-assistant hass[1416]: INFO:homeassistant.components.light:Updating light entities
        Jan 25 19:04:00 home-assistant hass[1416]: INFO:homeassistant.components.camera:Updating camera entities
        Jan 25 19:04:00 home-assistant hass[1416]: INFO:homeassistant.core:Bus:Handling <Event state_changed[L]: old_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453763010.532438, friendly_name=LivingRoom Camera @ 19:03:23 25-01-2016>, entity_id=camera.livingroom_camera, new_state=<state camera.livingroom_camera=idle; entity_picture=/api/camera_proxy/camera.livingroom_camera?time=1453763040.5191662, friendly_name=LivingRoom Camera @ 19:03:23 25-01-2016>>
        Jan 25 19:04:00 home-assistant hass[1416]: INFO:urllib3.connectionpool:Starting new HTTP connection (1): 192.168.86.117
        My Projects
        2 Door Chime Sensor
        • D drock1985
              import pychromecast
              import pychromecast
          martinhjelmareM Offline
          martinhjelmare
          #44
          @drock1985
          All the messages logged from the gateway look good in the latest log output without errors. Only thing missing is a log line saying "adding new devices...". There are three main reasons why this doesn't happen when the code executes:
          • A device with the same node id is already added.
          • Some node/sensor data is missing in the data stuctures, sketch name, child id, S_TYPE, V_TYPE.
          • The S_TYPE and V_TYPE for the child sensor is not handled by any of the platforms that home assistant supports.
          All pure sensors in version 1.5 are currently supported by the sensor platform. The switch platform supports:
          S_DOOR,
          S_MOTION,
          S_SMOKE,
          S_LIGHT,
          S_LOCK,
          S_BINARY,
          S_SPRINKLER,
          S_WATER_LEAK,
          S_SOUND,
          S_VIBRATION,
          S_MOISTURE,
          V_ARMED,
          V_LIGHT,
          V_LOCK_STATUS,
          V_STATUS
          There's a bug if you don't specify version 1.5 in the config of home assistant. It's related to the V_PERCENTAGE attribute error. I'm fixing that now. But I don't think that's your problem here. My guess is point 1 or 2 above is the problem.
          You could try the following:
          • Remove any json or pickle persistence files from your config directory.
          • Activate persistence in your config (and set version 1.5).
          • Connect your gateway
          • Start hass
          • Wait for "gateway started" log line
          • Connect the sensor
          • If no errors occur, open the newly generated persistence file and copy/paste the contents here. This might give us more clues.
          • martinhjelmareM Offline
            martinhjelmare
            I'm trying to replicate the problem, and there seem to be some issue with adding devices "on the fly" and not from the persistence file.
            A workaround seems to be, as @asm reported:
            • Present sensors and send a value per sensor
            • Restart home assistant
            I'll try to figure out the cause and make a fix.
              martinhjelmare
              Ok, I've found the bug. I'll make the fix and pull request to home assistant. It should make the next release.
              Until then the workaround above should be usable, at least.
              Make sure you present the sensors and send at least one value per sensor, and the persistence file will be populated. Then after the restart of home assistant your sensors should show in the gui.
              Sorry for the inconvenience, and thanks for helping me troubleshoot this! I really appreciate all feedback and also any criticism, which in the end will make the controller and plugin better.
              asmA 1 Reply Last reply
                asmA Offline
                asmA Offline
                asm
                @martinhjelmare thank you !
                Yesterday I finally got all the sensors in the UI using the workaround, so now it looks fine, but I'll update when the fix is available.
                Thanks again!
                • D Offline
                  drock1985
                  Hi @martinhjelmare and @asm
                  Confirmed: I have the one node i set for auto-id working now. I had to still add the 1.5 version info to configuration.yaml for it to show properly though - so all lines that are on the Components page of the HA wiki are NEEDED. And the reboot of HA worked after enabling persistence and the v1.5
                  I'll work with my manually assigned ID's on the weekend - got too many courses/work to do the rest of the week. Thank you both again for your help, it was very much appreciated.
                  And @martinhjelmare keep up the great work on the addon, loving it. And if any advice, the only thing I wish is there was an option to have an ethernet gateway over the serial.
                  My Projects
                  2 Door Chime Sensor
                  • D drock1985
                    martinhjelmare
                    I'm not following completely. How do you mean ethernet gateway over serial? I know @Yveaux has made a Perl script to interface serial with mqtt. Is that what you mean?
                    • D Offline
                      drock1985
                      I mean that I would rather Home Assistant had an Ethernet Gateway over the Serial one. Don't know why but personally I find the Ethernet Gateway to be more stable/compatible than Serial (that goes for any home automation controller i've tried).
                      My Projects
                      2 Door Chime Sensor
                      • D drock1985
                        martinhjelmare
                        @drock1985
                        Oh, ok. I'm working on an ethernet gateway plugin. Needs some more testing, before I can submit it.
                        If you want to beta test, I can ping you when its more or less ready?
                        • D Offline
                          drock1985
                          Hi @martinhjelmare
                          I would love to beta test a gateway, no problem. Let me know when you need testing.
                          Also just a quick general Home-assistant question. Is it possible to rename devices? Not a big deal, but I notice that the sketch name is the default name of the device, and wasn't too sure if HA allows you to give them nick names or the like.
                          Thanks,
                          My Projects
                          2 Door Chime Sensor
                          • D drock1985
                            Hi @martinhjelmare
                            Thanks,
                            martinhjelmare
                            @drock1985
                            Yes, it's possible to rename devices and also customize icons etc.
                            See my post here:
                            http://forum.mysensors.org/topic/2388/home-assistant-how-to-recognize-mysensors-nodes/64
