  3. 💬 Various bootloader files based on Optiboot 6.2
optiboot
164 Posts 18 Posters 95.4k Views 18 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    #21
    @GertSanders Unfortunately, I was able to upload the bootloader, but was not able to upload any sketches on the breadboard:
    avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x78
    avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xc0
    avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x78
    Not sure why - I can upload a sketch via the programmer though. Will upload Nick Gammon sketch to test the bootloader.
    UPDATE1: Nick Gammon's sketch cannot detect the bootloader (tried 1MHz internal). Once again, I uploaded the bootloader (1Mhz internal) and the sketch via the programmer and it works, but....the serial monitor works only on 74880, despite for "1Mhz internal" boards.txt clearly says "9600":
    BlueBoard.menu.mhz.1Mi= 1Mhz - internal - 9K6 upload speed
    BlueBoard.menu.mhz.1Mi.bootloader.low_fuses=0xE2
    BlueBoard.menu.mhz.1Mi.bootloader.high_fuses=0xDE
    BlueBoard.menu.mhz.1Mi.build.f_cpu=1000000L
    BlueBoard.menu.mhz.1Mi.upload.speed=9600
    BlueBoard.menu.mhz.1Mi.bootloader.file=myoptiboot/optiboot_atmega328_01M_009600_B0.hex
    Additionally, I loaded the ASCIITable example sketch and it states " Serial.begin(9600);"
    I do not understand why it works only on 74880...
    • alexsh1A alexsh1
      GertSandersG
      GertSandersG
      GertSanders
      wrote on last edited by GertSanders
      #22
      @alexsh1
      I will do some testing tonight, I have not used the 1MHz bootloader yet.
      The instruction Serial.begin(9600) is independant of the upload.speed mentioned in the boards file. But I would expect that at 1MHz the higher serial comms speeds also give errors.
      A possible reason for the problem, is that the fuse E2 actually means that you run the processor at 8Mhz internally, but without any clock division, while the bootloader was compiled for 1MHz. Without clock division by 8 the processor actually runs at 8Mhz (the speed of the internal oscillator), while all timing code is set for a cpu working frequency of 1Mhz. This would also explain why you can communicate at 74880 (which is close to 76800, which in turn is 8 times 9600).
      I think the fuse should be set to both internal 8MHz oscillator AND clock division by 8. I do not know that correct value by hart, need to check that with a fuse calculator.
      UPDATE: I think the lower fuse should be set to 0x62 instead of 0xE2.
      • alexsh1A
        alexsh1A
        alexsh1
        @GertSanders
        OK, I have come to the following fuse settings for 1Mhz internal:
        BlueBoard.menu.mhz.1Mi.bootloader.low_fuses=0x62
        For Optiboot, the high fuse is always 0xDE.
        Now, a standard example sketch runs at 9600 - I have not checked if atmega328p is running at 1Mhz.
        Still have a problem uploading a sketch on the breadboard via FTDI
        GertSandersG 2 Replies Last reply
        • alexsh1A alexsh1
          @GertSanders
          GertSandersG
          GertSandersG
          GertSanders
          @alexsh1
          I will do some tests later tonight.
          • alexsh1A alexsh1
            @GertSanders
            GertSandersG
            GertSandersG
            GertSanders
            #25
            @alexsh1
            I just loaded a blink sketch at 4800 baud using FTDI and that works with the following combination:
            Boot loader:
            0_1457554985438_optiboot_atmega328_08M1_004800_B0.hex
            Fuses:
            BlueBoard.menu.mhz.1Mi48= 1Mhz - internal 8MHz DIV 8 - 4K8 upload speed
            BlueBoard.menu.mhz.1Mi48.bootloader.low_fuses=0x62
            BlueBoard.menu.mhz.1Mi48.bootloader.high_fuses=0xDE
            BlueBoard.menu.mhz.1Mi48.build.f_cpu=1000000L
            BlueBoard.menu.mhz.1Mi48.upload.speed=4800
            BlueBoard.menu.mhz.1Mi48.bootloader.file=myoptiboot/optiboot_atmega328_08M1_004800_B0.hex
            You will have to strip the "0_1457554985438_" part from the uploaded filename.
