  3. CE line on sensor node?
29 Posts 6 Posters 10.5k Views 1 Watching
  • aquaproA
    aquaproA
    aquapro
    hm ... if CE inverted, ping sample should not work?! CE must switch between hight and low for TX and RX right? But Ping sample send and receive works.
    • aquaproA
      aquaproA
      aquapro
      I have bought the new modules (right on pic), which operate without modification. I simply swapped and all is fine.
      What do I do with the other. How can I test inverted.
      hekH 1 Reply Last reply
      • aquaproA aquapro
        @aquapro
        I hope you didn't get the left one when purchasing through the links in the MySensors "store"?
        • aquaproA
          aquaproA
          aquapro
          I got the left one from other eb..-"store".
          • aquaproA
            aquaproA
            aquapro
            The left one works with MySensor-Coding, but only with disconnected CE line.
            • Z
              Z
              Zeph
              If it truly works correctly with CE disconnected, that could be an advantage when there is a shortage of pins (eg: 8 pin ATTiny).
              Have you achieved full operation without CE on the old modules?
              And did you leave CE floating or tie it high?
              • aquaproA
                aquaproA
                aquapro
                I still see no difference when CE is disconnected.Only it as work at all.
                • Z
                  Z
                  Zeph
                  What vendor did you use to get the "no CE needed" variants? That could be useful to test.
                  I'm assuming that the nRF24L01+ doesn't work without CE connected, right?
                  • aquaproA
                    aquaproA
                    aquapro
                    Eb.. no. 360917673897 vendor "liuddndd2009"
