  3. CE line on sensor node?
29 Posts 6 Posters 10.5k Views 1 Watching
  • aquaproA aquapro
    @Yveaux
    Looking at the pictures I have a hard time figuring out the connections for pins 8..12, while these are just the interesting part...
    Pin 8?
    DammeD
    DammeD
    Damme
    Code Contributor
    @aquapro I dont think you got a nordic semiconductor nrf24l01, What I can find they are only in QFN package.
    http://www.nordicsemi.com/eng/Products/2.4GHz-RF/nRF24L01
    So the specs on that chip may be different. Maybe CE is inverted?
    • aquaproA
      aquaproA
      aquapro
      hm ... if CE inverted, ping sample should not work?! CE must switch between hight and low for TX and RX right? But Ping sample send and receive works.
      • aquaproA
        aquaproA
        aquapro
        I have bought the new modules (right on pic), which operate without modification. I simply swapped and all is fine.
        What do I do with the other. How can I test inverted.
        hekH 1 Reply Last reply
        • aquaproA aquapro
          @aquapro
          I hope you didn't get the left one when purchasing through the links in the MySensors "store"?
          • aquaproA
            aquaproA
            aquapro
            I got the left one from other eb..-"store".
            • aquaproA
              aquaproA
              aquapro
              The left one works with MySensor-Coding, but only with disconnected CE line.
              • Z
                Z
                Zeph
                If it truly works correctly with CE disconnected, that could be an advantage when there is a shortage of pins (eg: 8 pin ATTiny).
                Have you achieved full operation without CE on the old modules?
                And did you leave CE floating or tie it high?
                • aquaproA
                  aquaproA
                  aquapro
                  I still see no difference when CE is disconnected.Only it as work at all.
                  • Z
                    Z
                    Zeph
                    What vendor did you use to get the "no CE needed" variants? That could be useful to test.
                    I'm assuming that the nRF24L01+ doesn't work without CE connected, right?
                    • aquaproA
                      aquaproA
                      aquapro
                      Eb.. no. 360917673897 vendor "liuddndd2009"
