  3. Mi-Light controller for Mysensors
69 Posts 15 Posters 52.1k Views 27 Watching
  • Iraklis KourtisI Iraklis Kourtis
    Hi Ted,
    Your project looks really amazing and I think it is exactly what I was looking for.
    I want to change my lighting at home. I am thinking of adding 8 LED strips that will be controlled by 2 x 4 Mi-Light remote controls and 2 x wifi bridges. As I would like to still be able to use the wall switches to turn them on/off I was thinking of using your solution. Do you think it will be feasible with your project? Also is there a way to reduce the wifi bridges to 1 instead of having 2?
    Thank you for this great project!
    Iraklis
    ted
    @Iraklis-Kourtis
    The controller is all you need to control the lights. It does not need wifi bridge
    • CrankyCoderC
      CrankyCoderC
      CrankyCoder
      Has this been converted to 2.0?
      Also, to build the controller for this i don't need anything special other than the arduino + nrf24l01 correct? I am VERY interested in this
      Home Automation Tinkerer
      www.CrankyCoder.net
      Gateway: MQTTClientGateway
      MySensors: 2.3
      • CrankyCoderC
        CrankyCoderC
        CrankyCoder
        i got 2 of my milight bulbs in today. Just wondering if anyone is still using this?
        www.CrankyCoder.net
        MySensors: 2.3
        • Cliff KarlssonC
          Cliff KarlssonC
          Cliff Karlsson
          I would like to use this solution as it seams to be really great to have both a NRF/Mi-light-Repeater for every "node". But my skils are not enough to make this work with RGB-strips/bulbs and to have it working with domoticz. I am using the standard Domoticz way of controllign them using the original mi-light gateways and have also experimented with RF-link mi-light control.
          But my dream-scenario is that some nice coding-wiz will post a complete solution that even newbies can integrate this in this forum-thread. But I would not count on it.
          • CrankyCoderC
            CrankyCoderC
            CrankyCoder
            I have done a little bit of tinkering with it today. i have not cleaned up the code yet, but I have been able to get my arduino repeater to pair with one of the lights, and turn it on and off. My progress so far.
            • Convert to using the mysensor 2.0 framework
            • setup a bulb and paired
            • can turn bulb on and off
            My next step is to see if i can change colors on the bulb. The only thing I noticed is there is a small delay when switching the radio between the mysensors rf and the milight rf protocol. I may later see if it's possible to do 2 radios. But for now progress is being made with a repeater node.
            Once it's working, Ill see if i can post some samples of how I controlled it via mqtt. (I use openhab)
            If the original author of this sketch is interested I will provide him current code progress. Or I can throw it on github if anyone is interested in tinkering with it. I definitely want to get some documentation together for how to get multiple bulbs working on it.
            www.CrankyCoder.net
            MySensors: 2.3
            • CrankyCoderC
              CrankyCoderC
              CrankyCoder
              I have put my mods on github.
              https://github.com/brunkj/MySensorsMiLight/
              I have not been able to mess with it since the weekend. Still trying to get some info on the RGB part. If anyone wants to take a shot at it let me know if you make any progress :)
              www.CrankyCoder.net
              MySensors: 2.3
              • CrankyCoderC
                CrankyCoderC
                CrankyCoder
                spent some more time working on this. Still not having luck figuring out a what to send to the V_VAR1 to get the bulb to do anything
                I can send simple on off for S_LIGHT V_STATUS
                if (message.type == V_STATUS)
                    //Serial.println("triggered V_STATUS");
                    mlr.begin();
                    // Change light status
                    if ( message.getBool())
                      Serial.println("here");
                      // Serial.println("triggered ON");
                      sendCommand (outgoingPacket_on, sizeof(outgoingPacket_on));
                    else {
                      //  Serial.println("triggered off");
                      sendCommand(outgoingPacket_off, sizeof(outgoingPacket_off));
                    _begin();
                Easy. But the V_VAR1 on S_CUSTOM I can't figure out what to put in the payload
                if (message.type == V_VAR1)
                    // Serial.println("triggered V_VAR1");
                    incomingCommand = (char *)message.getCustom();
                    Serial.println((char *)message.getCustom());
                     mlr.begin();
                     Serial.println("#############");
                    for (int i=0; i<sizeof(outgoingPacket); i++)
                    { outgoingPacket[i] = 16*char_to_uint8_t(incomingCommand[i*2]) + char_to_uint8_t(incomingCommand[i*2+1]);
                      Serial.println(outgoingPacket[i]);
                    Serial.write(outgoingPacket, 7);
                    sendCommand(outgoingPacket, sizeof(outgoingPacket));
                    _begin();
                I have referenced the hacking milight protocol pages and many other, I just can't seem to get it right to get my bulb to do anything.
