  2. Feature Requests
  3. New Sensor type
New Sensor type
11 Posts 6 Posters 5.4k Views 7 Watching
  • L
    L
    lafleur
    Please consider adding: S_PRESSURE, this could be used for water pressure, air pressure (like in a compressor tank) or ??
    thanks...
    andreacioniA 1 Reply Last reply
    • L lafleur
      thanks...
      andreacioniA
      andreacioniA
      andreacioni
      @lafleur
      Yes could be an idea, but if you need things that are not specified you can think about using: S_CUSTOM as a temporary method ☺
        You might be looking for
        S_BARO	8	Barometer sensor (Pressure)	V_PRESSURE, V_FORECAST
        and
        V_PRESSURE	4	Atmospheric Pressure	S_BARO
        from https://www.mysensors.org/download/serial_api_15#message-structure-elements
        mikeg291M 1 Reply Last reply
        • andreacioniA
          andreacioniA
          andreacioni
          wrote on last edited by andreacioni
          ;) opss, i've not see the s_baro sorry for the wrong suggestion
          • L
            L
            lafleur
            yes, but it imply Barometric pressure, not absolute or reference pressure like from a gauge...
            One could #define S_PRESSURE S_BARO, but this is confusing..
            and S_PRESSURE is generic, S_BARO is specific
            my two bits...
            • mikeg291M
              mikeg291M
              mikeg291
              I agree this is needed . I got interested in my sensors because I wanted to monitor some pressures not knowing there wasn't a S-PRESSURE available.
              regards
                and
                mikeg291M
                mikeg291M
                mikeg291
                @mfalkvidd
                Once , I realized that their wasn't an S_PRESSURE available . I thought about using S_Baro ,however I decided like "lafleur" in his comment that it would be confusing.
                Hopefully , there will be an S_PRESSURE in the future. I am amazed at this point in time there isn't one .
                  Ok. Agree, might be useful.
                    Could we nail down the difference between BARO and PRESSURE, so they can be documented, making it possible for users to know which one they should choose when programming?
                    • L
                      L
                      lafleur
                      Barometric pressure is an atmospheric reference for pressure, where pressure is a generic reference to water pressure, gas pressure, oil pressure ect... or even for Barometric pressure...
                      Its a generic v specific reference types...
                      • AWIA
                        AWIA
                        AWI
                        The only real difference is the name and magnitude. Hecto Pascal vs Pascal
