  3. Control of step down
20 Posts 3 Posters 6.2k Views 3 Watching
  • F Offline
    F Offline
    flopp
    I am using a TLV70033 to step down from from LiPo to 3.3v.
    TLV70033 have an ENABLE pin, 0-0,4v not enabled and 0,9-Vin it is enabled.
    I am using digital 5 as output to enable and disable TLV
    My problem now is that I can't enable it before Setup in my sketch, digitalWrite doesn't work before Setup. pinMode doesn't work before Setup.
    If NRF is used before Setup I can't get it to work.
    Can anyone confirm that NRF is used before Setup or not?
    A 1 Reply Last reply
    • mfalkviddM Offline
      You could probably use the digital pin to pull the signal low instead. Connect a resistor between Vcc and the pin to pull it high by default.
      F 1 Reply Last reply
        F Offline
        F Offline
        flopp
        @mfalkvidd
        Ok, and when I set the pin HIGH in sketch it will go low?
          No, set the pin low in the sketch.
            F Offline
            F Offline
            flopp
            wrote on last edited by flopp
            And to HIGH when I want enable the TLV70033?
            • F Offline
              F Offline
              flopp
              Here is the PDF about TLV70033, if anyone wants read more.
              http://www.ti.com/lit/ds/symlink/tlv70033-q1.pdf
              • F flopp
                A Offline
                A Offline
                AWI
                @flopp Why are you anabling/ disabling the TLV70033? Are you switching the nrf on/off?
                • A AWI
                  F Offline
                  F Offline
                  flopp
                  @AWI
                  Yes and no, I am running on batteries and trying to save battery.
                  With TLV disable my hardware draw 2uA(tested by pulling out Enable cable)with TLV enabled it draws 35uA
                  NRF draws almost nothing but the TLV itself draw 30uA when enabled.
                  • F flopp
                    @AWI
                    A Offline
                    A Offline
                    AWI
                    @flopp Just a suggestion: XC6206 (662k) takes only 1uA...
                    • A AWI
                      F Offline
                      F Offline
                      flopp
                      @AWI
                      Thanks, looks good.
                      Will order and test.
                      • F Offline
                        F Offline
                        flopp
                        I now have another problem.
                        Same sketch but different problem.
                        If a use a digital output, I do not have any resistor connected to the digital pin, to enable/disable TLV.
                        My problem is when I connect pins for I2C(sda and scl) current for whole project goes up to ~300uA if I disconnect SDA it goes down to ~150uA and disconnect SCL it goes down to ~10uA. 10uA is what I have on other project without I2C
                        Very strange for me. It tried to put a 10k between GND and Enable pin on TLV, same current.
                        Any ideas.
                        Can it help with internal pull-up? I am not home right now so I can't try that right now
                        • F flopp
                          Any ideas.
                          A Offline
                          A Offline
                          AWI
                          @flopp Sounds like problems with (internal) pull-ups and signal levels. Can you post the sketch and your design?
                          • A AWI
                            F Offline
                            F Offline
                            flopp
                            @AWI
                            Lots of code that I don't use, I have not clean up yet.
                            * Version 1.0 - Henrik Ekblad
                            * Pressure sensor example using BMP085 module
                            * http://www.mysensors.org/build/pressure
                            #include <Wire.h>
                            #include <Adafruit_BMP085.h>
                            #include <SI7021.h>
                            #define NODE_ID 3
                            #define BARO_CHILD 0
                            #define TEMP_CHILD 1
                            #define BATT_CHILD 2
                            #define HUM_CHILD 3
                            const float ALTITUDE = 8; // <-- adapt this value to your own location's altitude.
                            // Sleep time between reads (in seconds). Do not change this value as the forecast algorithm needs a sample every minute.