            Loading the sketch is VERY slow, but it works perfectly. The Blink sketch blinks the led at 500ms on and 500ms off, and that is checked on the breadboard.
            Whether the processor actually runs at 1MHz I do not know for sure, since I have no frequency meter (still missing from my toolbox).
            I used an arduino as ISP to load the boot loader, and then used an FTDI interface (from Adafruit) to load the sketch while the atmega328 was plugged in a breadboard (Gammon style).
            Next I will try with the 9600 baud version at 1Mhz.
            alexsh1A 1 Reply Last reply
            • GertSandersG GertSanders
              @alexsh1
              Boot loader:
              Fuses:
              alexsh1A
              alexsh1A
              alexsh1
              THanks
              I'm looking forward to this - 4800 is way too slow.
              I think the way to check the frequency is to time delay(1000); in the blink sketch...
              • alexsh1A alexsh1
                THanks
                GertSandersG
                GertSandersG
                GertSanders
                #27
                @alexsh1
                I just tested with the 9600 baud version at 1MHz, and the blink sketch at 250ms, 500ms and 1000ms per on/off cycle. All rock solid and as expected.
                Here is the setup I tested the transfer with FTDI:
                I used the following combination:
                Boot loader:
                0_1457556618255_optiboot_atmega328_01M_009600_B0.hex
                Fuses:
                BlueBoard.menu.mhz.1Mi= 1Mhz - internal 8MHz DIV 8 - 9K6 upload speed
                Also here the "0_1457556618255_" is added by uploading on this forum, strip when downloaded.
                Uploads were at twice the speed then before. Still slow, but acceptable.
                • alexsh1A
                  alexsh1A
                  alexsh1
                  @GertSanders I have the same breadboard setup, but can only read serial and cannot upload a sketch (out of sync). My settings are the same as yours as per my post earlier on today so I reckon it must be something wrong with the wiring on the breadboard since "Uploading using Programmer" works fine. Not sure what it is as I checked it a few times today.
                  • alexsh1A alexsh1
                    GertSandersG
                    GertSandersG
                    GertSanders
                    #29
                    @alexsh1
                    Maybe make a picture of your setup?
                    Upload using programmer means you use another Arduino to load the sketch on the atmega328, which at the same time deletes any bootloader.
                    I load bootloaders with an Arduino and the sketch ArduinoISP loaded on that one. Then I issue a "burn bootloader" command.
                    To load sketches I switch to my FTDI interface and upload sketches with the same processor setting. But as said with a different interface. And I do not use "upload using programmer", but the upload button next to the compile button.
                    Maybe I should try to make a video like Mr Pete.
                      @alexsh1
                      alexsh1A
                      alexsh1A
                      alexsh1
                      #30
                      @GertSanders Yes, this is normally the way I do (burn bootloader and then upload a sketch via FTDI on the breadboard). Will post photos shortly.
                      Are you sure "Upload using programmer" deleting the bootloader?
                      • alexsh1A alexsh1
                        alexsh1A
                        alexsh1A
                        alexsh1
                        @GertSanders
                        Yes, looks like you are right - it kills the bootloader. So what's happening? I do not have any bootloader when I use this method to load up sketches?
                        • alexsh1A alexsh1
                          @GertSanders
                          GertSandersG
                          GertSandersG
                          GertSanders
                          @alexsh1
                          If you load a sketch with "Upload using programmer" you replace anything in flash with the sketch. Just the sketch will run on the mcu.
                          In the very narrow node, there is no FTDI connector, so for those nodes it does not make sense to have a boot loader in flash (it does not hurt either). You couldvjust as well just load the sketch and skip the boot loader altogether.
                          If you need the extra 512 that optiboot occupies, then "Upload using programmer" allows you to recuperate that space.
