  2. Announcements
  3. 2.0 Discussion: Units, sensor types and protocol
170 Posts 23 Posters 118.9k Views 7 Watching
  • AnticimexA
    AnticimexA
    Anticimex
    Think "uart" :)
    • tbowmoT
      tbowmoT
      tbowmo
      Think that, for UART it should be enough to send characters (or strings) to the sensor, and send back replies to the master (If anything comes in at the serial port)
      I asume that if one needs to use serial to communicate with some remote device, one will setup baudrate etc. for that particular device in the arduino sketch. So no need to use initialisation commands for the serial stuff.
      For IR it's a bit more complicated, because there is no single protocol definition like serial. for IR it could be RC5, RC6, something else, it can be different carrier frequences etc. for each brand. And it can be send to multiple devices, using the same IR "blaster"
      / Thomas
      AnticimexA 1 Reply Last reply
      • tbowmoT tbowmo
        / Thomas
        AnticimexA
        AnticimexA
        Anticimex
        @Thomas-Bowman-Mørch well, yes. But I am more thinking a "protocol". No matter what serial interface the sensor has externally, any serial interface implement some form of protocol for managing handshaking, flow control, etc. And considering the limitation in the data packets in RF24, we cannot expect to be able to implement a "stream".
        By having a protocol, the sensor node can ensure it collects enough data to be able to satisfy it's external device, i.e. caching data packets for making a larger continuous serial transmission. Or reading a larger continuous transmission and caching it from the device, before starting to transmitting it to the controller. If transmission starts too early, data sent from the device, could be lost (depending on HW/SW solution) as serial protocols do not have to implement flow control (and rarely does).
        Both IR and UART share the same caveats so in that respect, I think it makes good sense to figure out a command type that can satisfy both types as the needs are similar. And then it potentially can also be applied to other serial protocols (CAN for instance).
        • L
          L
          lunarok
          Not very usefull post for you here, but I want to say I'm very pleased to see this discussion and the news I can read here or what appears in dev on the github.
          About the presentation of sub-type accepted. After getting an almost complete controller for Jeedom, we have difficulties to "predict" things to automate and make it very simple for user to use the plugin. Like for exemple, create commands. For relays and dimmer it was easy, but after when we look for servo or some extra type it's impossible to know for now what we can create.
          So reading, the sensor will tell it in presentation it's just perfect.
          Same for the presentation during node of lib used, that's just better than during the sensors, make sense.
          I read also on the protocol page, that there is a way for a node to request data from gateway/controller. Can this point be clarified, maybe it needs also the sensor/node to say what it can request ? That's also for automation of autolink. For us (Jeedom plugin) and I think for other, if we know the sensor is able to request some data, we can automaticly create the information item and the user will have only to map it to the equipment it wants to point. I don't know if this is still included/planned as I'm aware many of the "smart" part must be on the controller side, but with beautiful things like Scene Controller and LCD display, I can imagine there is a need ?
          I read also the OTA process will change a lot. So, is it better waiting 2.0 to include it on our side ? I mean, for the controller part, will this change a lot of things ?
          And last point, there is actually a internal message type Reboot. This one is indicated only working for OTA bootloader. Is that true ?
          If so, is it possible in 2.0 to include a way to request a complete presentation of an already started sensor. (that's why I ask for the Reboot message, simpler to request a reboot so the node will present itself at the same type)
          Sometimes it's easier when migrating for exemple or reinstall, and we know the ID of sensor to ask it for presentating itself than going there to unplug it.
          That's my thoughs after getting a little more in deep of protocol for the controler/plugin :)
          Cédric
          hekH T 2 Replies Last reply
          • A
            A
            aliasdoc
            Hi, I think we could integrate an uuid system in protocol, like this one https://code.google.com/p/tinkerit/wiki/TrueRandom .
            • L lunarok
              Cédric
              True, reboot would send presentation again. But another option is to save the presentations in the api. Still a bit unclear which option I will choose.
              @aliasdoc
              What do you mean the random number should be used for?
              • nneeooN
                nneeooN
                nneeoo
                Hi. I would like my nodes measuring various values (temperature, humidity, ...) to send those values at specific times. I don't want to include the RTC on the node, so would like the node to request a sleep period from the controller. I can see there is no such possibility with the version 1.4 of the protocol. What do you think about including such thing?
                  You can use VAR1-5 for this in 1.4.
                  2.0 will have both VAR (used mostly for pushing custom data) and CONFIG (for custom node configuration).
                  nneeooN 1 Reply Last reply
                  • BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    wrote on last edited by BulldogLowell
                    #129
                    Right now you can use the Time.h library and you don't need an RTC.
                    Just sync the time with MySensors call...
                    gw.requestTime(receiveTime);
                    with the function:
                    void receiveTime(unsigned long controllerTime)
                      Serial.print("Time value received: ");
                      Serial.println(controllerTime);
                      RTC.set(controllerTime);
                      nneeooN
                      nneeooN
                      nneeoo
                      Yeah, good point. I somehow missed these general purpose variables. It might be good to add a dedicated type for it if you'll find it useful. If not I can live with the VAR for sure ;). Thanks.