                            const unsigned long SLEEP_TIME = 1795000;//1795000=30 min
                            /*const char *weather[] = { "stable", "sunny", "cloudy", "unstable", "thunderstorm", "unknown" };
                            enum FORECAST
                            STABLE = 0,	// "Stable Weather Pattern"
                            SUNNY = 1,	// "Slowly rising Good Weather", "Clear/Sunny "
                            CLOUDY = 2,	// "Slowly falling L-Pressure ", "Cloudy/Rain "
                            UNSTABLE = 3,	// "Quickly rising H-Press", "Not Stable"
                            THUNDERSTORM = 4,	// "Quickly falling L-Press", "Thunderstorm"
                            UNKNOWN = 5	// "Unknown (More Time needed)
                            Adafruit_BMP085 bmp = Adafruit_BMP085(); // Digital Pressure Sensor
                            //int BATTERY_SENSE_PIN = A0; // select the input pin for the battery sense point
                            //int oldBatteryPcnt = 0;
                            long result;
                            SI7021 sensor;
                            int humidity;
                            //float lastPressure = -1;
                            //float lastTemp = -1;
                            //int lastForecast = -1;
                            //const int LAST_SAMPLES_COUNT = 5;
                            //float lastPressureSamples[LAST_SAMPLES_COUNT];
                            float batteryPcnt;
                            float batteryVolt;
                            //int cycle=6;
                            // this CONVERSION_FACTOR is used to convert from Pa to kPa in forecast algorithm
                            // get kPa/h be dividing hPa by 10
                            //#define CONVERSION_FACTOR (1.0/10.0)
                            //int minuteCount = 0;
                            //bool firstRound = true;
                            // average value is used in forecast algorithm.
                            //float pressureAvg;
                            // average after 2 hours is used as reference value for the next iteration.
                            //float pressureAvg2;
                            float dP_dt;
                            float temperature;
                            boolean metric;
                            MyMessage tempMsg(TEMP_CHILD, V_TEMP);
                            MyMessage pressureMsg(BARO_CHILD, V_PRESSURE);
                            //MyMessage forecastMsg(BARO_CHILD, V_FORECAST);
                            MyMessage battMsg(BATT_CHILD, V_VOLTAGE);
                            MyMessage humMsg(HUM_CHILD, V_HUM);
                            pinMode(6,OUTPUT);
                            digitalWrite(6,HIGH);
                            analogReference(INTERNAL1V1);
                            #else
                            analogReference(INTERNAL);
                            sensor.begin();
                            gw.begin(NULL,NODE_ID);
                            gw.sendSketchInfo("Mini Weather", "1.0");
                            if (!bmp.begin())
                            Serial.println("Could not find a valid BMP085 sensor, check wiring!");
                            //while (1) {}
                            // Register sensors to gw (they will be created as child devices)
                            gw.present(BARO_CHILD, S_BARO);
                            gw.present(TEMP_CHILD, S_TEMP);
                            gw.present(BATT_CHILD, S_MULTIMETER);
                            gw.present(HUM_CHILD, S_HUM);
                            Serial.println("start");
                            delay(1000);
                            // get the battery Voltage
                            #ifdef DEBUG
                            Serial.println(sensorValue);
                            // ((305400+100000)/100000)*1.1 = Vmax = 4.46 Volts
                            // 4.46/1023 = Volts per bit = 0.0043591398
                            //float batteryV = sensorValue * 0.004359140;
                            float batteryV = sensorValue * 4.2 / 1023;
                            #ifdef DEBUG
                            Serial.print(batteryV);
                            Serial.println(" V");
                            Serial.print(batteryPcnt);
                            Serial.println(" %");
                            int pressure = bmp.readSealevelPressure(ALTITUDE) / 100.0;
                            //	float temperature = bmp.readTemperature();
                            //	int forecast = sample(pressure);
                            //	Serial.print("Temperature = ");
                            //	Serial.print(temperature);
                            //	Serial.println(metric ? " *C" : " *F");
                            //Serial.print("Forecast = ");
                            //Serial.println(weather[forecast]);
                            si7021_thc data = sensor.getTempAndRH();
                            temperature = data.celsiusHundredths/100.0;
                            humidity = data.humidityPercent;
                            Serial.print("humidity:");
                            Serial.print(humidity);
                            Serial.println("%");
                            Serial.print("Pressure = ");
