  3. 💬 MySensors Stable Node
mysensorscontest2016
103 Posts 29 Posters 71.3k Views 36 Watching
  • S Slorf
    @Koresh
    Sorry for the late reply, our second son was born just 2 weeks ago.... no sleep anymore :-)
    It looks like this one, except mines it labelled: 0935VI, the one on the link 0935VJ
    http://www.aliexpress.com/store/product/NRF24L01-QFN20-24L01-SMD-chip-new-original-SDQYS/1823911_32468479303.html
    Y
    Y
    yury
    @Slorf said:
    reply
    Congrats and enjoy ))
    • Sander TeunissenS
      Sander TeunissenS
      Sander Teunissen
      @koresh Just created a light sensor from one of the boards I bought from you. It works great !
      I had to do some tweaking with the serial monitor speed from my arduino IDE (I had to double the speed which was set in the code or something)
      I also had to press the reset button just before uploading of the sketch started.
      Apart from that: Great !
      Thanks !
      KoreshK 1 Reply Last reply
      • Sander TeunissenS Sander Teunissen
        Thanks !
        KoreshK
        KoreshK
        Koresh
        wrote on last edited by Koresh
        #83
        @Sander-Teunissen
        Thanks to your responce.
        I'm sorry to hear you faced some hardware problem. Of course the board must restart itself. It may be couse of low quality of mounting first boards or it was damaged during delivery :(
        May be you used incorrect usb-ttl converters boards without correct dtr line? I faced them year ago.. it was bad surprise )
        Sander TeunissenS 1 Reply Last reply
        • KoreshK Koresh
          @Sander-Teunissen
          Sander TeunissenS
          Sander TeunissenS
          Sander Teunissen
          @Koresh No problems. I am happy working with them.
          • Sander TeunissenS
            Sander TeunissenS
            Sander Teunissen
            @Koresh I guess I already know the answer, but this board works with 3.3 volts ? If I want to connect something like this:
            https://www.mysensors.org/build/motion ,which works only on 5V I'd need to add a step up converter ?
            Sander.
              Sander.
              KoreshK
              KoreshK
              Koresh
              #86
              Sander.
              Board contains two 3.3v LDO. You can change one of them to 5v (do not forget check schematic).
              • hensingH
                hensingH
                hensing
                @Sander-Teunissen you can modify the motion sensor to work on 3.3V (see http://www.instructables.com/id/Convert-a-5v-PIR-Motion-Sensor-to-33v-for-ESP8266/)
                • hensingH
                  hensingH
                  hensing
                  @Koresh can you give us an ETA of the sensor? I'm looking forward to buy some :)
                  • TigroenotT
                    TigroenotT
                    Tigroenot
                    I aasembled your node, but the radio chip version is not the + one. After burning the MYS bootloader is prints the debug in serial:
                    60110 TSM:FAIL:RE-INIT
                    60112 TSM:INIT
                    60119 !TSM:INIT:TSP FAIL
                    60123 TSM:FAIL:CNT=7
                    60125 TSM:FAIL:PDT
                    Any suggestions?
                    • TigroenotT Tigroenot
                      60112 TSM:INIT
                      60125 TSM:FAIL:PDT
                      Any suggestions?
                      KoreshK
                      KoreshK
                      Koresh
                      60112 TSM:INIT
                      60125 TSM:FAIL:PDT
                      Any suggestions?
                      For not the + version you should mount 1M resistor (R21). And check all soldering points of course.
                      • TigroenotT
                        TigroenotT
                        Tigroenot
                        I checked everything twice of course. I don't have 0402 1M resistor, the smallest I have is 0805 :)
                          KoreshK
                          KoreshK
                          Koresh
                          You can easily solder THD resistor in parallel with Q2 ;)
                          • TigroenotT
                            TigroenotT
                            Tigroenot
                            @Koresh Did that. No luck.
                            0 MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.1.0-beta
                            4 TSM:INIT
                            4 TSF:WUR:MS=0
                            12 !TSM:INIT:TSP FAIL
                            14 TSM:FAIL:CNT=1
                            16 TSM:FAIL:PDT
                            • TigroenotT
                              TigroenotT
                              Tigroenot
                              Allright, I have replaced the nrf chips to those with + and... that was it, everything is working very well now :)
                              Here they are, freshly handmade :)
                                KoreshK
                                KoreshK
                                Koresh
                                #95
                                @Tigroenot
                                I'm really happy to see your success with these boards. Congratulations! :thumbsup:
                                • qqlapralineQ
                                  qqlapralineQ
                                  qqlapraline
                                  Very nice design ! I wish it was available for sale !
                                  I have a question, though. Would it make sense to mutualize the Crystal between the NRF and the Atmel ?
                                  • qqlapralineQ qqlapraline
                                    KoreshK
                                    KoreshK
                                    Koresh
                                    @qqlapraline Thanks for your attention to this project. A small batch of these boards is ready. Boards are under tests (individually) and almost ready for sale. Unfortunatelly I have "small" technical troubles with ebay :anguished: but hope to solve them soon. Otherwise you will be able to buy them via paypal directly soon :wink:
                                    • qqlapralineQ
                                      qqlapralineQ
                                      qqlapraline
                                      wrote on last edited by qqlapraline
                                      #98
                                      @qqlapraline said in 💬 MySensors Stable Node:
                                      (I love to quote myself :grin: )
                                        KoreshK
                                        KoreshK
                                        Koresh
                                        #99
                                        I saw your question the first time, but it is a relatively hard question so I read documentation before writing the answer. I think this is a not good idea, very many inconsistencies. First, NRF24L01+ chip has a requirement:
                                        Input crystal amplitude and current consumption
                                        The input signal should not have amplitudes exceeding any rail voltage. Exceeding rail voltage excites the
                                        ESD structure and consequently, the radio performance degrades below specification. You must use an
                                        external DC block if you are testing the nRF24L01+ with a reference source that has no DC offset (which is
                                        usual with a RF source).
                                        If you want to be able to share atmega's crystal you must use Full Swing Crystal Oscillator mode (by default arduino uses Low Power Crystal Oscillator mode). You can set this mode without any problems via fuses, but in this case you can't power atmega from 5V (according nrf24L01+ requirement).
                                        However in this case you can't use 16Mhz crystal because 3.3v/16Mhz is overclocked mode for the atmega 328p (I do not say your device will not work, I say atmel do not garantee stability in this case)
                                        As you can see on the latest photo, I didn't solder atmega328p crystals at all and the chip uses an internal oscillator and is powered from 5V :)
                                        • KoreshK
                                          KoreshK
                                          Koresh
                                          Unfortunately I can't open my ebay shop right now. While I'm trying to open it, you can buy this board here: https://www.ebid.net/eu/for-sale/arduino-ide-compatible-controller-with-the-nordic-nrf24l01-radio-transceiver-156695123.htm
