  3. plugin RelayActuatorWithButton
9 Posts 3 Posters 2.8k Views 1 Watching
  • H
    H
    hirobo
    Hi friends!
    So I have built RelayActuatorWithButton, and has been working well with vera3.
    But when I unplug the vera3, the button does not turn on the relay.
    I want it to work without vera3.
    If vera fails, button still activates the lamps.
    Please help to solve this problem.
    • marceltrapmanM
      marceltrapmanM
      marceltrapman
      When your button is on the same board as the relay you can do what you want.
      You can simply search for 'arduino' and 'button' and you will find plenty of sketches on how to do that.
      Fulltime Servoy Developer
        This example will change state without receiving ack from controller
        https://codebender.cc/sketch:46847
        • H
          H
          hirobo
          Thank HEK
          I do not know programming arduino
          Solved my problem.
          • H hirobo
            Thank HEK
            Solved my problem.
            marceltrapmanM
            marceltrapmanM
            marceltrapman
            I still think it is worth it to search for examples and check out what is going on.
            You will need it at some point :)
            • H
              H
              hirobo
              One more question HEK.
              With vera3 off. When I press the button 3 times, the third he has small response delay
              Always the third touch of the button it has a delay.
              How to solve this bug??
                I haven´t got a slightest idea why it would delay on the third push.
                • H
                  H
                  hirobo
                  How can I change the button for a sensor?
                  To learn the status of the lamp on or off
                  • H
                    H
                    hirobo
                    has no way to resolve this delay???