                            Serial.print(pressure);
                            Serial.println(" hPa");
                            Serial.print("temperature:");
                            Serial.println("°");
                            /*if (temperature != lastTemp)
                            gw.send(tempMsg.set(temperature, 1));
                            lastTemp = temperature;
                            delay(100);
                            if (pressure != lastPressure)
                            gw.send(pressureMsg.set(pressure, 0));
                            lastPressure = pressure;
                            delay(100);
                            /*if (forecast != lastForecast)
                            gw.send(forecastMsg.set(weather[forecast]));
                            lastForecast = forecast;
                            delay(100);
                            readVcc();
                            gw.send(battMsg.set(batteryVolt, 3));
                            //lastTemp = temperature;
                            //lastPressure = pressure;
                            //gw.send(forecastMsg.set(weather[forecast]));
                            //lastForecast = forecast;
                            gw.send(humMsg.set(humidity, 0));
                            delay(100);
                            //cycle=0;
                            digitalWrite(6,LOW);
                            Serial.println("sleep");
                            delay(1000);
                            //cycle++;
                            gw.sleep(SLEEP_TIME);
                            /*float getLastPressureSamplesAverage()
                            float lastPressureSamplesAverage = 0;
                            for (int i = 0; i < LAST_SAMPLES_COUNT; i++)
                            lastPressureSamplesAverage += lastPressureSamples[i];
                            lastPressureSamplesAverage /= LAST_SAMPLES_COUNT;
                            return lastPressureSamplesAverage;
                            // Algorithm found here
                            // http://www.freescale.com/files/sensors/doc/app_note/AN3914.pdf
                            // Pressure in hPa --> forecast done by calculating kPa/h
                            int sample(float pressure)
                            // Calculate the average of the last n minutes.
                            int index = minuteCount % LAST_SAMPLES_COUNT;
                            lastPressureSamples[index] = pressure;
                            minuteCount++;
                            if (minuteCount > 185)
                            minuteCount = 6;
                            if (minuteCount == 5)
                            pressureAvg = getLastPressureSamplesAverage();
                            else if (minuteCount == 35)
                            float lastPressureAvg = getLastPressureSamplesAverage();
                            float change = (lastPressureAvg - pressureAvg) * CONVERSION_FACTOR;
                            if (firstRound) // first time initial 3 hour
                            dP_dt = change * 2; // note this is for t = 0.5hour
                            else
                            dP_dt = change / 1.5; // divide by 1.5 as this is the difference in time from 0 value.
                            else if (minuteCount == 65)
                            if (firstRound) //first time initial 3 hour
                            dP_dt = change; //note this is for t = 1 hour
                            else
                            dP_dt = change / 2; //divide by 2 as this is the difference in time from 0 value
                            else if (minuteCount == 95)
                            dP_dt = change / 1.5; // note this is for t = 1.5 hour
                            else
                            dP_dt = change / 2.5; // divide by 2.5 as this is the difference in time from 0 value
                            else if (minuteCount == 125)
                            pressureAvg2 = lastPressureAvg; // store for later use.
                            dP_dt = change / 2; // note this is for t = 2 hour
                            else
                            dP_dt = change / 3; // divide by 3 as this is the difference in time from 0 value
                            else if (minuteCount == 155)
                            dP_dt = change / 2.5; // note this is for t = 2.5 hour
                            else
                            dP_dt = change / 3.5; // divide by 3.5 as this is the difference in time from 0 value
                            else if (minuteCount == 185)
                            dP_dt = change / 3; // note this is for t = 3 hour
                            else
                            dP_dt = change / 4; // divide by 4 as this is the difference in time from 0 value
                            pressureAvg = pressureAvg2; // Equating the pressure at 0 to the pressure at 2 hour after 3 hours have past.
                            firstRound = false; // flag to let you know that this is on the past 3 hour mark. Initialized to 0 outside main loop.
                            int forecast = UNKNOWN;
                            if (minuteCount < 35 && firstRound) //if time is less than 35 min on the first 3 hour interval.
