  3. Radio problems
Radio problems
1.4b1nrf24l01+pa+lna
25 Posts 8 Posters 15.5k Views 1 Watching
  • J Offline
    J Offline
    jocke4u
    DAMN :( :(
    I think dataMine played a prank on me and the statistic is probably not correct (not logging everything). Will hook in my MQTT monitor to extract statistics in a way I control it.
    Currently I am running 1.3b3 and will run a test sensor for a while to see how it's works and then eventually go for 1.4 again.
    Thanks for your support and I have learnt more about power and capacitors :)
    • Y Yveaux
      @ServiceXp said:
      Can't say that about 1.4.
      Do you mean you're having problems with 1.4 then or did you just not have any experience with it yet?
      R Offline
      R Offline
      RJ_Make
      @Yveaux
      I think both.. The radio problems I had drove me crazy, and then there's still the temps not converting to F using the existing 1.4b library. Which is not a big problem thanks to @hek help.
      I literately had zero issues with the 1.3b library.
      RJ_Make
      Y 1 Reply Last reply
      • R RJ_Make
        @Yveaux
        Y Offline
        Y Offline
        @ServiceXp I'm not aware of any major issues with 1.4 at the moment and @hek is about to tag it. If you are really having (radio) issues related to 1.4 we should fix them asap.
        R 1 Reply Last reply
        • Y Yveaux
          R Offline
          R Offline
          RJ_Make
          wrote on last edited by RJ_Make
          #24
          @Yveaux
          At this point I think I found the solution, but have not built up another test bed to make sure the solution worked. The temp conversion problem is persistent,
          http://forum.mysensors.org/topic/309/1-4b-radio-transmission-problem-not-present-in-1-3b
          RJ_Make
          • R RJ_Make
            @Yveaux
            Y Offline
            Y Offline
            #25
            @ServiceXp you said in this post:
            That was it!!!!! I tried 22uF, was still doggie, so I thought why not move up to 47uF wink and what do you know, that seems to be the winning value. I have some more testing, but looking pretty good so far.
            This sounds to me that the issue is solved...
            I can imagine that 1.4 requires a bigger cap while 1.3 doesn't. 1.4 uses auto acknowledge which can send burst packets. This could put a bigger load on your power supply.
