  3. ESP8266 as WiFi gateway that posts to Thingspeak
6 Posts 3 Posters 3.5k Views 5 Watching
  • LendogL Offline
    LendogL Offline
    Lendog
    Thanks to Hek/Yveaux/nikil511 I’ve got an ESP8266 wifi gateway that posts sensors readings directly to thingspeak without need for a computer :)
    At the moment my code is setup for sending temperature and wind speed readings to two separate thing speak channels. It could be easily modified for single or even more channels or diffrent data
    I have only changed the original Esp8266Gateway.ino code but have included the GatewayUtil.h in it for completeness. Also note it requires all the same mysensor library’s etc.
    The code can be found here
    https://github.com/Lendog/Mysensors-ESP8266-Wifi-gateway-post-to-thingspeak
    One thing to note: is thingspeak requires 15 second wait before readings. This is handled on the sensor side and not on the esp8266. I think readings just don't get posted if it’s less than 15 seconds, this is not critical in my application so i haven’t worried about investigated alternative solutions.
    Would be awesome if part of the code gets integrated into the original, as posting to thingspeak maybe beneficial to other users.
    also my wificheck is handled slightly differently. I've heard the esp locks up if no valid connection and http post occurs. Haven’t tried it, I just figured it’s good to check first before posting.
    Anyway hope someone else may find this useful.
    jumpingJ 1 Reply Last reply
    • LendogL Lendog
      jumpingJ Offline
      jumpingJ Offline
      jumping
      @Lendog Hello, is the sketch compatible with Mysensosr 2.0 ?
      thanks
      Raspberrry PI3 - Domoticz
      ESP8266 GW - MySensors 2.1.1
      • LendogL Offline
        LendogL Offline
        Lendog
        It should work. If it doesn't let me know and I may have a look at it.
        But I've been happy with it, once i got it sorted I haven't looked at the code since. Haven't needed to :)
        • L Offline
          L Offline
          leeoz
          Hi. It doesnt work with mysensors 2.0 compling it. Any chance to covert it to be able to compile with 2.0 version?
          • LendogL Offline
            LendogL Offline
            Lendog
            Thanks. Might try to updated it in the next few days if I get a chance. Think the original library I used was 1.5.1 if that's any help
            • LendogL Offline
              LendogL Offline
              Lendog
              I've created a new branch at
              https://github.com/Lendog/Mysensors-ESP8266-Wifi-gateway-post-to-thingspeak/tree/My-sensors-library-2.0
              I feel a bit slack not properly testing it yet and putting it online, but it compiles fine just haven't loaded it on or tested with sensors. Might need to look into updating a sensor or 2 to run on the new libary
