  3. ESP NodeMcu in bootloop
4 Posts 2 Posters 2.4k Views 2 Watching
  • SweebeeS
    SweebeeS
    Sweebee
    Ive tested my ESP and it works fine with sample sketches, but with the ESP gateway it keeps booting:
    ?�F�x��D�H!�ȩLR�@H��0;255;3;0;9;Starting gateway (RNNGE-, 2.0.0-beta)
    0;255;3;0;9;Radio init successful.
    scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 5
    cnt
    connected with Nieuwenhuis, channel 1
    dhcp client start...
    .ip:192.168.1.41,mask:255.255.255.0,gw:192.168.1.1
    .IP: 192.168.1.41
    �@��0;255;3;0;9;Starting gateway (RNNGE-, 2.0.0-beta)
    scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 5
    cnt
    .IP: 192.168.1.41
    H!�ȩL��@H��0;255;3;0;9;Starting gateway (RNNGE-, 2.0.0-beta)
    scandone
    state: 0 -> 2 (b0)
    state: 2 -> 3 (0)
    state: 3 -> 5 (10)
    add 0
    aid 5
    cnt
    .IP: 192.168.1.41
    • gerritvG
      gerritvG
      gerritv
      There is a problem with this configuration and ESP8266/Arduino 2.1 library.
      See http://forum.mysensors.org/topic/3524/solved-wifi-gateway-problem-esp8266/2 for more details.
      Have you tried the esp8266 as a sensor node or just with some of the esp8266 examples? Just trying to see what we can eliminate from the search for a solution.
      SweebeeS 1 Reply Last reply
      • gerritvG gerritv
        SweebeeS
        SweebeeS
        Sweebee
        wrote on last edited by Sweebee
        @gerritv I tested with some esp examples, like the http server. They work fine.
        Edit: yes 2.0 is working, thanks :)
        • gerritvG
          gerritvG
          gerritv
          See the above mentioned topic, there is a solution to using esp8266/Arduino 2.1 library.