                            forecast = UNKNOWN;
                            else if (dP_dt < (-0.25))
                            forecast = THUNDERSTORM;
                            else if (dP_dt > 0.25)
                            forecast = UNSTABLE;
                            else if ((dP_dt > (-0.25)) && (dP_dt < (-0.05)))
                            forecast = CLOUDY;
                            else if ((dP_dt > 0.05) && (dP_dt < 0.25))
                            forecast = SUNNY;
                            else if ((dP_dt >(-0.05)) && (dP_dt < 0.05))
                            forecast = STABLE;
                            else
                            forecast = UNKNOWN;
                            // uncomment when debugging
                            //Serial.print(F("Forecast at minute "));
                            //Serial.print(minuteCount);
                            //Serial.print(F(" dP/dt = "));
                            //Serial.print(dP_dt);
                            //Serial.print(F("kPa/h --> "));
                            return forecast;
                            long readVcc() {
                            ADCSRA |= _BV(ADSC); // Convert
                            while (bit_is_set(ADCSRA,ADSC));
                            result = ADCL;
                            result |= ADCH<<8;
                            result = 1126400L / result; // Back-calculate AVcc in mV
                            //return result;
                            batteryPcnt = (result - 3300) * 0.111111;
                            batteryVolt = result/1000.000;
                            /*Serial.print("battery volt:");
                            Serial.println(batteryVolt, 3);
                            Serial.print("battery percent:");
                            Serial.println(batteryPcnt);
                            • F flopp
                              @AWI
                              #include <Wire.h>
                              #include <SI7021.h>
                              #define NODE_ID 3
                              #define HUM_CHILD 3
                              enum FORECAST
                              long result;
                              SI7021 sensor;
                              int humidity;
                              float batteryPcnt;
                              float batteryVolt;
                              //int cycle=6;
                              float dP_dt;
                              float temperature;
                              boolean metric;
                              pinMode(6,OUTPUT);
                              #else
                              sensor.begin();
                              if (!bmp.begin())
                              //while (1) {}
                              delay(1000);
                              #ifdef DEBUG
                              #ifdef DEBUG
                              delay(100);
                              delay(100);
                              delay(100);
                              readVcc();
                              delay(100);
                              //cycle=0;
                              delay(1000);
                              //cycle++;
                              minuteCount++;
                              minuteCount = 6;
                              else
                              else
                              else
                              else
                              else
                              else
                              forecast = UNKNOWN;
                              forecast = CLOUDY;
                              forecast = SUNNY;
                              forecast = STABLE;
                              else
                              forecast = UNKNOWN;
                              return forecast;
                              long readVcc() {
                              result = ADCL;
                              result |= ADCH<<8;
                              //return result;
                              A Offline
                              A Offline
                              AWI
                              @flopp and your circuit? Which are your I2C devices and do you power them down while sleeping?
                              • A AWI
                                F Offline
                                F Offline
                                flopp
                                @AWI
                                mysensorsboard_nocharge.pdf
                                BMP180 and Si7021. Yes, I set LOW on digital 6, so TLV is powered down, right before SLEEP
                                • F Offline
                                  F Offline
                                  flopp
                                  @AWI
                                  Added PDF
                                  • F flopp
                                    @AWI
                                    Added PDF
                                    A Offline
                                    A Offline
                                    AWI
                                    @flopp I cannot find it in the datasheets but I can imagine that the BMP180 and/or si7021 kind of "short" their inputs to ground when power drops to down to Grnd. This would connect the pullups to grn explaining the rise in consumption. Both these sensors take around 0.1 uA in standby so I don't see a need to power them down.
                                    • A AWI
                                      F Offline
                                      F Offline
                                      flopp
                                      @AWI
                                      Thanks for you time.
                                      I have also NRF connected to TLV, so I power down that one also.
                                      If I don't power down my project draw ~60 uA, which I can live with but when power down it will be ~10 uA, that is 1/6.
                                      I run on battery so that is something I want to be able to do.
                                      I will try to have only BMP180 and also test to only have Si7021.
                                      • F flopp
                                        @AWI
                                        A Offline
                                        A Offline
                                        AWI
                                        @flopp One of my nodes, equipped with the same sensors (si7021/ bmp180 and nrf) including the electronics (LDO level conversion etc.) on the sensor boards is consuming around 12uA during sleep. The sensors are all powered from the same LDO (662k).
                                        • A AWI
                                          F Offline
                                          F Offline
                                          flopp
                                          @AWI
                                          Thank again.
                                          I found one 662K at home.
                                          Now it draws ~19uA with everything connected: arduino pro mini(clone), NRF, si7021 and bmp180(without 662k) This is good enough.
                                          12.1k
