  3. 💬 Various bootloader files based on Optiboot 6.2
optiboot
164 Posts 18 Posters 90.2k Views 18 Watching
  • S Offline
    Samuel235
    I'm sorry, i don't understand the issue at hand.... Could you attempt to explain any clearer?
    MySensors 2.1.1
    mar.conteM 1 Reply Last reply
    • mar.conteM Offline
      mar.conteM Offline
      mar.conte
      This post is deleted!
      • S Samuel235
        mar.conteM Offline
        mar.conteM Offline
        mar.conte
        @Samuel235
        Hy
        My project is simple atmega328 with internal clock 8 mhz in powerdown mode end rfm69 hw which send to gateway when pir motion is high powered all with 2 aa battery.
        The First test what i do is in breadboard atmega328 with optiboot 6.2 ( i have upload bootloader 8mhz internal , 38vk, bod 2v7) and simple sketch j gammon: result no microampere but around 2/5 mah in sleep mode;
        alexsh1A 1 Reply Last reply
        • mar.conteM mar.conte
          @Samuel235
          Hy
          alexsh1A Offline
          alexsh1A Offline
          alexsh1
          @mar.conte I'm not familiar with the sketch you mentioned. The best is to use the voltmeter and oscillograph to determine consumption.
          Why do you have BOD 2.7v? I do not have any BOD - this would let a node to run on two batteries until voltage drops to below 1.9V
          • alexsh1A alexsh1
            mar.conteM Offline
            mar.conteM Offline
            mar.conte
            @alexsh1
            I have only voltmeter extec, can i mesure ua?
            Can you send simple sketch for deep sleep ?
            S alexsh1A 2 Replies Last reply
              @alexsh1
              Samuel235
              @mar.conte - Are you basically saying that your hardware is using too much power to enable you to run on battery for any substantial time?
              MySensors 2.1.1
              • S Samuel235
                mar.conteM Offline
                mar.conteM Offline
                mar.conte
                @Samuel235
                Yes, i want obtain few micro amp but its two month wich i try without result.....
                tonnerre33T 1 Reply Last reply
                  @Samuel235
                  tonnerre33T Offline
                  tonnerre33T Offline
                  tonnerre33
                  wrote on last edited by tonnerre33
                  #148
                  @mar.conte Which skecth did you use ?
                  Did you have radio errors in your log ?
                  • S Offline
                    Samuel235
                    Could you please either include your sketch here or give us a link to the example sketch that you used please.
                    MySensors 2.1.1
                    • S Samuel235
                      mar.conteM Offline
                      mar.conteM Offline
                      mar.conte
                      wrote on last edited by mar.conte
                      #150
                      @Samuel235
                      Resolved
                      I have try with sketc j gammon https://www.gammon.com.au/forum/?id=11497
                      And the problem are pir input (model hrc-501)
                      Are ever high and the cpu dont go in sleep.
                      I have remove pir and all ok the atmega run 20 uah very good.
                      Can you advise a good pir wich run to 3,3 V for my project?
                      Tanks
                        @Samuel235
                        Resolved
                        Tanks
                        mar.conteM Offline
                        mar.conteM Offline
                        mar.conte
                        #151
                        @mar.conte
                        im not sure why pir with simple test like this http://playground.arduino.cc/Code/PIRsense is ok
                        but with my sketch the cpu reset forever
                        #include <Arduino.h>            // assumes Arduino IDE v1.0 or greater
                        #include <avr/sleep.h>
                        #include <avr/wdt.h>
                        #include <avr/power.h>
                        #include <avr/io.h>
                        ISR (PCINT2_vect)
                          // handle pin change interrupt for D0 to D7 here
                        }  // end of PCINT2_vect
                        const unsigned long WAIT_TIME = 4000;
                         const byte  LED =8 ;
                         const byte  LED2 =9 ;
                        int  wakepin =3 ;
                          unsigned long lastSleep;
                        volatile boolean motionDetected=false;
                        float batteryVolts = 5;
                        char BATstr[10]; //longest battery voltage reading message = 9chars
                        char sendBuf[32];
                        byte sendLen;
                        void checkBattery(void);
                        #include <RFM69.h>    //get it here: https://www.github.com/lowpowerlab/rfm69
                        // *********** IMPORTANT SETTINGS - YOU MUST CHANGE/ONFIGURE TO FIT YOUR HARDWARE *************
                        #define NETWORKID     100  // The same on all nodes that talk to each other
                        #define NODEID        2    // The unique identifier of this node
                        #define RECEIVER      1    // The recipient of packets
                        //Match frequency to the hardware version of the radio on your Feather
                        //#define FREQUENCY     RF69_433MHZ
                        //#define FREQUENCY     RF69_868MHZ
                        #define ENCRYPTKEY    "sampleEncryptKey" //exactly the same 16 characters/bytes on all nodes!
