  3. Vera
  4. Node w/o radio, direct to Vera & usb hub
11 Posts 3 Posters 3.8k Views 3 Watching
  • pbcstudiosP
    pbcstudiosP
    pbcstudios
    I know that this has been asked before. I spend some time looking through the Forum and really couldn't find an answer. I have 2 relay switches that are sitting less than 6 inches from my serial Gateway and would like to see if there is a way to directly connect them to my Vera unit. My gateway, like most, is on a USB hub. I am not looking to add the relays to the Gateway I/O's, but would like to add a stand-alone relay that can be controlled directly through Vera. My search through the Forum has shown mixed results some people say it is possible others say it is not. I'm looking to see if anyone has actually successfully done this. I find my motion sensors and light sensors work great on the my sensors Network, however occasionally the two relays I have do not receive the signal to turn on or off from the gateway. I have found the serial Gateway sketch under the dev section on GitHub, but still was unable to make it work successfully. Any advice would be helpful.
    TheoLT 1 Reply Last reply
    • pbcstudiosP pbcstudios
      TheoLT
      TheoLT
      TheoL
      @pbcstudios I don't have Vera. But I've experienced the simular problems in the best. Did you add the capacitor to the antenna? It solved my problem.
      You could also try to add Ack mechanism to the sensor. I wouldn't attach the relays directly to Vera. If for some reason you want to switch to another HA. You'll have to find another solution.
      • pbcstudiosP
        pbcstudiosP
        pbcstudios
        Yes, capacitors, regulated wall wart, etc...lol. Doesn't happen often and it's not the driving force behind wanting a direct connect. It just seems silly to have a transmitter next to a receiver. :)
          TheoLT
          TheoLT
          TheoL
          @pbcstudios maybe you can add a serial gateway and connect the relays to that. I agree, it seems silly to have a transceiver next to the gateway. I know some people have connected sensors to the gateway, but I don't think I'd do that.
            @pbcstudios
            The gateway in the development branch should be able to handle sensors/actuators directly connected to it (without the need for any attached radio).
            So what is the problem you're experiencing?
            Did you create a sketch?
            • pbcstudiosP
              pbcstudiosP
              pbcstudios
              wrote on last edited by pbcstudios
              Thank you for your reply. While I can understand the node sketches and alter them to fit my needs, the gateway sketch eludes me. I took the GatewaySerial.ino sketch in the development branch and inserted voidsetup and voidloop from the relay sketch. I guess it's not as easy as combining node sketches. When I compile I get a "gw not declared in this scope" error. I'm not even sure if I do get it working, if I create a new Mysensors plugin and hit Start to include or create a Relay device in Vera.
               * The ArduinoGateway prints data received from sensors on the serial link.
               * The gateway accepts input on seral which will be sent out on radio network.
               * The GW code is designed for Arduino Nano 328p / 16MHz
               * Wire connections (OPTIONAL):
               * - Inclusion button should be connected between digital pin 3 and GND
               * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
               * LEDs (OPTIONAL):
               * - To use the feature, uncomment MY_LEDS_BLINKING_FEATURE in MyConfig.h
              // Enable serial gateway
              #define MY_GATEWAY_SERIAL
              // Flash leds on rx/tx/err
              #define MY_LEDS_BLINKING_FEATURE
              // Set blinking period
              // Enable inclusion mode
                gw.sendSketchInfo("Relay", "1.0");
              void presentation() {
                  gw.present(sensor, S_LIGHT);
                  pinMode(pin, OUTPUT);
                  digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
                gw.process();
                if (message.type==V_LIGHT) {
                   // Change relay state
                   // Store state in eeprom
                   // Write some debug info
                   Serial.print(message.sensor);
              • TheoLT
                TheoLT
                TheoL
                I think you forgot to copy something. If I look at the Serial gateway example in 1.5.4 I see at least this line:
                // Construct MySensors library (signer needed if MY_SIGNING_FEATURE is turned on in MyConfig.h)
                // To use LEDs blinking, uncomment WITH_LEDS_BLINKING in MyConfig.h
                #ifdef WITH_LEDS_BLINKING
                MySensor gw(transport, hw /*, signer*/, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
                #else
                MySensor gw(transport, hw /*, signer*/);
                This part (you need more) is missing in your sketch hence the errors.
                  wrote on last edited by hek
                  Just a sec.. I'll modify the sketch a bit.
                  I have now disabled radio and the inclusion button feature and MY_LEDS_BLINKING_FEATURE as it will interfere with your relays.
                   * LEDs (OPTIONAL):
                  // #define MY_RADIO_NRF24
                  // #define MY_LEDS_BLINKING_FEATURE
                  // #define MY_INCLUSION_MODE_BUTTON_PIN  3
                  pbcstudiosP 1 Reply Last reply
                     * LEDs (OPTIONAL):
                    pbcstudiosP
                    pbcstudiosP
                    pbcstudios
                    @hek Thank you. I see how the pins are in conflict, but I copy the sketch posted and still got errors when compiling (ie. 'sendSketchInfo' was not declared in this scope). What am I doing wrong?
                      Did you really install the MySensors library from the dev-branch?
                        pbcstudiosP
                        pbcstudiosP
                        pbcstudios
                        @hek Ahhh! Got it. Thank you. But can I use the original Gateway sketch with attached radio from the Master branch? My Serial gateway with a radio died this morning, which is why I started down this path. I figure if I have to start my Gateway from scratch I might as well try connecting my relays directly. Or do I have to re-install that library?
