  3. MQTT SSL Support
MQTT SSL Support
12 Posts 5 Posters 8.1k Views 6 Watching
  • noelgeorgiN
    noelgeorgiN
    noelgeorgi
    @hek @Anticimex is there any way to add SSL support for MQTT client on nodemcu(esp8266). I know that esp8266 supports SSL(from node-mcu custom builds http://nodemcu-build.com/). I am using domoticz as controller and it already has MQTT SSL support. I am planning to run domoticz on my VPS so SSL support for MQTT is required.
    • AnticimexA
      AnticimexA
      Anticimex
      No idea. I have only looked at security from a node2node node2gw perspective. Not controller2gw. That is too controller specific to be generalized efficiently. But there probably exist ssl libs out there which you could look at.
      • noelgeorgiN
        noelgeorgiN
        noelgeorgi
        Thanks for the reply but the controller already supports ssl, its the mysensors eso8266mqtt client that doesnt support ssl!!! :disappointed_relieved:
        AnticimexA 1 Reply Last reply
          We're using the pubsubclient library for the MQTT communication:
          https://github.com/knolleary/pubsubclient
          From what I can tell it doesn't support the WiFiClientSecure at the moment. But I could be wrong.. just did a quick search among their issues on github.
          • noelgeorgiN noelgeorgi
            AnticimexA
            AnticimexA
            Anticimex
            @noelgeorgi Yes, but I am not doing controller specific adaptations to the library for signing/encryption. So your ssl feature in your specific gw is specific to you (and all others who happen to need ssl for MQTT).
            • noelgeorgiN
              noelgeorgiN
              noelgeorgi
              Thanks for the fast replies. This is the only forum i have seen with the fastest replies. @hek @Anticimex there really exist an mqtt library for esp8266 supporting SSL, any way to change to this: https://github.com/tuanpmt/esp_mqtt
                Please, go ahead and create your own GatewayTransport variant. Will probably be appreciated by others as well.
                • noelgeorgiN
                  noelgeorgiN
                  noelgeorgi
                  wrote on last edited by noelgeorgi
                  Already work in progress, esp8266 2.1.0 library added support for having ca certificates in SPIFFS memory, not enough documentation on using it....:sweat: :disappointed:
                  https://github.com/esp8266/Arduino/blob/master/libraries/ESP8266WiFi/src/WiFiClientSecure.h#L52-L66
                  • J
                    J
                    jkandasa
                    https://github.com/knolleary/pubsubclient will not support for SSL. https://github.com/knolleary/pubsubclient/issues/23
                    • noelgeorgiN
                      noelgeorgiN
                      noelgeorgi
                      you just have to change WiFiClient client; to WiFiClientSecure client;
                      • noelgeorgiN
                        noelgeorgiN
                        noelgeorgi
                        finally succeeded in implementing ssl for MQTT with esp8266!!!!!!!:smiley: :satisfied: :relaxed: will post in Development...... http://forum.mysensors.org/topic/3385/ssl-support-for-mqtt-on-esp8266
                        • F
                          F
                          flip
                          Did you have any success to implement SSL support to the mqtt broker?