                        #define IS_RFM69HW   true // set to 'true' if you are using an RFM69HCW module
                        #define SERIAL_BAUD   115200
                        #define RFM69_CS      10
                        #define RFM69_IRQ     2
                        #define RFM69_IRQN    0  // Pin 2 is IRQ 0!
                        #define RFM69_RST     9
                        int16_t packetnum = 0;  // packet counter, we increment per xmission
                        RFM69 radio = RFM69(RFM69_CS, RFM69_IRQ, IS_RFM69HW, RFM69_IRQN);
                        void setup () {
                          pinMode (wakepin,INPUT);
                            pinMode(LED, OUTPUT);
                             pinMode(LED2, OUTPUT);
                               digitalWrite(wakepin,HIGH);
                          char buff[50];
                          Serial.begin(SERIAL_BAUD);
                          Serial.println("Arduino RFM69HCW Transmitter");
                          // Hard Reset the RFM module
                          pinMode(RFM69_RST, OUTPUT);
                          digitalWrite(RFM69_RST, HIGH);
                          delay(100);
                          digitalWrite(RFM69_RST, LOW);
                          delay(100);
                          // Initialize radio
                          radio.initialize(FREQUENCY,NODEID,NETWORKID);
                          if (IS_RFM69HW) {
                            radio.setHighPower();    // Only for RFM69HCW & HW!
                          radio.setPowerLevel(31); // power output ranges from 0 (5dBm) to 31 (20dBm)
                          radio.encrypt(ENCRYPTKEY);
                          Serial.print("\nTransmitting at ");
                          Serial.print(FREQUENCY==RF69_433MHZ ? 433 : FREQUENCY==RF69_868MHZ ? 868 : 915);
                          Serial.println(" MHz");
                        uint16_t batteryReportCycles=0;
                        void loop ()
                           //rf();
                          sleepNow();
                           rf();
                         //radio.sleep();
                                        // sleep function called here
                         radio.sleep();
                        void wake ()
                         // cancel sleep as a precaution
                          //sleep_disable();
                          // precautionary while we do other stuff
                         detachInterrupt (1);
                        }  // end of wake
                        void sleepNow()
                           if (millis () - lastSleep >= WAIT_TIME)
                            lastSleep = millis ();
                            byte old_ADCSRA = ADCSRA;
                            // disable ADC
                            ADCSRA = 0;
                            // pin change interrupt (example for D0)
                            PCMSK2 |= bit (PCINT16); // want pin 0
                            PCIFR  |= bit (PCIF2);   // clear any outstanding interrupts
                            PCICR  |= bit (PCIE2);   // enable pin change interrupts for D0 to D7
                            set_sleep_mode (SLEEP_MODE_PWR_DOWN);
                            power_adc_disable();
                            power_spi_disable();
                            power_timer0_disable();
                            power_timer1_disable();
                            power_timer2_disable();
                            power_twi_disable();
                          //PORTB = 0x00;
                            UCSR0B &= ~bit (RXEN0);  // disable receiver
                            UCSR0B &= ~bit (TXEN0);  // disable transmitter
                            sleep_enable();
                            noInterrupts ();
                          attachInterrupt (1, wake,HIGH);
                            digitalWrite (LED, LOW);
                          interrupts ();
                            sleep_cpu ();
                           digitalWrite (LED, HIGH);
                            sleep_disable();
                            power_all_enable();
                            ADCSRA = old_ADCSRA;
                            PCICR  &= ~bit (PCIE2);   // disable pin change interrupts for D0 to D7
                            UCSR0B |= bit (RXEN0);  // enable receiver
                            UCSR0B |= bit (TXEN0);  // enable transmitter
                          }  // end of time to sleep
                        void rf()
                         char radiopacket[20] = "Hello World #";
                          itoa(packetnum++, radiopacket+13, 10);
                          Serial.print("Sending "); Serial.println(radiopacket);
                          if (!radio.sendWithRetry(RECEIVER, radiopacket, strlen(radiopacket))) { //target node Id, message as string or byte array, message length
                            Serial.println("OK");
                          radio.receiveDone(); //put radio in RX mode
                          Serial.flush(); //make sure all serial data is clocked out before sleeping the MCU
                        • S Offline
                          Samuel235
                          Firstly, i can't read the structure the way you have posted your sketch. You should use the code function in the reply, the icon looks like "</>" above where you make your reply. Put your code in there for us to have any chance of reading it at all.
