  3. Mysensors ESP8266 GW with relay - Presentation relay not working why?
4 Posts 4 Posters 2.7k Views 1 Watching
  • F
    F
    fernando coelho
    Dear all,
    I am trying to use the ESP8266 with a local attached relay , but it is not recognized by domoticz.
    Can someone help on that ?
    Here the information log and the ino code:
    DOMOTICZ LOG
    2016-01-17 13:49:54.731 MySensors: connected to: 192.168.1.111:5003
    2016-01-17 13:49:54.731 MySensors: Gateway Ready...
    2016-01-17 13:49:55.781 MySensors: Gateway Version: 1.6.0-beta
    ESP LOG
    connected with FCSSID, channel 1
    ip:192.168.1.111,mask:255.255.255.0,gw:192.168.1.1
    .IP: 192.168.1.111
    start call Setup
    Start wait
    End wait
    End call Setup
    start call presentation
    Start wait
    End wait
    End call presentation
    0;0;3;0;9;Init complete, id=0, parent=0, distance=0
    0;0;3;0;9;Client 0 connected
    0;0;3;0;9;Client 0: 0;0;3;0;2;
    0;0;3;0;9;Client 0: 0;0;3;0;2;Get Version
    0;0;3;0;9;Client 0: 0;0;3;0;18;PING
    INO code:
    #include <EEPROM.h>
    //#define MY_REPEATER_FEATURE
    #define MY_DEBUG_VERBOSE
    #define MY_BAUD_RATE 9600
    // #define MY_RADIO_NRF24
    // #define MY_RADIO_RFM69
    // Gateway mode always enabled for ESP8266. But we add this anyway ;)
    #define MY_GATEWAY_ESP8266
    #define MY_ESP8266_SSID "FCSSID"
    #define MY_ESP8266_PASSWORD "jfsc20100930*"
    // Enable UDP communication
    //#define MY_USE_UDP
    #define MY_IP_ADDRESS 192,168,1,111
    #define MY_IP_GATEWAY_ADDRESS 192,168,1,1
    #define MY_PORT 5003
    // Flash leds on rx/tx/err
    #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // Enable inclusion mode
    #if defined(MY_USE_UDP)
      #include <WiFiUDP.h>
    #else
      #include <ESP8266WiFi.h>
    #define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
      Serial.println("start call Setup");
        pinMode(pin, OUTPUT);
        Serial.println("Start wait");
        //delay(60000);
        Serial.println("End wait");
        Serial.println("End call Setup");
        Serial.println("start call presentation");
        //delay(60000);
      sendSketchInfo("Relay2", "2.0");
        present(sensor, S_LIGHT);
          Serial.println("End call presentation");
          //Serial.println("start call loop");
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
    • E
      E
      ericvdb
      wrote on last edited by ericvdb
      please indent your code with 4 spaces to keep it readable.
      And in the arduino gui press CTRL-T to tabify your code correctly ;)
      • W
        W
        wxws
        yes ,i find this bug too.
          Hmm.. Looks like it could it be that the connection to controller hasn't been initialised when node/gw sends the presentations.
          Please create an issue on github and create a link to it here.
