[SOLVED] No message after few hours
I'm testing the network with domoticz on a raspberry and a couple of arduino nano with dht11 sensors.
Everything works fine, but after few hours it seems my nodes stop transmitting. Robooting arduino solves the problem.
Any idea? -
Any idea?@gerseun DHT reading issue? Transmit batteryLevel or some other heartbeat message every hour to find out.
I am a newbie with arduino, what is a heartbeat message?
@gerseun I just mean anything that tells you it's alive. Any kind of message sent to you at a known interval. It could be a flashing LED, radio message logged by controller or whatever.
Any idea? -
I think I solved it.
The reading from the sensor is good bad the trasmission stop randomly, so I tried to add coupling capacitors on the wirless module.
It's more then 24h without problem so I think this solves it. -