                          Secondly, I don't think that this is the place to be posting this issue. For a start, this isn't an issue relevant to the bootloader in this thread and secondly, it doesn't even have anything to do with MySensors.
                          MySensors 2.1.1
                            @alexsh1
                            alexsh1A Offline
                            alexsh1A Offline
                            alexsh1
                            @mar.conte yes, you can measure consumption (should be in uA) while sleeping with a good voltmeter.
                            However, I really fail to understand what has Nick's sketch you mentioned to do with MySensors? I suppose some people here may be aware of sleeping issues, but again your problem has nothing to do with MySensors.
                            Please see the following - it may help you troubleshoot your issue
                            https://www.mysensors.org/build/battery
                            • S Samuel235
                              mar.conteM Offline
                              mar.conteM Offline
                              mar.conte
                              @Samuel235
                              I wanted to build my projects with mysensors, first of all I started with bootloader found in this section to try them with examples that I know because I do not know yet mysensors, I wanted to learn it so I took the liberty to insert code in your section. if you can figure out my problem thank you or I apologize for the trouble thanks
                              • S Offline
                                Samuel235
                                I get why you done it, but i don't understand why. You don't need to 'know' mysensors.... There is a getting started page, i suggest you take a few hours and read through everything. I'm not helping with an issue that is completely not related to mysensors while on the mysensors forum. Just simply for future readers of this thread that come here to solve their issue, if this thread is bloated out with over 10/20 replies that is not related to the question at hand its much harder for them to find their resolution here. I suggest contacting the author of the code himself as i'm pretty sure that your issue is not the bootloader.
                                MySensors 2.1.1
                                • S Samuel235
                                  mar.conteM Offline
                                  mar.conteM Offline
                                  mar.conte
                                  @Samuel235
                                  Thanks anyway, this section introduced me to some very interesting bootloader, at least with these bootloader I can get a few microamperes for my projects, I will take note of your good day and thank you tips
                                  • S Offline
                                    siod
                                    Hi guys,
                                    I am getting an errror when trying to burn the bootloader, any idea what´s wrong? Im using Arduino IDE 1.6.10 and these settings:
                                    0_1495966865551_upload-48973443-91a2-4504-a73b-96557383d6bf
                                    and that´s the error:
                                    avrdude: Version 6.3, compiled on Jun 22 2016 at 16:05:21
                                             Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
                                             Copyright (c) 2007-2014 Joerg Wunsch
                                             System wide configuration file is "T:\Programme\Arduino 1.6.10\hardware\tools\avr/etc/avrdude.conf"
                                             Using Port                    : COM10
                                             Using Programmer              : stk500v1
                                             Overriding Baud Rate          : 19200
                                             AVR Part                      : ATmega328P
                                             Chip Erase delay              : 9000 us
                                             PAGEL                         : PD7
                                             BS2                           : PC2
                                             RESET disposition             : dedicated
                                             RETRY pulse                   : SCK
                                             serial program mode           : yes
                                             parallel program mode         : yes
                                             Timeout                       : 200
                                             StabDelay                     : 100
                                             CmdexeDelay                   : 25
                                             SyncLoops                     : 32
                                             ByteDelay                     : 0
                                             PollIndex                     : 3
                                             PollValue                     : 0x53
                                             Memory Detail                 :
        Block Poll               Page                       Polled
                                               Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
                                               eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
                                               flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
                                               lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                                               hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                                               efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                                               lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                                               calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
                                               signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
                                             Programmer Type : STK500
