  3. How to force static use of an repeater-node...?
6 Posts 4 Posters 2.9k Views 4 Watching
  • I
    I
    idstone
    Hi all,
    may be someone would be so kind to tell me, how to force the usage of an specified repeater-node?
    I've set up a repeater-node with an NRF24L01+PA+LNA antenna version. This node is powered by 3,3v DC and working properly. A sensor, which monitors my dehumidifier-water-tank, sends via that node.
    My problem is, that a new sensor at my entrance door reaches the gateway not always, so I get an dead node. I would prefer this node also being connect via this antenna-pimped repeater next to itself.
    Thanks in advance!
    Sincerely
    Carsten
    • I idstone
      Hi all,
      Thanks in advance!
      Sincerely
      Carsten
      martinhjelmareM
      martinhjelmareM
      martinhjelmare
      @idstone
      Hi!
      In the 1.5 releases you can set a static parent in the begin method. It's the fourth argument. See "Starting up the library" here:
      http://www.mysensors.org/download/sensor_api_15
      • I
        I
        idstone
        Hi martinhjelmare...
        so I think I got it...
        changed from:
        // gw.begin();
        to
        // Test - nur über Repeaternode 103 senden!
        gw.begin(NULL, AUTO, false, 103);
        fhem now shows parentId 103...
        I'll confirm after some testing :)
        Thanks a lot
        • I idstone
          changed from:
          // gw.begin();
          to
          Thanks a lot
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @idstone
          :thumbsup:
          • Mark SwiftM
            Mark SwiftM
            Mark Swift
            Guys, how do we do this in the current dev branch?
              #define MY_PARENT_NODE_ID xx
