  3. MQTT Gw - Request time
4 Posts 2 Posters 1.8k Views 2 Watching
    matias53
    Hi, I´m planning using request time to display some info and current date time
    But I can get response from gateway about requestTime
    I´m using MQTT gateway with OpenHab
    Should I do something on Openhab?
      You have to answer the time request from the node in OpenHab or some broker in between..
      I have too little knowledge of OH to know if this is possible or have been done by someone already.
        matias53
        Hi.
        When I use MQTTFx to see that the gateway is asking to OpenHab I see this.
        MyMQTT/25/255/V_SKETCH_NAME
        RTC Clock
        MyMQTT/25/255/V_SKETCH_VERSION
        1.0
        MyMQTT/25/255/V_
        (no data)
        I saw in the library API that the time request is an internal command, maybe I´m wrong, but shouldn´t I expect a I_TIME instead
        Does anyone know how to respond to this request?
        Thank you.
          You should probably try to use the MQTT client Gateway in the dev-branch. It forwards internal commands as well unlike the gateway in 1.5 which on do some forwards and rewrites of internal commands.