                Anyone want to take a shot at it? or have payload data I could try?
                full sketch
                #define MY_REPEATER_FEATURE
                #include <MyConfig.h>
                #define CE_PIN 9     //CE and CSN pin for nrf24 radio
                #define CSN_PIN 10
                #include <nRF_24L01.h>
                #include <avr/power.h>
                #include <printf.h>
                #include "PL1167_nRF24.h"
                #include "MiLightRadio.h"
                #define NODE_ID 100
                #define mi_command_repeat 30   //# of times to resend the command to bulb
                RF_24 mi_radio(CE_PIN, CSN_PIN);
                PL1167_nRF24 prf(mi_radio);
                MiLightRadio mlr(prf);
                                                       // B0-176   F2-242    EA-234    6D    B0    02    f0
                static uint8_t outgoingPacket_on[7] = { 0xB0, 0xF2, 0xEA, 0x6D, 0x91, 0x03, 0x00};  //the first three #s are remote ID, replace with yours
                static uint8_t outgoingPacket_off[7] = { 0xB0, 0xF2, 0xEA, 0x04, 0x91, 0x04, 0x00};
                uint8_t outgoingPacket[7];
                #define sizeofincomingCommand 15 //command comes in text form of 7 uint8_t, with an additional NULL at end
                char *incomingCommand;    //array for incoming command
                boolean mi_radio_state = false;
                  //Send the sensor node sketch version information to the gateway
                  sendSketchInfo("Milight controller", "1.0");
                   //clock_prescale_set(clock_div_2);     //for a barebone atmega328p, this  will make the CPU running at 4MHz.
                  //Serial.begin(115200);
                  // The third argument enables repeater mode.
                  present(0, S_LIGHT);
                  present(1, S_CUSTOM);
                  // The command will be transmitted in V_VAR1 type, in the following 7 byte format: ID1 ID2 ID3 COLOR BRIGHTNESS COMMAND.
                  // see https://hackaday.io/project/5888-reverse-engineering-the-milight-on-air-protocol
                  Serial.println(message.type);
                    mlr.begin();
                    else {
                    _begin();
                     mlr.begin();
                    _begin();
                //gw.begin(incomingMessage, NODE_ID, true);
                void sendCommand(uint8_t mi_Command[7], int sizeofcommand)
                { for (int i = 0; i < mi_command_repeat; i++)
                  { mlr.write(mi_Command, sizeofcommand);
                uint8_t char_to_uint8_t(char c)
                	uint8_t i;
                	if (c <= '9')
                		i = c - '0';
                	else if (c >= 'a')
                		i = c - 'a' + 10;
                	else
                		i = c - 'A' + 10;
                	return i;
                www.CrankyCoder.net
                MySensors: 2.3
                • n1ck1355N
                  n1ck1355N
                  n1ck1355
                  wrote on last edited by n1ck1355
                  #48
                  @Jason-Brunk
                  unfortunately i havnt got my own milight bulbs but for what i've seen on the
                  reverse engineered protocol page the payload must be something like
                  "07B0F2EA359001B9ACF9" for all on or
                  "07B0F2EA7D910FD4EC72" for green
                  or the part "07B0F2EA" must be the ID so the payload
                  is somethink like "359001B9ACF9" for all on and
                  "7D910FD4EC72" for green
                  • n1ck1355N
                    n1ck1355N
                    n1ck1355
                    @ted are you there and can get a hint please? :)
                    T 1 Reply Last reply
                    • n1ck1355N n1ck1355
                      ted
                      @n1ck1355 @Jason-Brunk
                      sorry i'm been really busy with job recently. I used openhab to send the payload to V_VAR1 and S_CUSTOM. When I get home tonight, I'll post the openhab rule file so people can get some sense how to control color.
