  3. Pin 1 not usable
Pin 1 not usable
5 Posts 3 Posters 1.8k Views 3 Watching
  • flylowgofastF
    flylowgofastF
    flylowgofast
    Hello all,
    I try to use on Arduino pro mini the pin 1 (Tx) as output to trig a triac. But Since I have been using MySensors, I can't use this pin. Do you have any informations on this problem ? is there a link with led Blinking ?
    regads
      Serial uses pin 1 so if you have DEBUG turned on or are using Serial anywhere in your sketch you will not be able to use pin 1.
      Except that, nothing in MySensors is using pin1. I use that pin myself for one sensor. Could you post your sketch?
        In the development branch you can disable MySensors from using pin 0/1
        https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/MyConfig.h#L49
        • flylowgofastF
          flylowgofastF
          flylowgofast
          Hello, thank you for your reply. You are right, it works fine without debug.
          Thanks again
          • flylowgofastF flylowgofast
            Thanks again
            @flylowgofast great! Thanks for reporting back :)
