  2. Announcements
  3. MySensors 1.4 Released
72 Posts 19 Posters 37.9k Views 2 Watching
  • M mikeones
    @hek
    It appears sending "255;255;3;0;4;1\r\n" fixes my issue.
    send: 255-255-255-0 s=255,c=3,t=3,pt=0,l=0,st=fail:
    read: 0-0-255 s=255,c=3,t=4,pt=0,l=1:1
    id=1
    sensor started, id 1
    @mikeones
    Ok thanks. I will make this more robust. It should be ok to skip the carriage return character.
      mikeones
      wrote on last edited by mikeones
      #42
      What does st=fail represent? Is that stating the ack failed or sending failed? Would this error show up for all messages if debug is enabled on the sensor node and not the gateway.? Maybe this is a non issue? I am trying to confirm if gw.getConfig and gw.requestTime requests are reaching the GW since they don't seem to be set consistently in my environment.
      sensor started, id 3
      send: 3-3-0-0 s=255,c=0,t=17,pt=0,l=3,st=fail:1.4
      send: 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
      send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=8,st=ok:Humidity
      send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
      send: 3-3-0-0 s=0,c=0,t=7,pt=0,l=3,st=fail:1.4
      send: 3-3-0-0 s=1,c=0,t=6,pt=0,l=3,st=fail:1.4
      send: 3-3-0-0 s=1,c=1,t=0,pt=7,l=5,st=fail:25.8
      T: 25.80
      send: 3-3-0-0 s=0,c=1,t=1,pt=7,l=5,st=fail:50.4
      H: 50.40
      T: 25.80
      H: 50.40
        ###1.4 update 1 released
        NOTE: This release does not require you to update all nodes . Nothing has changed in protocols.
        • All outgoing messages from gateway included a newline character. This has now been fixed.
        • The msg.getByte() wrongfully used atoi() conversion if payload was of string type.
        • The getByte-bug caused problems when receiving Metric/Imperial settings from controller.
        • A new sleep-method added to allow wake-up on both external interrupts.
        • A new example BinarySwitchSleepSensor showing the new sleep function (thanks @Anticimex).
        • Library code (RF24) reduced by 624 bytes (thanks @Damme)
        • Many people has reported powering problems when using amplified version of the NRF-chip on their gateway. The Arduino Nanos 3v3 output does not seem to be sufficient for PA_MAX. The radio needs to be feeded separately with a stable 3v3 to work. Defaulting gateway PA-level to LOW now and if you are using a vanilla radio on gateway you can switch back to MAX in your MyConfig.h.
        RJ_MakeR
        RJ_MakeR
        RJ_Make
        @hek said:> ###1.4 update 1 released
        Was this release supposed to fix the C to F conversion problem I've been having? I just updated and problem persists for me.
        RJ_Make
        hekH 1 Reply Last reply
        • RJ_MakeR RJ_Make
          @ServiceXp
          Think I found the config problem. No wonder it didn't work. Please download and try again.
          @mikeones
          You should now be able to omit carriage return now.
          The fail you're seeing is for the inter-node-ack.
          Just verified requesting time from controller and it seems to work fine here (using the example sketch).
          RJ_MakeR 1 Reply Last reply
          • YveauxY
            YveauxY
            @hek When MySensors has no parent, or fails to contact parent for a number of times, the findParentNode() method is entered.
            This sends a broadcast (ignoring the result) and then waits at most 2 seconds for a response.
            When this response doesn't come, the sensor just carries on as if the parent has been found, sending messages until again a number of times it failed to contact the parent.
            Shouldn't findParentNode() either block until the parent has been found (maybe not desirable for battery based nodes) or only reset the failedTransmissions counter when a succesful response from the parent has been received?
            • YveauxY Yveaux
              Blocking is as you say a bad idea for battery sensors (1.3 had this problem resulting in drained batteries).
              How would it help to reset failedTransmissions?
              YveauxY 1 Reply Last reply
                @Yveaux
                BTW. Do you have any idea why this happens?
                http://forum.mysensors.org/topic/347/1-4-error-compiling-with-pinchangeint-h-library-file/5
                I can't explain why linker includes things from MyGateway.cpp when compiling sensor examples.
                  YveauxY
                  YveauxY
                  Just thinking out aloud:
                  • Don't reset failedTransmissions in findParentNode()
                  • Reset failedTransmissions only when a new parent has been found
                  • In sendRoute() first perform findParentNode() when failedTransmissions > SEARCH_FAILURES
                  • When succesful (failedTransmissions == 0) perform sendWrite()
                  This will always first try to find a parent when none has been found yet, before trying to send the message.
                  If it fails, the send of the message will fail and the (battery powered) sensor will just carry on as if the message has been send, and sleep the sensor as usual.
                  Just sending to a known-bad parent node should be avoided at all times.
                  • YveauxY Yveaux
                    @Yveaux
                    Sounds good. Go for it!
                    YveauxY 2 Replies Last reply
                      @Yveaux
                      YveauxY
                      YveauxY
                      @hek ;-)
                        @Yveaux
                        YveauxY
                        YveauxY
                        Compiler & linker seem to be configured correctly in 1.5.7 (see hardware\arduino\avr\patform.txt)
                        Did you have a look at the map-file? What exactly is included from the MyGateway.cpp file?
                          @Yveaux
                          YveauxY
                          YveauxY
                          #52
                          @hek I'm also a bit puzzled by the RF24::enableAckPayload() and RF24::writeAckPayload() calls in the library, just like @Zeph .
                          If I disable them the findParentNode() call only seems to emit a single message (which I can understand, as auto-ack is disabled for broadcasts), while 16 will be emit when the calls are enabled.
                          Looks like auto-ack doesn't get disabled for broadcasts in this case.
                          A sending nRF24 will immediately & automatically **switch to listen to the destination node's ID **after it has sent its message. Reason for this is that the nRF24 packet format only contains a destination node address and no source. The receiving node has no idea where the message came from and does not know who to send the ack to. Therefore it just sends the ack to its own node address, which the transmitting node happens to listen to.
                          I tested only with a single sensor sending to a non-existent parent, but I can imagine that when auto-acks are enabled for broadcasts the s**t will definately hit the fan when there are many nodes within close proximity!
                          • YveauxY Yveaux
                            @Yveaux
                            Ok, I'll download 1.5.7 and test again. Can't find any map-file anywhere in the build directory.
                              @Yveaux
                              YveauxY
                              YveauxY
                              I think Arduino does not enable it by default. You either have to add generation to the build-parameters in platform.txt, or generate it afterwards .
                              • YveauxY Yveaux
                                Ok, 16! Hmm..not good.
                                Could you perhaps do some more verifications with removed ackPayload/writeAckPayload while sniffing to see that everything works as expected with the whole findParent?
                                Would be a nice addition to get this removed while you refactor findParent.
                                  YveauxY
                                  YveauxY
                                  @hek first need to rebuild the mysensors setup. Everything is Radiohead now....
                                  • YveauxY Yveaux
                                    :O
                                    You sniffing is really helpful finding bugs and quirks in the radios bwt!
                                      :O
                                      YveauxY
                                      YveauxY
                                      @hek yeah I know. I can't think of developing any networking stack without knowing what's really going on...
                                      Why don't you build one yourself ? ;-)
                                      • YveauxY Yveaux
                                        @Yveaux
                                        I would really love to, but unfortunately I don't have any computer to lobotomize with windos.
                                          @Yveaux
                                          YveauxY
                                          YveauxY
                                          @hek maybe run it in a virtual machine?
                                          I should have written the serial-wireshark bridge in a more portable way...