                          So this shoudl explain why you can reed data from the Node via Serial (because the sketch is running and taking care of the serial connection), but why uploading a sketch fails, because for that you need a boot loader in flash.
                          • alexsh1A
                            alexsh1A
                            alexsh1
                            @GertSanders
                            I did a short video how I upload optiboot
                            Finally, success!
                            I think I had to reassemble the breadboard set-up three times before finally being able to upload the sketch. I think the problem was no connection at RTS, but I am not sure. I need to assemble a more permanent board to upload sketches via FTDI.
                            • alexsh1A
                              alexsh1A
                              alexsh1
                              #34
                              FTDI Adapter
                              • alexsh1A
                                alexsh1A
                                alexsh1
                                My Set-up
                                • alexsh1A
                                  alexsh1A
                                  alexsh1
                                  #36
                                  @GertSanders if I load a sketch via Upload using programmer - how do I control the frequency? (1Mhz or 8Mhz internal or external crystal)
                                  S 1 Reply Last reply
                                  • alexsh1A alexsh1
                                    Samuel235
                                    #37
                                    @alexsh1 - You would do this by setting the correct fuses. Can you just confirm my information @GertSanders :)
                                    I would also like to state that Atmel does not support or even recommend using FTDI with the internal crystal, my current board just will not upload via FTDI and no external crystal however yet a arduino pro mini does and that uses an external crystal with no other circuitry compared to my board apart from the physical reset switch.
                                    MySensors 2.1.1
                                    • S Samuel235
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      I think you have a point, but if I do not change anything, just use "Upload using programmer", what are the default frequency and fuses?
                                      S GertSandersG 2 Replies Last reply
                                      • alexsh1A alexsh1
                                        Samuel235
                                        @alexsh1 If you haven't touched the ATmega328p then it should be sitting with fuses of; L:0x62 H:0xD9 E:0xFF, which would run the uC at 1MHz
                                        MySensors 2.1.1
                                        • alexsh1A alexsh1
                                          GertSandersG
                                          GertSandersG
                                          GertSanders
                                          @*alexsh1
                                          Which fuses are set when loading a boot loader is defined by wich menu element in tools you have selected. Every processor or board you choose will correspond with values in a board.txt file.
                                          You can have several board.txt files: 1 file per "family" of boards.
                                          When uploading sketches, the fusesettings are ignored, only the uploadspeed counts then. Both when uploading with Arduino as ISP as with FTDI interface.
                                          The internal oscillator of 8 Mhz is not as accurate as a crystal, so at higher uploadspeeds the errorrate can increase or decrease depending on the mcu temperature.
                                          Some uploadspeeds are closer to optimal then others in relation to the frequency at which the mcu works. The baudcalculator shows the errorrates. Most are non optimal. avrdude can handle an errorrate of 2% or less. So using a specific baudrate in combination with the internal 8Mhz oscillator depends on the worst case combination of transmission errorrate plus clock deviation error.
                                          For most mcu's the rate of 9600 baud will be acceptable because at that slow rate a clockerror will be relative small. At higher speeds the small clockerror becomes more important. Then it is best to choose an upload speed close to the optimum.
                                          The fusesettings are only burnt when loading a boot loader (within the Arduino IDE, in AVRStudio you can set fuses seperatly from loading anything).
                                          The frequency of 8 Mhz can be obtained via a 8mhz crystal or the internal 8mhz oscillator. The low fuse value 0xE2 sets this internal oscillator. By using value 0x62 you also set the clock division bit in combination with the 8mhz internal oscillator, so your mcu will run at 8mhz / 8 = 1mhz
                                          There are other division values possible. Calculate the low byte value using an avr fuse calculator.
                                          You can also use an external 8 mhz crystal, and combine this with clock division by 8 to get 1mhz operation.
                                          And you can choose an external 1mhz crystal.
                                          All this from choose the right fuse bits.
                                          Same for Brown out Detection which is set via the three least significant bits of the extended fuse.