                                             Description     : Atmel STK500 Version 1.x firmware
                                             Hardware Version: 2
                                             Firmware Version: 1.18
                                             Topcard         : Unknown
                                             Vtarget         : 0.0 V
                                             Varef           : 0.0 V
                                             Oscillator      : Off
                                             SCK period      : 0.1 us
                                    avrdude: AVR device initialized and ready to accept instructions
                                    Reading | ################################################## | 100% 0.06s
                                    avrdude: Device signature = 0x1e950f (probably m328p)
                                    avrdude: erasing chip
                                    avrdude: reading input file "0x3F"
                                    avrdude: writing lock (1 bytes):
                                    Writing | ################################################## | 100% 0.03s
                                    avrdude: 1 bytes of lock written
                                    avrdude: verifying lock memory against 0x3F:
                                    avrdude: load data lock data from input file 0x3F:
                                    avrdude: input file 0x3F contains 1 bytes
                                    avrdude: reading on-chip lock data:
                                    Reading | ################################################## | 100% 0.02s
                                    avrdude: verifying ...
                                    avrdude: 1 bytes of lock verified
                                    avrdude: reading input file "0x06"
                                    avrdude: writing efuse (1 bytes):
                                    Writing |  ***failed;
                                    ################################################## | 100% 0.16s
                                    avrdude: 1 bytes of efuse written
                                    avrdude: verifying efuse memory against 0x06:
                                    avrdude: load data efuse data from input file 0x06:
                                    avrdude: input file 0x06 contains 1 bytes
                                    avrdude: reading on-chip efuse data:
                                    Fehler beim Brennen des Bootloaders.
                                    avrdude: verification error, first mismatch at byte 0x0000
                                             0xfe != 0x06
                                    avrdude: verification error; content mismatch
                                    avrdude done.  Thank you.
                                    still learning...
                                    • S siod
                                      Hi guys,
                                               Using Port                    : COM10
                                               PAGEL                         : PD7
                                               BS2                           : PC2
                                               RETRY pulse                   : SCK
                                               Timeout                       : 200
                                               StabDelay                     : 100
                                               CmdexeDelay                   : 25
                                               SyncLoops                     : 32
                                               ByteDelay                     : 0
                                               PollIndex                     : 3
                                               PollValue                     : 0x53
                                               Memory Detail                 :
                                               Hardware Version: 2
                                               Topcard         : Unknown
                                               Vtarget         : 0.0 V
                                               Varef           : 0.0 V
                                               Oscillator      : Off
                                               SCK period      : 0.1 us
                                               0xfe != 0x06
                                      alexsh1A Offline
                                      alexsh1A Offline
                                      alexsh1
                                      #158
                                      @siod what board are you using? Windows or Mac?
                                      I would suggest update Arduino IDE - you are running an old version
                                      Many people experience similar issues when using a wrong version of IDE:
                                      https://forum.arduino.cc/index.php?topic=431294.0
                                      • G Offline
                                        G Offline
                                        GertSanders
                                        I have been using version 1.8.x (at 1.8.2 now) for quite a while now, so no experience with 1.6.10
                                        Best is indeed to update the IDE, as this will also bring new versions of GCC (the compiler) and I thought also of AVRDUDE (transfertool). Not sure about that last bit though.
                                        Gert
                                        • S Offline
                                          siod
                                          Hi guys,
                                          thx for your quick reply. I could upload the bootloader using ver 1.6.5 of the Arduino IDE. After that I realized ther is already a 1.8.2 version released which is closing the gaps between arduino.cc and arduino.org.
                                          I havent tested this version now, but I guess it was just an IDE error, so everything´s fine now...
                                          still learning...
                                          12.2k