                      • n1ck1355N
                        n1ck1355N
                        n1ck1355
                        that's really great :) Thanks!
                          ted
                          @n1ck1355
                          sorry for the delay. Here is what I learned from https://hackaday.io/project/5888-reverse-engineering-the-milight-on-air-protocol
                          Basically, the mi controller will receive text string and convert them into HEX format and send it to the bulb. The text string should be formatted as the following (+ added for easy of reading, no '+' in the actual command):
                          ID + color + brightness + button code + seq
                          The ID is the ID of the bulb to be controlled, it is six byte in ASCII but will be converted into 3 byte HEX before sending to the bulb.
                          color, brightness and button code are each 2 byte in ASCII and will be converted into 1 byte HEX and send to bulb.
                          Seq is 2 byte in ASCII but it appears that you can just use "00".
                          To change color, you need to send a color code (e.g.: "00"=purple, "1B"=red, "40"=yellow,e tc) and using button code "OF".
                          To change back to white, you use "04" as color code and "13" as button code.
                          The detailed button code definition can be found here:
                          https://cdn.hackaday.io/images/1224221432724803073.jpg
                          Hope this helps.
                          • n1ck1355N
                            n1ck1355N
                            n1ck1355
                            Thank you @ted :)
                            i already played with it and can turn the bulbs on/off. i will play around with your
                            information to make the other funktions work.
                            But what i see is that you cannot e.g. dim the bulbs softly from say 100% to 20% cause
                            that would be more commands behind each other. But the node must reset itself after
                            each command by calling _Begin() and that takes some time..
                            any suggestions to resolve that?
                              Thank you @ted :)
                              ted
                              @n1ck1355
                              my only solution is to use two radios, one receives command from the gateway and the other sending command to the bulbs. it might be doable with just 1 arduino by using softSPI.
                              Nca78N 1 Reply Last reply
                              • T ted
                                @n1ck1355
                                Nca78N
                                Nca78N
                                @ted said:
                                @n1ck1355
                                I don't see why you would need SoftSPI for that ? It should just need some change for CE and CSN pins for the NRF that is used to send data to the milights. I will try to find time to check that this week.
                                • n1ck1355N
                                  n1ck1355N
                                  n1ck1355
                                  @Nca78 :
                                  did you have success with thw NRF boards connecting?
                                    @Nca78 :
                                    Nca78N
                                    Nca78N
                                    @n1ck1355 said:
                                    @Nca78 :
                                    Hello, unfortunately I had no time to test it, I was busy with my Livolo switch :P
                                    • Cliff KarlssonC
                                      Cliff KarlssonC
                                      Cliff Karlsson
                                      I just tried out openhab2, would it be easier controling the bulbs from openhab2 or do I still to do alot of "coding" on my own?
                                      • Nca78N
                                        Nca78N
                                        wrote on last edited by Nca78
                                        #59
                                        Hello, few months have passed and I finally had a look at the code from @Jason-Brunk
                                        I made a MiLightBulb class with methods to set on/off, set brightness level, set color and set animation. It still needs improvements as brightness is not working, some colors are a bit off and I didn't test animation yet but it's starting to take shape and I can use it from RGB light control in domoticz.
                                        I have connected 2 nrf24 also, using pins 7&8 for the one sending MiLight messages instead of 9&10 and it running fine as expected, no use to call begin() all the time: much more reactive.
                                        I'll publish the code as soon as I have time to finish and clean up.
                                        • Cliff KarlssonC
                                          Cliff KarlssonC
                                          Cliff Karlsson
                                          Great news @Nca78