                        with the function:
                        nneeooN
                        nneeooN
                        nneeoo
                        with the function:
                        Thanks for pointing out this library. However I don't want to track the time on the node, but would like just request the time for which the node should sleep from the controller. I think it makes more sense to have the logic in controller.
                        • nneeooN nneeoo
                          with the function:
                          BulldogLowellB
                          BulldogLowellB
                          BulldogLowell
                          @nneeoo
                          Oh, you are requesting the duration of the sleep... not the moment at which you wish it to sleep.
                          I thought you were wanting it to transmit data at certain times...
                            @nneeoo
                            nneeooN
                            nneeooN
                            nneeoo
                            @nneeoo
                            Well, yes. I want the node to transmit at certain time. Since the controller should know when that time is, it has to be able to calculate for how long should the node sleep, when the node asks the controller. I hope you get my point.
                            • nneeooN nneeoo
                              @nneeoo
                              BulldogLowellB
                              BulldogLowellB
                              BulldogLowell
                              #134
                              @nneeoo
                              yes, so you can use Henrik's advice and store a variable which is the time interval in seconds, minutes or even milliseconds.
                              pass that variable into a function that uses that time as the interval to transmit your data from the sensor.
                              something like this... pseudo code
                              int intervalFromController; //in minutes
                                gw.begin(getVariables, RADIO_ID, false);
                                //your other stuff
                                updateSensorData(intervalFromController);
                              void getVariables(const MyMessage &message) //
                                if (message.sensor == CHILD_ID)
                                  if (message.type == V_VAR1)
                                    // get your V_VAR1
                              updateSensorData(int interval)
                                static unsigned long lastTransmitTime;
                                if (millis() - lastTransmitTime >= interval *60000UL)
                                  //collect and transmit sensor data
                                 //request sensor interval
                                lastTransmitTime += interval * 60000UL;
                              • L lunarok
                                Cédric
                                ToSa
                                Code Contributor
                                Reset and OTA bootloader are independent - but you need to set the fuse bits of the MCU to enable the watchdog for the software reset to work. This is done automatically when flashing the OTA bootloader but you can do that as well in a separate step keeping the existing bootloader (e.g. optiboot).
                                • A
                                  A
                                  aliasdoc
                                  I am currently trying to develop a bridge between mysensors and home kit managed with RPi and for this purpose I need an uuid different of the id used in the my sensors library and I thought the above library is a good start for the generation of a uuid (almost unique).
                                  • Z
                                    Z
                                    Zeph
                                    If there is interest in using somewhat of a standard rather than rolling our own (and I think a case could be made either way), it would be worth reviewing the IoTDB effort which is also trying to describe the semantics of sensor/actuator control. For example:
                                    https://iotdb.org/pub/iot-attribute.html
                                    hekH 1 Reply Last reply
                                    • Z Zeph
                                      Thanks interesting reading.
                                      • daulagariD
                                        daulagariD
                                        daulagari
                                        Yes, indeed interesting reading also in the light of controllers.
                                        • L
                                          L
                                          lunarok
                                          Please to see this post. As our plugin for Jeedom is complet now, I have some feedback to share.
                                          First, is there a date and status of version 2 for now ?
                                          Here my thoughs :
                                          • about units, I agree with the fact that it's lightier to have the Arduino not taking care of it, but instead use some conversion on the controller side
                                          • about value types, it will be better to have really type and not a notion of unit sometime here too like for power get only consuption and not kwh, really going all the way and give the unit control to the controller
                                          • about value types and sensor types, after writing the plugin, still weird for me to have a sensor presentation giving some clue on what type it is, but need to wait for some value to be sure. I mean power sensor for exemple that can get some different type of values, this is not really clean I think. Or the weather sensor, in one case it will send a value type that is numeric, the other one is text (forecast)
                                          • will it not be better to have some mechanism when it's an actuator to deliver the type of message it is accepting ? for exemple a heater, there is the off/on but also a mode type. How is it possible to know that the sensor is accepting all or only on/off ?
                                          So, for me, something like after a presentation being able on the controller to say what type of data and what commands we can say, will be the best. And important too, what data it can be requesting. I mean, now with the scene_controller to extend functions, we need to get data from the automation software too. Imagine to display some informations from outside the mySensors network.
                                          Maybe by completing the sensor_type and merging with value_types, removing the unit notion inside the value. And so during presentation we know all about the data it can send. And in second step during presentation, declare the actuator commands.
                                          One other point important and asked by some users, is it possible to integrate some security in the protocol ? As soon you talk about actuator accepting command from anyone, that's unsecure. Key given during inclusion by gateway and use for encode the data ?
                                          Thanks for reading
                                          Cédric
